Old 07-19-2007, 10:39   #1 (permalink)
Member: 264667
Sonork: 100.105892
Thanks Meter: 481
NeeD Help For ZTE A12
i prepare cable my self ,but infinty does not booting phone,also m fail in serch A12 in ZTE moduel.it is phone Lock.
Old 07-19-2007, 11:03   #2 (permalink)
Member: 128745
Thanks Meter: 16,936
double check pinout .
reverse rx and tx
Old 07-19-2007, 12:30   #3 (permalink)
Member: 264667
Sonork: 100.105892
Thanks Meter: 481
reverse rx and tx
check 2 3 times also reverse,also with ufs com emulater (mean 2 different type cables)infinity have A12+, i have A12 in my hand,is it ok?
Old 07-19-2007, 15:06   #4 (permalink)
Member: 130995
Thanks Meter: 35,227
I can't say anything about A12 because A12+ was tested.
Please, read this link to get more info about A12:
http:///vbb/showpo...17&postcount=6
Old 07-19-2007, 16:38   #5 (permalink)
Member: 264667
Sonork: 100.105892
Thanks Meter: 481
ok i did it.in short time i will post all data,what i did,how i did.
10x for u r responce,it was very easy the origional mistake was frm Rj-45.as u explain in other therad about pin 2 3 and pin 8,as frm yours the pin was describe rj 45 as TX and pin 3 as RX, BUT HERE IT WAS TOTALY CHANGE PIN 2 IS RX AND PIN 3 IS TX AS SHOWN IN PINOUTS MENU IN SOFTWARE,WHERE I NEGLECTED IT AND REMEBER THE EXPLANTION AS IN AONTHER THERAD.
Old 07-19-2007, 17:02   #6 (permalink)
Member: 264667
Sonork: 100.105892
Thanks Meter: 481
Rj 45 Pinouts For Infinty Box
HERE IS OROIGIONAL RJ 45 PINOUTS FOR INFINTY BOX
Old 07-19-2007, 17:14   #7 (permalink)
Member: 264667
Sonork: 100.105892
Thanks Meter: 481
Zte A12 How To Handle With Infinty
IF U HAVE A CABLE THEN U CAN EASLY HANDLE IT WITH INFINTY BOX SIMPLY HOLD THE POWER BOTTON AND YOU CAN DO RESET SETTINGS OR EVEN UNLOCK THE PHONE.IF U HAVE NOT A CABLE U CAN MADE YOUR BY YOUR SELF.
  • TAKE ANY EXTERA CABLE REMOVE THE HEAD FRM THE CABLE AND GET THE RJ 45 PART.
  • NOW FIND ANY SAMSUNG UFS EXTERA CABLE, REMOVE ALL WIRES FRM IT.
  • OPEN THE PHONE TRACE PIN 11 13 AND 14, FRM PHONE CB TO THE CONECTER WHICH U PULG (AS 11 IS GROUND 13 IS RX AND 14 TX).
  • NOW CONECT THE RJ 45 PART TO THE SAMSUNG CABLE CONECTER, ONE BY ONE AND CONECT ALL WIRES TO THE CONECTER.
  • REMBER U CAN CONECT THE PHONE, WITHOUT THIS SAMSUNG UFS CONECTER,BY CONECTING ONE WIRE TO ANY GND OF THE PHONE AND TX AND RX TO 13 AND 14 POINTS DIRECTLY TO INER SURFACE OF THE CB OF THE PHONE,WHICH IS ALSO SO EASY,IN THIS CASE U CAN USE INVITER POWER SUPPLY INSTEAD OF BATTERY, TO AVOID , COMPLETE CLOSE THE PHONE.
ZTE A 12 CLASSIC PHONE
HOW TO MAKE U R OWN CABLE
ADMIN
APPLE TEAM
Old 07-19-2007, 17:16   #8 (permalink)
Member: 264667
Sonork: 100.105892
Thanks Meter: 481
Zte A12
HERE IS THE LOG OF THE PHONE USING INFINTY
COM5 [VCP1] selected
Device: ZTE-A12+
Checking data, wait...
Action: reset
Boot...
Phone must be POWERED-OFF !
Press and HOLD Power button !
Connecting, wait...
Release Power button !
flash: EC22A000000000:80E59F00000000
flash: Samsung T 4Mb
Boot Done
Set baud...
115200
Set baud Done
Check flash...
Reading[eeprom-fat]...
file saved: backup_eeprom-fat_ZTE-A12+_20070719-181421.98E.bin
Reading[eeprom-ffs]...
file saved: backup_eeprom-ffs_ZTE-A12+_20070719-181519.98E.bin
Check flash Done
Check space...
Check space Done
Check parameters...
Check parameters Done
Erase...
Erase Done
Write...
Write Done
Finished, time used: 120 sec
Remove/Install battery now !
Old 07-19-2007, 17:24   #9 (permalink)
Y2ksalman's Avatar
Member: 194511
Sonork: 03335548581
Thanks Meter: 1,607
good work faisal and keep sharing with us
Old 07-19-2007, 18:38   #10 (permalink)
sahil2000ind's Avatar
Member: 269044
Sonork: 100.1590584
Thanks Meter: 3,949
very nice work mann keep going
Old 07-19-2007, 20:44   #11 (permalink)
Member: 130995
@..::AppleLinks::..
Please, read flash from ZTE-A12 and send to [email protected]
Thanks a lot !
Old 07-20-2007, 06:18   #12 (permalink)
Member: 264667
Sonork: 100.105892
Thanks Meter: 481
@..::AppleLinks::..
Thanks a lot !
ok i will do next time,bcz i back the phone to coustumer,bcz it was a phone lock,and it was ok.
Old 08-24-2007, 11:01   #13 (permalink)
Member: 187451
Thanks Meter: 163
COM2 selected
Device: ZTE-A12+
Action: reset
Boot...
Connecting, wait...
Boot Done
Set baud...
115200
Set baud Done
Check flash...
file saved: backup_eeprom-fat_ZTE-A12+_20070824-145857.98E.bin
file saved: backup_eeprom-ffs_ZTE-A12+_20070824-145952.98E.bin
Check flash Done
Check space...
Check space Done
Check parameters...
Erase...
Erase Done
Write...
Write Done
Finished, time used: 104 sec
Old 08-24-2007, 11:02   #14 (permalink)
Member: 187451
Thanks Meter: 163
Here Is Log
COM2 selected
Device: ZTE-A12+
Action: reset
Boot...
Connecting, wait...
Boot Done
Set baud...
115200
Set baud Done
Check flash...
Check flash Done
Check space...
Check space Done
Check parameters...
Erase...
Erase Done
Write...
Write Done
Old 08-24-2007, 11:05   #15 (permalink)
Member: 187451
Thanks Meter: 163
Thanks Apple Links,i Used Ur Trick To Made My Cable.
Need help for ZTE-MTK & treo module bramer2 FuriousGold 4 12-29-2009 23:18
I need help for Unlock ZTE X761 vitorafg UnlockBase 0 12-22-2009 14:17
i need help for Zte A301 chronic Infinity-Box 2 09-18-2009 09:35
22 Jun 2008: "AModule" v1.30:imei repair function added for .ZTE-A12, A12+, A15, A16, alamgir80 Infinity-Box 6 06-23-2008 11:48
Need Help on Zte C160 mail2sayem ZTE 0 04-24-2008 08:00
Page generated in 0.27534 seconds with 10 queries
