Need HUAWEI T261L Flash File Pls upload HUAWEI T261L Flash File, I flash using support area file, but phone has no display.... |
Do you have original full flash backup ? |
i don't have original full flash backup. please help me thanks |
If required file can not be found in support area (please use "search" function in support area first) it will be good if somebody can read full flash from the same good working phone and send full flash backup to [email protected] so we will be able to prepare and upload good working files in support area for all users. Here is an instruction how to make "search" in support area: http://forum.gsmhosting.com/vbb/showthread.php?t=499453 Please, DO NOT send to us backup files from damaged phones. We CAN NOT repair damaged files ! |
Phone flash ok with support area file, turn on, but blank display.. Please somebody read full flash & upload here.... thx.. COM3 [VCP0] selected module v1.66 Device: Huawei-T261L-HW-A Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T261L-HW-A_eeprom-static_20090803-115116.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T261L-HW-A_eeprom-security_20090803-115118.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T261L-HW-A_eeprom-complete_20090803-115124.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Erasing: Firmware Writing: Firmware Erasing: Firmware Writing: Firmware Write Done Finished, time used: 466 sec Remove/Install battery now ! |
How to restore full flash backup: It is possible to restore back eeprom/ffs files without additional files conversion. It is not possible to restore full flash files to avoid permanently dead phones. If you have full flash backup file and want to restore it: 1. Check support area, probably required file already exist there 2. If required file is not found send a mail with the next information to support: - reason to send files - full text from phone back label - flash backup file We will check your files, prepare and upload good flash files in support area ASAP. |
