Need info for mtk6735 this error Halo hi, I need to know how to solve the following log error 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 20 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x07000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with AUTH Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... [DA_ERROR] : DONE Boot Error! Operation Failed Elapsed: 00:00:04 Reconnect Power/Cable! I could see here Bootloader is locked. The Phone is MEIZU, dont know model no. Has come for Security lock. Thanks, br jackle123 |
Not Support this phone atm. |
Sent from my S_plus using Tapatalk |
HTC Desire 828 dual sim HTC Desire 828 dual sim Code: Operation : Check / Read Info [ v1.42 ] |
Then have no idea about htis phone. |
Meizu M2 Note 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 48 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x07000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with AUTH Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1616.01.01 Sending and initialize DA ... [DA_ERROR] : DONE Boot Error! Operation Failed Elapsed: 00:00:08 Reconnect Power/Cable! :)Develop new features and support we will all be very grateful. |
the answers is in LOGS... read logs you will get the answer |
