10-04-2017, 17:36 | #1 (permalink) |
No Life Poster Join Date: Feb 2010 Location: Macedonia Age: 49
Member: 1246981 Status: Offline Sonork: 100.1590424 Thanks Meter: 316 | lenovo a319 hang on logo here is log Chinese Miracle II [MTK module] v 1.58 Scatter Load Ok , BaseBand : MT6572 , Project : huaqin72_cwet_1a_kk , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483447316404050BA23D446285 Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x20000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A483447316404050BA23D446285 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xE0153C46B65A324BE3359277E8D0A4C4 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : huaqin72_cwet_1a_kk , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled Switching to HSUSB HSUSB Init Ok BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3765 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x0000000094840000 Flash Pre-Erase Done, time used : 00:00:02 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_huaqin72_cwet_1a_kk.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0012 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:04:10 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:01:17 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:05:58 Reconnect Power/Cable! |
10-04-2017, 17:40 | #3 (permalink) |
Member: 1246981 Status: Offline Sonork: 100.1590424 Thanks Meter: 316 | here is info before i flash Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483447316404050BA23D446285 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A483447316404050BA23D446285 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xE0153C46B65A324BE3359277E8D0A4C4 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Lenovo ProdName : A319 ProdModel : Lenovo A319 Device : A319 AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : A319_ROW_DS_S318_150615 Done! Elapsed: 00:00:10 Reconnect Power/Cable! |
10-04-2017, 22:09 | #4 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,786 | A319_ROW_DS_S318_150615 Flash with older SPFT (v3.1344.0.212), with "DA DL Checksum", and both checksum checking enabled from Options Drop-Down menu. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
The Following User Says Thank You to Brka For This Useful Post: |
10-05-2017, 08:50 | #5 (permalink) | |
Member: 1246981 Status: Offline Sonork: 100.1590424 Thanks Meter: 316 | Quote:
10-05-2017, 09:08 | #6 (permalink) |
Product Supporter Join Date: Mar 2013 Location: JTAG/eMMC/UFS
Member: 1902789 Status: Offline Thanks Meter: 1,101 | Hello Mr. trenac, Please Do This with CM2MTK ---- HW Test ( Tick Test[FlashIC], Test[RAM], Test[Other] ) & click Make Test.... Then see your eMMC Condition.... When any error or any problem in eMMC Then Final Solution ---- Use any Jtag box, 1. remove eMMC from PCB, 2. connect eMMC in Jtag Box through Adapter, 3. Make Universal Factory Format, 4. write GPT Partition, 5. Now select Scatter file & Write directly in eMMC by Jtag Box, 6. after Flashing complite Replace eMMC ic in PCB, 7. Power on Device Now 100% ur hang on logo problem solve & Device on perfectly... <---< That is my Garantee Last edited by Pijush Das; 10-05-2017 at 09:18. |
10-05-2017, 09:24 | #7 (permalink) |
Member: 1902789 Status: Offline Thanks Meter: 1,101 | Here Is Video Link Micromax D321 Hang On Logo Problem Solved (Normal Flashing Can't Solve This)..... https://www.youtube.com/watch?v=G4lX3ca6H7Q You apply same process for ur Device... Please Like, Share My Videos & Subscribe My Channel |
The Following User Says Thank You to Pijush Das For This Useful Post: |
10-05-2017, 15:57 | #8 (permalink) |
Member: 1246981 Status: Offline Sonork: 100.1590424 Thanks Meter: 316 | here is test result Operation : HW Test [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483447316404050BA23D446285 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A483447316404050BA23D446285 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xE0153C46B65A324BE3359277E8D0A4C4 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Processing Miscellaneous test MSC : BatteryLevel : 3900 mV [Processing] FlashMemory Read-Write test [eMMC] : [HYNIX] , d1G4 , 0xE9000000 , 3728 MiB [eMMC] : CID : 90014A483447316404050BA23D446285 [eMMC] : MODE : SQ-WR [PASSED] : eMMC RW Check #1 Ok! [eMMC] : MODE : RA-WR [PASSED] : eMMC RW Check #2 Ok! [eMMC RO CHECK] : eMMC Ok! READ-WRITE Passed! [Processing] RAM Read-Write test [DRAM] : 0x20000000 , 512 MiB [DRAM] : ADDRESS BUS test [PASSED] : Bus Count : 0x1C [DRAM] : DATA BUS test [PASSED] : Bus Count : 0x1F [DRAM] : PATTERN test [PASSED] : PATTERN Ok [DRAM] : INCDEC test [PASSED] : INCDEC Ok All Done! Done! Elapsed: 00:01:33 Reconnect Power/Cable! |
10-05-2017, 17:02 | #9 (permalink) |
Member: 1902789 Status: Offline Thanks Meter: 1,101 | Your eMMC condition 100% OK... So, try Flash with Latest version SP Flash Tool... 1. Format, 2. Flash & Check Device Condition... When Problem Same, Then I'm sure this Hang on log problem comes from Hardware, So, find fault in Hardware... ...*...THANK YOU...*... |
10-06-2017, 18:30 | #13 (permalink) |
Junior Member Join Date: Jun 2015
Member: 2408050 Status: Offline Thanks Meter: 9 | Not hardware. Its software. I flashed more than 50 a319 and I have 7 firmwares of different version of the same model phone. Maybe you are flashing wrong firmware. Try "ROW DS 313" if "ROW DS 318" didn't work. But before trying other firmware, If you can still see logo then I'd say you have the right preloader. But if your display went black or showing blurry images then you have to change the firmware. Btw you should initialize the preloader once before trying to flashing it again. Try init preloader from the extra tab of cm2 mtk by choosing the preloader bin file of your firmware then flash the firmware again. Don't turn on the phone after flashing. Try to charge it by a usb charger. Plug the charger's usb cable and wait. You should see the battery image and after some time you will see the charging animation with charge percentage. If you can see the animation then you are sure you flashed the right firmware. Turn the phone on while charging and wait 3 to 10 minutes and voila! you will see the welcome screen. But if you see nothing or only the battery logo but no animation for 20/30 seconds after plugging the charger then you must have to flash different firmware. Press thanks if I helped. Sent from my Primo_EF3 using Tapatalk |
The Following 2 Users Say Thank You to cleshera For This Useful Post: |
