02-12-2017, 17:03 | #1 (permalink) |
No Life Poster Join Date: Jan 2009 Location: JESSORE, BNGLADESH. Age: 39
Member: 939797 Status: Offline Sonork: 100.1601089 Thanks Meter: 359 | Need Samsung clone g36h Firmware Wait for phone... Phone found! [ 2 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 1501004E3957524D420189AF88E4A09B Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x10000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMRW9 [eMMC] : FLASH_CID : 1501004E3957524D420189AF88E4A09B [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x0000000070000000 [eMMC] : FLASH_UCP : 1792 MiB [eMMC 2 GiB] DEV RID : 0xB677AC60E464DA4F19A7DE98C92B322A INT RAM : 0x00020000 EXT RAM : 0x10000000 [256 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! |
The Following User Says Thank You to .::MAHABUB::. For This Useful Post: |
02-13-2017, 09:47 | #5 (permalink) |
Member: 939797 Status: Offline Sonork: 100.1601089 Thanks Meter: 359 | bro...PreLoader : NOT Active [ Erased ].this phone is already dead by wrong firmware with others tecnician.so how can Preloader.....Rename ? this is EMMC TEST Processing Miscellaneous test MSC : BatteryLevel : 3899 mV [Processing] FlashMemory Read-Write test [eMMC] : [SAMSUNG] , BMRW9 , 0x70000000 , 1792 MiB [eMMC] : CID : 1501004E3957524D420189AF88E4A09B [eMMC] : MODE : SQ-WR [PASSED] : eMMC RW Check #1 Ok! [eMMC] : MODE : RA-WR [PASSED] : eMMC RW Check #2 Ok! [eMMC RO CHECK] : eMMC Ok! READ-WRITE Passed! [Processing] RAM Read-Write test [DRAM] : 0x10000000 , 256 MiB [DRAM] : ADDRESS BUS test [PASSED] : Bus Count : 0x1B [DRAM] : DATA BUS test [PASSED] : Bus Count : 0x1F [DRAM] : PATTERN test [PASSED] : PATTERN Ok [DRAM] : INCDEC test [PASSED] : INCDEC Ok All Done! Done! Elapsed: 00:01:05 Reconnect Power/Cable! |
02-13-2017, 10:59 | #6 (permalink) |
Member: 939797 Status: Offline Sonork: 100.1601089 Thanks Meter: 359 | i found this preloder and who have this firmware?please share here. preloader_huaqin72_we_iba_lca |
