12-21-2008, 15:26 | #1 (permalink) |
Freak Poster Join Date: Jan 2008
Member: 672823 Status: Offline Thanks Meter: 6 | ef51 cant unlock module v1.31 Device: BenQ EF51 Checking data, wait... Action: unlock Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... 812500 Set Baud Done Check Flash... Check Flash Done Check Parameters... Flash: 001C:00C8001C00C8 file saved: C:\Program Files\InfinityBox\BModule\eeprom-00_20081221-150856.91F.bin Check Parameters Done Check Space... Flash: 001C:00C8001C00C8 flash: Mitsubishi B 8Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Flash: 001C:00C8001C00C8 error: error flash vpp error: error flash vpp try#1 to recover write error at 01780000 error: flash end try#2 to recover write error at 01780000 error: error flash vpp try#3 to recover write error at 01780000 error: flash end try#4 to recover write error at 01780000 |
The Following User Says Thank You to NABIL17 For This Useful Post: |
12-11-2009, 18:44 | #5 (permalink) |
No Life Poster Join Date: Aug 2008 Location: brazil Age: 47
Member: 846805 Status: Offline Sonork: alex cavalcante Thanks Meter: 261 | COM3 [VCP0] selected Mَdulo v1.32 Device: BenQ EF51 Verificando Dados. Aguarde... Açمo: Destravar Boot... O Telefone Deverل Estar DESLIGADO! Pressione o Botمo LIGAR Agora! Connecting... Erro: boot errorcode: 08 Boot Fail Finished, time used: 13 sec Remova/Recoloque a Bateria! |
12-06-2010, 18:58 | #7 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: algeria
Member: 206173 Status: Offline Thanks Meter: 169 | Quote:
Cant unlock Sony-Ericsson-J132 | rajhcl0 | Infinity-Box | 3 | 03-29-2010 18:28 |
a737 cant unlock error cant get cryftkey | dky_tel | Easy-Unlocker | 5 | 03-25-2008 04:15 |
W490 cant unlock cant PDA repair | mishaelwillo | Smart-Clip | 1 | 01-09-2008 08:39 |
V975 cant unlock. cos cant attatch to smart-moto | Softway | Smart-Clip | 12 | 12-21-2005 12:31 |
v70 cant unlock cant change imei | click190 | Motorola P2k | 0 | 06-24-2003 09:50 |
