Old 08-08-2017, 09:15   #1 (permalink)
Member: 599694
Thanks Meter: 76
Redmi 4A(rolex) Pattern Lock - Data needed!
Bootloader locked, TA data zone is encripted! So cm2 cant disabed locks (or read)
I try to flash custom recovery (by memory tool) but after that TA dosent go into recovery (black screen and diagnostic port 900E appears), phone works fine.
Any idea what else can be done?
Old 08-08-2017, 15:46   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Hello.
You need restore original recovery and check device state.
Will check about how device verify boot chain now, but seems as you need find another recovery ( if that one not work ), or those guys had enabled complete check, if device is BL locked.
Old 08-08-2017, 17:08   #3 (permalink)
vasko_bojilov's Avatar
Member: 877235
Sonork: vasilbojilov
Thanks Meter: 199
Data needed
If you need data from phone, read USERDATA partition
then open it and extract necessary info
Old 08-08-2017, 17:15   #4 (permalink)
hitech care's Avatar
Member: 1834832
Thanks Meter: 1,450
As I Know This Will Not Help As Phone Having Encrypted File System.
Old 08-08-2017, 17:44   #5 (permalink)
JayDi's Avatar
Member: 462970
Yes, it encrypted from factory.
Memory Tool will show that in info.
Old 08-09-2017, 09:10   #6 (permalink)
Member: 599694
Thanks Meter: 76
Stock recovery works, any custom (i use 3 different) same thing abowe.
Its mean boot chain check and thats the final point of our journey?))
P.S. recovery is also marked as encrypted, this is mean something?
Old 08-09-2017, 10:08   #7 (permalink)
JayDi's Avatar
Member: 462970
State for FILESYSTEM types only can be ENCRYPTED, in rest case it BINARY/DATA.
Old 08-12-2017, 01:22   #8 (permalink)
Member: 1793689
U have umt ten put the sladi load connect pc with usb factory reset done
Sent from my A1601 using Tapatalk
Old 08-12-2017, 08:20   #9 (permalink)
Member: 599694
Thanks Meter: 76
Mister english please!
Page generated in 0.14301 seconds with 8 queries
