Need Unlcok For Huwei T 128 hello infinity team when will we get un lock for t128 .we are waiting for a long time.please anounce this update.thankkkkkkkksssssss |
Hello, Our programmes working about it. |
and huawei u121 unlock solution pls? |
hello! u121 is not supported yet, we will see what we can do about this model |
guddu electronics hi infinity team huawei t128 please add fof thank,ssssss |
Hello, Our programmes working about it. Thread closed due to there is no reason to ask the same questions and write the same answers many times. |
huawei t128 unlocked succesfu;;y by infinty heres the log COM11 [VCP0] selected Device: Huawei-T128 Checking data, wait... Action: unlock direct unlock Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:22C4 Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T128_eeprom-sta_20080830-112259.B1E.bin loading data... wrong database file: C:\Program Files\InfinityBox\Pana01\T128_eep65535.cfg error: can't load database v.1106 reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T128_eeprom-sec_20080830-112302.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T128_eeprom-complete_20080830-112318.B1E.bin backup critical area Done Check memory... Check memory Done Write... Erasing: eeprom-complete Writing: eeprom-complete Write Done Finished, Remove/Install battery now ! Time used: 46 sec thx to infintybox |
chack this http:///vbb/showthread.php?t=519319 |
@VIJEESHNK Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
