08-29-2015, 13:51 | #1 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,827 | Access Violation At Address 0055178D In Module 'CM2MTK.exe'. Read Of Address 00000008 When I Click/Checked Only "Read Phone Info", It's Read Info Ok!. Operation : Check / Read Info [ v1.26 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004B3558564D4201A498CA8AC0A3 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMVX5 [eMMC] : FLASH_CID : 1501004B3558564D4201A498CA8AC0A3 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : TITANIUM ProdName : Karbonn Titanium S4 Plus ProdModel : Karbonn Titanium S4 Plus Device : jxd_p2000l_w AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : UTLTS4PLUSv1005 Done! Elapsed: 00:00:11 Reconnect Power/Cable! When Click/Checked "Read Info" & "Read Extended Info" It's Show This Error. Operation : Check / Read Info [ v1.26 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004B3558564D4201A498CA8AC0A3 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMVX5 [eMMC] : FLASH_CID : 1501004B3558564D4201A498CA8AC0A3 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : TITANIUM ProdName : Karbonn Titanium S4 Plus ProdModel : Karbonn Titanium S4 Plus Device : jxd_p2000l_w AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : UTLTS4PLUSv1005 MODEM : BaseBand : MT6582_S00_MOLY_WR8_W1315_MD_WG_MP_V34_1_wg_n Access Violation At Address 0055178D In Module 'CM2MTK.exe'. Read Of Address 00000008. |
08-29-2015, 14:49 | #3 (permalink) | |
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,827 | Quote:
Here It's Karbonn Titanium S4Plus Firmware : DOWNLOAD Credit Goes To The Original Uploader. | |
