01-13-2008, 12:12 | #1 (permalink) |
Freak Poster Join Date: Sep 2006 Location: Georgia
Member: 342909 Status: Offline Thanks Meter: 6 | nokia tp012 pinout need 12345 78910 gnd is 5 .I tried rx 7 tx 8 but no succes...please help me |
01-13-2008, 16:15 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | I have repeated easy explanation at least 100 (one hundred) times already: you must open phone and see CPU chip name. If CPU chip name is like MT62xx then this phone is supported ! Another instruction was repeated in this forum at least 1000 (one thousand) times: Currently many "Chinese" models with the same name but absolutely different hardware exist on market, f.e. exist at least 20 phones with name "Chinese Nokia-N95" but with different bottom connectors and different pinouts, so we recommend you to include the next information in your question regarding pinout: 1. detailed description of model: brand name, model name, complete text from phone back label, any other marks that you can find on phone cover 2. phone CPU chip name 3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB) 4. attach phone photo 5. attach phone bottom connector photo 6. include information about Gnd and Charge pins on phone bottom connector After you have this information prepared, you can find pinout by yourself more easy than before, just check the next detailed description how to get pinout for your model: 1. use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 2. if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\ 3. if not helps, please read: http:///vbb/showpo...36&postcount=7 4. if not helps, please read: http:///vbb/showthread.php?t=433447 |
Nokia N22 pinout needed? | dogeatdog | Infinity-Box | 8 | 09-06-2008 21:01 |
nokia n91 and nokia v300i pinout needed | GOODNESS | Infinity-Box | 1 | 04-29-2008 21:26 |
Nokia N73 pinouts needed | astana2007 | Infinity-Box | 1 | 03-04-2008 19:22 |
Nokia N66 pinout need urgent | sadaf2706 | Various | 1 | 02-01-2008 01:44 |
CHINESE NOKIA N78s PINOUT NEEDED | maplegsm | Infinity-Box | 1 | 09-04-2007 13:45 |
