01-27-2016, 11:00 | #1 (permalink) |
No Life Poster Join Date: May 2011 Location: KPK Mardan Age: 36
Member: 1582572 Status: Offline Sonork: 100.1609641 Thanks Meter: 573 | Need WIKO Firmware s5201ap Phone found! [ 17 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473261110150F972B772FF DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A4834473261110150F972B772FF [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : WIKO ProdName : s5201ap ProdModel : LENNY Device : s5201ap AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP7.V1 MODEM : BaseBand : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V43_1_wg_n EXTRA : LCD [0] : ili9806e_fwvga_dsi_vdo_txd LCD [1] : hx8379c_fwvga_dsi_vdo_tcl LCD [2] : ili9806e_fwvga_dsi_vdo_dj LCD [3] : ili9806e_fwvga_dsi_vdo_glass LCD [4] : ili9806e_fwvga_dsi_vdo_djnew LCD Res : 854x480 TOUCH [0] : GT9XX CAM [0] : ov5645_mipi_yuv CAM [1] : ov5646_mipi_yuv CAM [2] : sp0a19_yuv CAM [3] : gc0329_yuv CAM [4] : hi258_mipi_yuv MODEM : mt6572_s5201ae_wiko_hspa_gemini LOCALE : en_US es_ES zh_CN zh_TW ru_RU pt_BR fr_FR de_DE tr_TR it_IT in_ID ms_MY vi_VN ar_EG th_TH pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ iw_IL my_MM km_KH ko_KR pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB ur_PK fa_IR hdpi -sw600dp -sw720dp Done! Elapsed: 00:00:21 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to Shani3 For This Useful Post: |
01-29-2016, 11:55 | #3 (permalink) |
Member: 1582572 Status: Offline Sonork: 100.1609641 Thanks Meter: 573 | After flash dead and now the system is not detecting |
The Following 2 Users Say Thank You to Shani3 For This Useful Post: |
01-29-2016, 12:25 | #4 (permalink) |
No Life Poster Join Date: Dec 2015 Location: hossting
Member: 2501288 Status: Offline Thanks Meter: 328 | Pleas post wich firmware exactly use and operations logs Note: Mtk not possible to be full dead just try different firmware , and full charge battery Regards |
The Following 2 Users Say Thank You to Steve-1 For This Useful Post: |
01-29-2016, 14:11 | #5 (permalink) |
Freak Poster Join Date: Apr 2015
Member: 2379235 Status: Offline Thanks Meter: 38 | same happened with me..short kcolo with gnd..then flash with correct file..i hav MT6572__WIKO__LENNY__s5201ap__4.4.2__ALPS.KK1.MP7. V1 backup but my net speed is slow so cant upload |
The Following 2 Users Say Thank You to gsmfileservers For This Useful Post: |
01-29-2016, 14:18 | #6 (permalink) |
No Life Poster Join Date: Apr 2014 Location: Charsadda kpk Age: 41
Member: 2166444 Status: Offline Thanks Meter: 298 | MT6572__WIKO__LENNY__s5201ap__4.4.2__ALPS.KK1.MP7. V1 Wait for phone... Phone found! [ 8 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164040500A23138C1AD DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164040500A23138C1AD [eMMC] : FLASH_EXT : 00400000/00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : WIKO ProdName : s5201ap ProdModel : LENNY Device : s5201ap AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP7.V1 MODEM : BaseBand : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V43_1_wg_n EXTRA : LCD [0] : ili9806e_fwvga_dsi_vdo_txd LCD [1] : hx8379c_fwvga_dsi_vdo_tcl LCD [2] : ili9806e_fwvga_dsi_vdo_dj LCD [3] : ili9806e_fwvga_dsi_vdo_glass LCD [4] : ili9806e_fwvga_dsi_vdo_djnew LCD Res : 854x480 TOUCH [0] : GT9XX CAM [0] : ov5645_mipi_yuv CAM [1] : ov5646_mipi_yuv CAM [2] : sp0a19_yuv CAM [3] : gc0329_yuv CAM [4] : hi258_mipi_yuv MODEM : mt6572_s5201ae_wiko_hspa_gemini LOCALE : en_US es_ES zh_CN zh_TW ru_RU pt_BR fr_FR de_DE tr_TR it_IT in_ID ms_MY vi_VN ar_EG th_TH pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ iw_IL my_MM km_KH ko_KR pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB ur_PK fa_IR hdpi -sw600dp -sw720dp Done! |
The Following 2 Users Say Thank You to GSM KPK For This Useful Post: |
01-20-2017, 21:05 | #10 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,778 | If i see well on that picture, kcol0 is hard wired to Volume UP (or volume down) key. Holding it and inserting cable should give "MTK USB Port" (emergency/forced download port) (As is done on 99% MTK phones). b.r Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
The Following 3 Users Say Thank You to Brka For This Useful Post: |
07-03-2018, 03:34 | #14 (permalink) |
The Following User Says Thank You to Brka For This Useful Post: |
