11-29-2017, 07:02 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: philippines Age: 42
Member: 388962 Status: Offline Sonork: 100.1637202 Thanks Meter: 264 | new cm2 dongle not working my pc is windows 10 64 bit i plug dongle on usb, let windows install drivers. the dongle is blinking blue and red non stop. dongle manager cannot detect it. : === DongleManager [Infinity] v1.70 [11/29/2017 14:01:30] === Searching... Dongle can't be found: Card with specified AID is not found i tried manual update CardReader_Fetian_FT2K drivers but still dongle manager cannot detect it. i remove smartcard clean and then plug it again. but still no luck. what could be the problem? |
11-29-2017, 07:15 | #3 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,421 | Hello, -Download drivers from here Index of pub/drivers/ -Remove smartcard put in other dongle. Results ? |
11-29-2017, 08:22 | #4 (permalink) |
Member: 388962 Status: Offline Sonork: 100.1637202 Thanks Meter: 264 | cannot put in another smartcard. i dont have other dongle. done drivers download from support. still not working |
The Following User Says Thank You to eivelice For This Useful Post: |
11-29-2017, 11:30 | #7 (permalink) | |
Member: 388962 Status: Offline Sonork: 100.1637202 Thanks Meter: 264 | here is another error Quote:
11-29-2017, 11:51 | #11 (permalink) |
Freak Poster Join Date: May 2003 Location: Poland Age: 46
Member: 27843 Status: Offline Sonork: 100.1646294 Thanks Meter: 26 | no driver card. but cm2mtk work, qlm not work, delete folder reinstal work 1 time ;/ |
The Following User Says Thank You to gsmline For This Useful Post: |
11-29-2017, 14:18 | #12 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | This means Card-Reader drivers not installed well. 1. go here https://www.infinity-box.com/support/?s=2 2. download and run USB device viewer 3. write here your card-reader VID/PID |
11-29-2017, 14:43 | #13 (permalink) |
Junior Member Join Date: May 2015
Member: 2395262 Status: Offline Thanks Meter: 1 | Dongle update problem plz help.... === DongleManager [Infinity] v1.70 [29-Nov-17 18:39:56] === Box/Dongle type selected: [BEST] Card-Reader: FT SCR2000 0 HWID: 0005978118201292 === Process started: 29-Nov-17 18:39:56 === Connecting to server... Server connection successfully established Checking upgrade client version... Your upgrade client is up-to-date Checking Box/Dongle Identification... Authenticating on server... Authentication stage error: Server reported error: [0010] Not translated! |
The Following User Says Thank You to NasirMobiles For This Useful Post: |
11-29-2017, 15:43 | #14 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
What to do: 1. Install required Card-Reader Drivers: - File with Drivers: CardReader_Fetian_FT2K.7z - File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 Download files - http://www.infinity-box.com/support/?r=6 OR 1. Insert Smart-Card into another Card-Reader (good result for today is with Alcor Card-Reader) The next steps are: 2. Run DongleManager 3. Update Dongle firmware - DO NOT update Smart-Card many times otherwise your account will be locked automatically after 3 tries for 24 hours - DO NOT use any kind of usb sharing/trace/spy/debug software to avoid problem with Dongle ! | |
11-30-2017, 04:11 | #15 (permalink) | ||
Member: 388962 Status: Offline Sonork: 100.1637202 Thanks Meter: 264 | this is from device manager Quote:
