Old 11-01-2009, 12:06   #1 (permalink)
Member: 891237
Sonork: baba
Thanks Meter: 14
pl pl pl help
i have problem zetel n82y model china its dead i full format with infinity
COM4 [VCP0] selected
module v2.84
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: "format ffs"
ffs/eeprom backup enabled, it may takes several minutes !
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:C103:000C
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 2088C4BFFFBFFF:2088C400000000
flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
115200
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
unknown structure: 00
unknown identification#1 structure: 00
unknown firmware, read flash and send to support: [email protected]
detect device identification#2...
detect device identification#2 finished
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset assigned: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
Can't detect ffs/eeprom area
Do you want to use standard ffs/eeprom address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs/eeprom address selected by user
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
reading: _ffs...
i take gernl infomation and the frimwere is
_ffs_20091029-072739.B0E.bin
and eprom is
cfi_0020_88C4_FFFF_FFFF.bin
and i i take correct frimwere and eprom from same type set
GEMINI_PCB01_GPRS_MT6225_S00.L_2217B_V2_2_33__full flash_20091029-070957.B0M.bin
GEMINI_PCB01_GPRS_MT6225_S00.L_2217B_V2_2_33__ffs_ 20091029-071527.B0E.bin
i complete flesh but result is same i full format and unlock after full flesh
but problem is same
after flesh full format result is
module v2.84
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
Boot Done
Initialize ...
Initialize Done
Set baud ...
115200
Set baud Done
ffs/eeprom chip: 00
reading: _ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\_ffs_20091030-233048.B0E.bin
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
Write Done
Finalization ...
formatting...
Finalization Done
Finished, time used: 461 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
pl halp what can i do i have only infinity for chaina mobile
pl pl pl pl pl pl help
Old 11-01-2009, 16:55   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
here we clearly see that this phone has damaged flash IC.
try to heat it or resolder.
flash again.
if will not help- flash IC must be changed
cyclon team pl pkl pl sms_sudheer Cyclonebox 1 02-24-2010 09:55
1661 v.3.70 unlock pl cyclone teem help [Not Supported] sms_sudheer Cyclonebox 2 02-15-2010 09:02
PL...........................z anyone help me p.hotguy24 Nokia Multimedia 0 11-24-2007 15:22
pl help lg 275 lock problem pl help me ruvanw1979 Infinity-Box 3 11-06-2007 13:12
Page generated in 0.16406 seconds with 10 queries
