12-19-2009, 21:48 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: NYC
Member: 416710 Status: Offline Thanks Meter: 391 | A8+ dead after format.. COM5 [VCP0] selected module v2.92 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:9FF6:5B85 status: FF high speed boot Off boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #02 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #03 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 921600 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device rom info... detection phase #1... detect device rom info finished rom info structure: 2nd [enhanced] generation startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.D8862042.[SIMC26_06B_PCB01_GPRS_MT6226_S01.A8P-MUL_G60MPV01_01B03.BIN_36CF8AEF].rpl rom info detection finished device-id: D8862042 rom info protocol ver: 04 ver. sw 1: SIMC26_06B_PCB01_GPRS_MT6226_S01.A8P-MUL_G60MPV01_01B03.BIN ver. sw 2: A8P-MUL_G60MPv01.01b03, 107530C9 ffs offset/size: 00E00000/00200000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 98004900000002:2AEA0000000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 008E0000 Detected ffs/eeprom address is non-standard: 008E0000 Posible reasons: 1. ffs/eeprom is Ok but address is non-standard 2. ffs/eeprom is damaged and can't be detected 3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make full flash backup for emergency case 3. repeat required operation Are you sure that detected ffs/eeprom address is correct ? Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make full flash backup for emergency case 3. repeat required operation operation terminated by user file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\_ system_log_D8862042_36CF8AEF_20091219-144345.B0X.bin Finished, time used: 168 sec Remove/Install battery now ! Repair security log ==== log: [12/19/2009 3:54:27 PM] ==== COM5 [VCP0] selected module v2.92 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: repair security area Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:9FF6:5B85 status: FF high speed boot Off boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #02 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #03 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 921600 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device rom info... detection phase #1... detect device rom info finished rom info structure: 2nd [enhanced] generation startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.D8862042.[SIMC26_06B_PCB01_GPRS_MT6226_S01.A8P-MUL_G60MPV01_01B03.BIN_36CF8AEF].rpl rom info detection finished device-id: D8862042 rom info protocol ver: 04 ver. sw 1: SIMC26_06B_PCB01_GPRS_MT6226_S01.A8P-MUL_G60MPV01_01B03.BIN ver. sw 2: A8P-MUL_G60MPv01.01b03, 107530C9 ffs offset/size: 00E00000/00200000 detecting startup code area #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... startup code area #2 is absent detect device sec info... . detect device sec info finished startup code area #1 check... startup code area #1 fixed detect device sec info... . detect device sec info finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 98004900000002:2AEA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\S IMC26_06B_PCB01_GPRS_MT6226_S01.A8P-MUL_G60MPV01_01B03__system_log_D8862042_36CF8AEF_2 0091219-155813.B0X.bin Finished, time used: 224 sec Remove/Install battery now ! |
12-20-2009, 11:57 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! flash your phone with one of 3 available on support flash files flashfiles/ChineseMiracle/_MT6226/SIMC26_06B_PCB01_GPRS_MT6226_S01.A8P-MUL_G60MPV01_01B03_16m_En_Ru_Fr_Th_Farsi_Cn_Ar.B0M .bin flashfiles/ChineseMiracle/_MT6226/SIMC26_06B_PCB01_GPRS_MT6226_S01.A8P-MUL_G60MPV01_01B03__iPhone-A8+_16m_En_Ru_Fr_Th_Farsi_Cn_Ar.B0M.bin flashfiles/ChineseMiracle/_MT6226/SIMC26_06B_PCB01_GPRS_MT6226_S01.A8P-MUL_G60MPV01_01B03__iphone_a38_16m_En_Ru_Fr_Th_Far si_Cn_Ar.B0M.bin start from iPhone-A8+ file |
12-21-2009, 14:00 | #3 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: P@kIsTaN
Member: 327384 Status: Offline Sonork: 100.1605419 Thanks Meter: 312 | Quote:
Hello Bro write backup eeprom file & post here results......... | |
Nokia china N73 dead after format | ahmedasmet | Infinity-Box | 10 | 12-05-2007 01:17 |
KG 300 dead after Format FFS ...... | .::BHATTI::. | Infinity-Box | 4 | 11-19-2007 09:45 |
Nokia 6300 Dead after formating | Ramzan | Infinity-Box | 4 | 10-01-2007 17:21 |
lg c2500 dead after formatting fss | gsmgold | Infinity-Box | 2 | 05-06-2007 06:58 |
