new sony-ericson t303 unlocking succesfull in infinity module v1.32 Device: Sony-Ericsson-T303 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 89890400040089:89890400000000 flash: Intel ST [def 0080x040000] 32Mb software version: 1209-8242 software version: R2CA005 Check hardware done Read data ... reading Sony-Ericsson-T303_eeprom_calibration-1... file saved: C:\Documents and Settings\aaa\Desktop\Sony-Ericsson-T303_eeprom_calibration-1_20090226-233732.80E.bin Read data done Check data ... Check data done Write ... ........................... flash: 89890400040089:89890400000000 Write: simlock Write done Finished, time used: 256 sec Remove/Install battery now ! |
Br Kmax |
Model- new but MCU old With new MCU Bid problem : COM15 [VCP0] selected module v1.32 Device: Sony-Ericsson-T303i "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot fail error: operation failed Finished, time used: 49 sec Remove/Install battery now ! |
2 check cable if still same 3 its new cpu not supported at the moment |
yes new cpu of sonyercisson t303 t280 etc not supported yet |
This is log se t303 unlocking by infinity.thanks |
This is log se t303 unlocking by infinity.thanks COM6 [VCP1] selected module v1.30 Device: Sony-Ericsson-T303 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot fail error: operation failed Finished, time used: 49 sec Remove/Install battery now ! |
Br Kmax |
Pressing the power faster, the power is poor communication. just try and you will find that sometimes it is not the version of the phone, only power. the infinity should improve the communication does not leave much for that mistake. |
Thank you very much for your advice ! I'll ask programmers to check initial boot procedure and make messages in log window visible better that before. |
when new ver will be sppurted in infinity? |
waiting log.. of Imei repair... please.. |
Hello, Our programmers is working about solution. |
thnx nd regards Kmax |
