06-09-2021, 08:08 | #1 (permalink) |
Crazy Poster Join Date: Oct 2019 Location: West Africa
Member: 2932917 Status: Offline Thanks Meter: 2 | Meizu m8 format error. Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM9) MODE : BOOTROM PORT : 9 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : D2F45C7A013622621B205F3206647488 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Meizu : M8 | Manual : Disabled BROM : SOCID : 3C3E636773820198E996BDD60A0ECBBF28F3AF03AA7D9EE493 1370231C0177CB BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Look for cookies BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_k91813aa1.bin EMI : CNT : 0002 EMI : Init EMI from INTERNAL DB DA : SETUP EMI PARAMS FAILED! ERROR : ABORT Error : Fail to init protocol! >>> Internal EMI : Select other EMI number! External Preloader - make sure it correct for connected device! Reconnect Power/Cable! Operation : Identify [ v2.24 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM9) MODE : BOOTROM PORT : 9 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : D2F45C7A013622621B205F3206647488 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Meizu : M8 | Manual : Disabled BROM : SOCID : 3C3E636773820198E996BDD60A0ECBBF28F3AF03AA7D9EE493 1370231C0177CB BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_k91813aa1.bin EMI : CNT : 0002 EMI : Init EMI from INTERNAL DB DA : SETUP EMI PARAMS FAILED! ERROR : ABORT Error : Fail to init protocol! >>> Internal EMI : Select other EMI number! External Preloader - make sure it correct for connected device! Reconnect Power/Cable! |
06-09-2021, 15:05 | #3 (permalink) |
Member: 2932917 Status: Offline Thanks Meter: 2 | Card found : 935BDA93 , v0149 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.24 Load IDBase v524190 Ok! UserName and/or Password not set! Can't continue! Update failed! Check settings and/or internet connection! Operation : Reset Settings/Format FS [ v2.24 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM9) MODE : BOOTROM PORT : 9 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : D2F45C7A013622621B205F3206647488 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Meizu : M8 | Manual : Disabled BROM : SOCID : 3C3E636773820198E996BDD60A0ECBBF28F3AF03AA7D9EE493 1370231C0177CB BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! DA : EMI : Failed to get EMI info from selected source! Boot done! Done! Elapsed: 00:02:11 Reconnect Power/Cable! |
06-10-2021, 09:32 | #5 (permalink) |
No Life Poster Join Date: Oct 2017 Location: on google.com
Member: 2771307 Status: Offline Thanks Meter: 772 | Today will be a new update check after see it should be fixed. But if want work new models should have the correct username and pass in software because you got old phone database in software Load IDBase v524190 Ok! UserName and/or Password not set! Can't continue! Update failed! Check settings and/or internet connection! New one is Update configuration ... Update Ok! Load IDBase v67213 Ok! Without a correct username and password, you lost lots of new models added on the server-side every day and updated every start of cm2mt2 software. Last edited by IMEI_info; 06-10-2021 at 09:41. |
