Old 06-30-2020, 14:44   #16 (permalink)
Member: 1677653
Thanks Meter: 2,769
Originally Posted by mhammadleo View Post
how to get preloader mode ?
Go 2ru this thread and check post #2 maybe it will help you.
Old 06-30-2020, 21:06   #17 (permalink)
Member: 1169259
Sonork: 100.1648194
Thanks Meter: 149
Originally Posted by JayDi View Post
Since here may appears some questions :
We divide phones by chipset and basic security structure, not by specified vendors/brands/models.
That may bring some misunderstand, because xiaomi used compicated security system.
Yes, it is. Exactly that device have unlocked bootloader.
after that enough reflash engeniring rom or special package ( both uploading on support area under "begonia" or "Redmi Note 8 Pro")
After you can always had access to device for playing.
Not flash preloader files from official packages to avoid get brick/loose that ability!!!!
you mean flash preloader eng and when flash normal firmware skip preloader file ?
Old 10-31-2020, 10:43   #18 (permalink)
malka4u's Avatar
Member: 1626780
Thanks Meter: 1,275
No firmware found under name
Old 11-19-2020, 17:29   #19 (permalink)
Member: 2119579
Thanks Meter: 44
Thanks for your efforts, I have question that: can I flash Redmi Note 8 Pro with device bootloader locked using the new version of CM2MT2?
With official fastboot package from Xiaomi website and latest version of MIUI 12 (flash official files from official website)
Old 11-20-2020, 05:04   #20 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
You can flash official ROM's, but since factory preloader not allow enter to flash mode, only brom, you get troubles at first step - device will require use bootrom mode and xiaomi auth server.
The Following User Says Thank You to JayDi For This Useful Post:
Old 11-20-2020, 05:18   #21 (permalink)
Abzal's Avatar
Member: 19032
Thanks Meter: 158
Hello
Can flash Huawei Y6s?
Old 11-20-2020, 06:24   #22 (permalink)
Abzal's Avatar
Member: 19032
Thanks Meter: 158
Try connect, but error:
Card found :  , v0145
Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.16
Load IDBase v99153 Ok!
Update configuration ...
Update Ok!
Load IDBase v1118158 Ok!
Operation : Identify [ v2.16 ]
Mode : FLASH
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port (COM5)
MODE : BOOTROM
PORT : 5
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
     CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
     CODE : Cervino
     TYPE : MODERN RAPHAEL
BROM : MEID : C040D111601290708C56BBC2CA0685A0
BROM : SecLevel : 0x000000E5
BROM : SecMode  : SBC+SDA+EXT
BROM : BROM|BL  : 0x05|0xFE
BROM : BOOTROM
MODE : Huawei : 8A_JAT-XXX | Manual : Disabled
BROM : SOCID : E340D8FA44C628D6216C10EE1592197CF18E57DCBDD620E008AC289645561133
BROM : ARB : ACTIVE : LOG : F0: 102B 0000  F3: 0000 0000 [0200]  V0: 0000 0000 [0001]
BROM : SLA
BROM : SLA Passed!
BROM : SLA CHLNG not used
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6765
AGENT : MTK_DOWNLOAD_AGENT
     BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
     DA : AGENT started!
DA : SYNC with DA FAILED!
Error : Fail to init protocol!
>>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation!
Reconnect Power/Cable!
Old 11-20-2020, 14:15   #23 (permalink)
Member: 2119579
Thanks Meter: 44
Thanks again for feedback, the question is if I have dead Redmi Note 8 Pro (boot-loader locked), can I still flash it with CM2MT2?
測定を破る
Old 11-20-2020, 16:27   #24 (permalink)
Member: 1677653
Thanks Meter: 2,769
Update Ok!
Mode : FLASH
MODE : BOOTROM
PORT : 5
BROM : Init BROM
BROM init passed!
     CODE : Cervino
BROM : BOOTROM
BROM : SLA
BROM : SLA Passed!
BROM : DA sent
     DA : AGENT started!
connection required PRELOADER MODE
Old 11-20-2020, 17:43   #25 (permalink)
JayDi's Avatar
Member: 462970
Update Ok!
Mode : FLASH
MODE : BOOTROM
PORT : 5
BROM : Init BROM
BROM init passed!
     CODE : Cervino
BROM : BOOTROM
BROM : SLA
BROM : SLA Passed!
BROM : DA sent
     DA : AGENT started!
Make sure about you NOT hold TP long, when device connect in windows - release it at same time.
Old 11-20-2020, 17:44   #26 (permalink)
JayDi's Avatar
Member: 462970
測定を破る
Only if you have Xiaomi Auth account. We can enable that feature using in our modules.
Old 11-21-2020, 04:37   #27 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,514
great
its credit based ? or standalone sir ?
Old 11-21-2020, 04:43   #28 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,514
wow that's great news
its with credits or server based sir ?
Old 11-21-2020, 05:56   #29 (permalink)
Abzal's Avatar
Member: 19032
Thanks Meter: 158
For connect this phone need open phone and use TP?
Have FW for flash it via CM?
Old 11-21-2020, 08:46   #30 (permalink)
JayDi's Avatar
Member: 462970
If it connect without TP - most probably it already damaged by some way. Check device first at overall look inside.
Page generated in 0.25653 seconds with 9 queries
