06-19-2018, 05:54 | #1 (permalink) |
Freak Poster Join Date: Oct 2007 Location: Ново&#
Member: 599694 Status: Offline Thanks Meter: 76 | New Xiaomi Security OP - doesn't work! Wipe Security Partitions Erase : FSG Erase : MODEMST1 Erase : MODEMST2 Done! Elapsed: 00:00:45 And it doesn't affect at all - imei on board! On some firmware\model imei become 0, but writing QCN doesn't help (no imei/or no network) - comming back to life only after rewrite original security backup. Xiaomi pached security? |
06-19-2018, 06:31 | #2 (permalink) | |
Product Supporter Join Date: Jun 2014 Location: India
Member: 2211790 Status: Offline Thanks Meter: 5,118 | Quote:
06-19-2018, 09:54 | #3 (permalink) |
No Life Poster Join Date: Jan 2013 Location: gsmhosting Age: 29
Member: 1876736 Status: Offline Thanks Meter: 735 | do this steps read qcn read security reset security factory reset frp menu (phone) repair imei reboot phone write back up qcn factory reset from menu tested and work |
06-19-2018, 10:02 | #4 (permalink) |
Member: 1876736 Status: Offline Thanks Meter: 735 | here steps read qcn Code: Operation : Read QCN (NVM) [ v1.16 ] 1. Enable DiagInterface on device [ by Code, Root or other way ] 2. Make sure DiagDrivers installed and work correct Wait for phone... Device Found! Initialize ... DiagMode initialized! MSMHW : 000005F1 MODHW : 00001010 BUILD : MPSS.TH.2.0.c1.9-00078-M8996FAAAANAZM-1.76210.1.79676.1.80359.1.80172.1.80630.3 RTIME : Dec 27 201618:11:25 BTIME : Dec 02 201614:00:00 DEVST : 8996.gen Reading NVRAM data in XQCN format ... Reading NV Items... Reading NV Items SIM1... Reading NV Items SIM2... Reading RFNV... Reading Provisioning Item Files... Reading Feature_Mask... Saved as : F:\InfinityBox\CM2QLM\Backup\QCN\000005F1__MPSS.TH.2.0.c1.9-00078-M8996FAAAANAZM-1.76210.1.79676.1.80359.1.80172.1.80630.3.xqcn Read Done! Code: Operation : EDL Security Operation [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 821 [MSM8996 Pro] ID_BLOCK_S : B4DB6A24 ID_BLOCK_L : 582F2D946093D8D24E20B37BBEB547B5 ID_BLOCK_L : 116DDAB770C72593D3426D07FEAFA15C Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8996 , FLASH : UFS , mVER : 1 ExtInfo : 0x0001C000/0001C000/00001000/00001000/00001000 UFS Device : TOSHIBA THGLF2G9J8LBATRH0101 UFS SectSize : 0x1000 UFS Size : 0x0000000EE6800000 : 59.60 GiB --------------UFS Device Info-------------- INFO: {'storage_info': {'total_blocks':14448640, 'block_size':4096, 'page_size':4096, 'num_physical':6, 'manufacturer_id':408, 'serial_num':1212760641, 'fw_version':'101','mem_type':'UFS','prod_name':'THGLF2G9J8LBATRH0101'}} UFS Total Active LU: 0x6 UFS wManufacturerID: 0x198 UFS Boot Partition Enabled: 0x1 UFS LU Write Protect: 0x0 UFS Boot LUN ID: = 0x0 UFS Memory Type: 0x0 UFS LU Total Blocks: 0x0 UFS Supported Memory Types: 0x801f UFS LUN Enable Bitmask: 0x3f UFS bConfigDescrLock: 0x0 Boot Ok! Backup Security Partitions Backup : FSG Backup : MODEMST1 Backup : MODEMST2 Backup saved to : F:\InfinityBox\CM2QLM\Backup\MSM8996_[0005F0E1]_B4DB6A24_SEC\ Code: Operation : EDL Security Operation [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 821 [MSM8996 Pro] ID_BLOCK_S : B4DB6A24 ID_BLOCK_L : 582F2D946093D8D24E20B37BBEB547B5 ID_BLOCK_L : 116DDAB770C72593D3426D07FEAFA15C Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8996 , FLASH : UFS , mVER : 1 ExtInfo : 0x0001C000/0001C000/00001000/00001000/00001000 UFS Device : TOSHIBA THGLF2G9J8LBATRH0101 UFS SectSize : 0x1000 UFS Size : 0x0000000EE6800000 : 59.60 GiB --------------UFS Device Info-------------- INFO: {'storage_info': {'total_blocks':14448640, 'block_size':4096, 'page_size':4096, 'num_physical':6, 'manufacturer_id':408, 'serial_num':1212760641, 'fw_version':'101','mem_type':'UFS','prod_name':'THGLF2G9J8LBATRH0101'}} UFS Total Active LU: 0x6 UFS wManufacturerID: 0x198 UFS Boot Partition Enabled: 0x1 UFS LU Write Protect: 0x0 UFS Boot LUN ID: = 0x0 UFS Memory Type: 0x0 UFS LU Total Blocks: 0x0 UFS Supported Memory Types: 0x801f UFS LUN Enable Bitmask: 0x3f UFS bConfigDescrLock: 0x0 Boot Ok! Wipe Security Partitions Erase : FSG Erase : MODEMST1 Erase : MODEMST2 Done! Elapsed: 00:00:22 Reconnect Power/Cable! Code: Operation : Write Security [ v1.16 ] 1. Enable DiagInterface on device [ by Code, Root or other way ] 2. Make sure DiagDrivers installed and work correct Wait for phone... Device Found! Initialize ... DiagMode initialized! MSMHW : 000005F1 MODHW : 00001010 BUILD : MPSS.TH.2.0.c1.9-00078-M8996FAAAANAZM-1.76210.1.79676.1.80359.1.80172.1.80630.3 RTIME : Dec 27 201618:11:25 BTIME : Dec 02 201614:00:00 DEVST : 8996.gen Update IMEI[1] : xxxxxxxxxx Record update Ok! Update IMEI[2] : xxxxxxxxxx Record update Ok! Write done! Reboot device, if it not restart! Hint : QCN write and Factory Reset is required to finish process completely! Code: Operation : Write QCN (NVM) [ v1.16 ] 1. Enable DiagInterface on device [ by Code, Root or other way ] 2. Make sure DiagDrivers installed and work correct Wait for phone... Device Found! Initialize ... DiagMode initialized! MSMHW : 000005F1 MODHW : 00001010 BUILD : MPSS.TH.2.0.c1.9-00078-M8996FAAAANAZM-1.76210.1.79676.1.80359.1.80172.1.80630.3 RTIME : Dec 27 201618:11:25 BTIME : Dec 02 201614:00:00 DEVST : 8996.gen xQCN details : IMEI [1] : 863818035601583 IMEI [2] : 863818035601583 BTID : 9FB7D2F80278 WiFi : 7802F8F2B79F Writing NVRAM data from XQCN image ... Writing NV Items... Writing SIM1 NV Items... Writing SIM2 NV Items... Writing RFNV... Writing Provisioning Item Files... Write done! Reboot device, if it not restart! Hint : Factory Reset is required to finish process completely! this steps are important read qcn read security reset security factory reset frp menu (phone) repair imei reboot phone write back up qcn factory reset from menu if you did not do one of this rewrite original security and do steps from begining |
