Old 10-12-2009, 19:23   #1 (permalink)
shahzadthe1's Avatar
Member: 541117
Sonork: .::100.1586906::.
Thanks Meter: 173
Nk 2008 dead after Full Format ???????
set Condition was= insert sim
i format with whole flash method
after that set is not powering on
then i download flash file from support and flash but no luck...phone still dead
here is format and flash log..................
format log...
COM13 [VCP0] selected
module v2.82
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: erase flash chip
ffs/eeprom backup enabled, it may takes several minutes !
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:2703:0006
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 98000300000001:18E59F00000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
115200
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area (code #1) is Ok
security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.D755B224.[N96_ABROAD_PCB01_GPRS_MT6225_S00.N96_ABROAD_SPANS_ S5LCD_V2_3_6.BIN_1FE27974].rpl
New firmware detected (v.2.82, database date: unknown):
This firmware is missing in support area. If this phone is good and working:
- make "Read full flash" operation
- send "system_log_..." file to support: [email protected]
- send flash backup files to support: [email protected]
- include in your e-mail full text from phone back label (phone name etc.)
identification#1 detection finished
device-id: D755B224
identification#1 protocol ver: 04
ver. sw 1: N96_ABROAD_PCB01_GPRS_MT6225_S00.N96_ABROAD_SPANS_ S5LCD_V2_3_6.BIN
ver. sw 2: N96_ABROAD_SPANS_S5LCD_V2.3.6, 8B861DE0
ffs offset/size: 00E00000/00200000
detect device identification#2...
detect device identification#2 finished
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
ffs/eeprom found near: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
reading: N96_ABROAD_PCB01_GPRS_MT6225_S00.N96_ABROAD_SPANS_ S5LCD_V2_3_6__ffs...
file saved: F:\1_Infinity\china backups\N96_ABROAD_PCB01_GPRS_MT6225_S00.N96_ABROA D_SPANS_S5LCD_V2_3_6__ffs_20091011-212735.B0E.bin
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
Write Done
Finalization ...
formatting...
Erase: chip 1 of 1
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\N 96_ABROAD_PCB01_GPRS_MT6225_S00.N96_ABROAD_SPANS_S 5LCD_V2_3_6__system_log_D755B224_1FE27974_20091011-213009.B0X.bin
Finished, time used: 399 sec
Remove/Install battery now !
Flash log...........
module v2.82
Action: write NOR flash
"smart write" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
Boot Done
Initialize ...
flash: 98000300000001:FFFFFF00000000
Initialize Done
Set baud ...
115200
Set baud Done
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
Write ...
.damaged firmware
.damaged hardware
warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.D755B224.[N96_ABROAD_PCB01_GPRS_MT6225_S00.N96_ABROAD_SPANS_ GUOAOLCD_V2_4_1.BIN_83692549].rpl
warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.D755B224._N96_ ABROAD_PCB01_GPRS_MT6225_S00.N96_ABROAD_SPANS_GUOA OLCD_V2_4_1.BIN_83692549_.rpl
warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.D755B224.[N96_ABROAD_PCB01_GPRS_MT6225_S00.N96_ABROAD_SPANS_ GUOAOLCD_V2_4_1.BIN_83692549].rpl
warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.D755B224._N96_ABROAD_PCB01_GPRS_MT6225_S00.N96_A BROAD_SPANS_GUOAOLCD_V2_4_1.BIN_83692549_.rpl
warning: unknown identification#1 structure: N96_ABROAD_PCB01_GPRS_MT6225_S00.N96_ABROAD_SPANS_ GUOAOLCD_V2_4_1.BIN_83692549
error: Unknown firmware detected (v.2.82, database date: ), user action required:
1. download latest software from support area and try again
2. if no still luck follow the next procedure:
- find good working phone with the same firmware:
- be little bit patient and wait update
detecting security area (code #2)...
security area (code #2) is absent
Area: Firmware
Write: Firmware
Write Done
Finalization ...
Finalization Done
Finished, time used: 1114 sec
these backup i have but not working
N96_ABROAD_PCB01_GPRS_MT6225_S00.N96_ABROAD_SPANS_ S5LCD_V2_3_6__ffs_20091011-212735.B0E.bin
Old 10-12-2009, 20:29   #2 (permalink)
faisal4friend's Avatar
Member: 262523
Sonork: 100.1611482
Thanks Meter: 288
first of all brother ur phone is already hardware problem because of ur phone was insert sim any way u can not select whole flash format method u can just complete format select other wise u have make full flash backup but u dont make full flash backup ur phone new firmware file and this file is not support area so what can u do just wait support area update and check it
Old 10-12-2009, 20:50   #3 (permalink)
kashif_khatri's Avatar
Member: 572614
Thanks Meter: 144
i can also face this problem , and i can also need this mobile flash file ,thanks.
i was waiting infinity team.
http://forum.gsmhosting.com/vbb/showthread.php?t=840635
Old 10-12-2009, 21:01   #4 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
what result you get by flashing this file:
flashfiles/ChineseMiracle/_MT6225/N96_ABROAD_PCB01_GPRS_MT6225_S00.N96_ABROAD_SPANS_ S5LCD_V2_3_6__w_eeprom.B0E.bin
Old 10-13-2009, 08:27   #5 (permalink)
Member: 541117
Thanks Meter: 173
i flash normally but look at this post log it give this eror
i have rpl back how to write it back
Old 10-13-2009, 16:11   #6 (permalink)
Member: 541117
Thanks Meter: 173
hello , infinity team pls have a look here
i need new firmware file for this phone , i could'nt find in support
if any have new firmware pls give me link
br
Old 10-13-2009, 16:20   #7 (permalink)
Cheater -Don't Deal with him-
Member: 1050335
Sonork: 100.1602801
Thanks Meter: 4,174
..::Brother to full flash with file so to ok file download this link http://forum.gsmhosting.com/vbb/showthread.php?t=716093 so i hope your problem solved::..
Old 10-13-2009, 16:39   #8 (permalink)
Member: 541117
Thanks Meter: 173
hello , look at my post i talking about NK 2008 not A200
if you have kindly show me the link... thnx
br
Old 10-13-2009, 17:11   #9 (permalink)
..::My3gtech::..'s Avatar
Member: 158032
Thanks Meter: 331
Bro download flash file from support site or take backup from another set and upload it on your phone that's the final solution...
Old 10-13-2009, 21:55   #10 (permalink)
Member: 148515
hello!
this RPL problem will be fixed in next CM update, which will be released nearest time
Old 10-14-2009, 16:04   #11 (permalink)
Member: 541117
Thanks Meter: 173
thnx i m waiting for your next update
br
Old 11-01-2009, 19:53   #12 (permalink)
rameez_gsm's Avatar
Member: 327384
Sonork: 100.1605419
Thanks Meter: 312
br
Hi new update is release watch there support area u must try to flash 2.4.1 your problem will b solve then post here result.....
Why LCD becomes White after Full format Mr. Right Infinity-Box 4 11-21-2009 16:51
Help infinity team china set dead after full format? malikawan Infinity-Box 3 10-02-2009 10:38
Phone not power after full format Raulperez53 CPF-Dongle 2 08-20-2009 05:52
Spice S700 After Full format Habg on WELCOME & goes Off....... amol_sm Infinity-Box 3 07-30-2008 13:14
NK 6103b dead after flashing. Help pls. Alemano Nokia Digital Core Technology 4 ( DCT-4 ) 0 07-25-2007 23:34
Page generated in 0.28147 seconds with 10 queries
