Nktel 2008 onboard pinouts needed hi charging connector is damaged .......Nktel 2008 onboard pinouts needed |
..::Brother to open mobile and you se 3 points sim jeck up 1:-rx 2:-tx 3:-gnd ..::So to use this pinout and enjoy::.. |
pcb Quote:
post yur pcb pic brother |
3 Attachment(s) here is pics.....................................check it |
1 pin dng 2 pin battery pin 3 pin rx 4 pin tx 5 power on off pin r difenrt |
..::Brother all china pinout this link http://www.shrak-mobile.com/eng/index.html so to press Thanks::.. |
try this 1 Attachment(s) try this brother i hope this pic helps u |
sorry i tried the above given pinouts but not working:confused: |
txd pin damaged on my board pls help |
@ZEERIK This is not MTK based cpu.its infeon or other cpu.because MTK cpu 2008 has same pinouts as A200 pinouts which are shown by EHSAS_GHUM.in very first time with this board i also surprised.if u can check cpu then check if not MTK then infinitybox cant help u. |
2008 nktel [ sir i know about 2008 ring ic ya CPU |
i need nktel 2008 charging juck pin out help me this board rx print damage |
