11-20-2010, 20:09 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Havana, CUBA
Member: 181633 Status: Offline Thanks Meter: 730 | Chinese ACE London I've not found on support a firmware for Chinese ACE "London" (Dual Sim iPhone Copy). Can someone sendme a backup from a working phone?. Phone is in dead status, when trying to read detailed information this is the resulting log: Thanks in advance Code: COM5 [VCP0] selected module v3.25 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:3403:0002 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC227E22632260:18A59F00000000 flash: AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC227E22632260:18A59F00000000 flash: AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 number of flash chip/regions detected: 02/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC227E22632260:18A59F00000000 flash: AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC227E22632260:18A59F00000000 flash: AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 it's time to stop: 18B09FA518B09FA518B09FA518B09FA518B09FA518B09FA5 number of flash chip/regions detected: 01/01 total flash region size: 02000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 01C00000 flash: EC227E22632260:18A59F00000000 checking area [00000000]: 00080000-01FFFFFF... ffs/eeprom found near: 00B40000 Detected ffs/eeprom address is non-standard: 00B40000 Posible reasons: 1. ffs/eeprom is Ok but address is non-standard 2. ffs/eeprom is damaged and can't be detected 3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make full flash backup for emergency case 3. repeat required operation Are you sure that detected ffs/eeprom address is correct ? Do you want to use standard ffs/eeprom address: 01C00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make full flash backup for emergency case 3. repeat required operation standard ffs/eeprom address confirmed by user: 01C00000 detecting ffs/eeprom size... ffs/eeprom size: 00400000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:01C00000-01FFFFFF firmware area: 00000000-01BFFFFF detecting ffs/eeprom structure pass 1... ................................................................................................................ ffs/eeprom: can't detect record name location error: ffs/eeprom detection failed: element #1 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished detecting firmware version... ................................................................................................................................ ................................................................................................................................ done warning: can not detect firmware version if software freez: make "Find firmware version (slow process)" unchecked and repeat operation. detecting firmware build... ................................................................................................................................ done detecting product-id... ................................................................................................................................ done detecting languages... ............................................. language parameters detected detected languages: En Fr Es Pt Finished, time used: 3 min 7 sec Remove/Install battery now ! |
I need Upgrade Hex for Chinese White CLIP | wilcd | Motorola Old Legacy (EMMI) | 1 | 02-24-2002 21:25 |
Somebody sells pic to upgrade the Chinese emmi-clips | ChavaL | Motorola Old Legacy (EMMI) | 0 | 11-05-2001 16:09 |
Sl45 chinese language file *.lng | bobby8850 | x1x to x45/x50 | 0 | 10-08-2001 13:09 |
3210v531 chinese flash file | dgtulga | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-28-2001 16:52 |
