02-11-2022, 11:26 | #1 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Into the Unknown
Member: 121461 Status: Offline Thanks Meter: 49 | Nokia 2.4 ta-1274 help! USB\VID_0E8D&PID_20FF&REV_0223, USB\VID_0E8D&PID_20FF i have tried to change drivers but windows 10 keep saying driver is not associated with hardware. i can only get fastboot option and this is the info that comes up Baseband MOLY.LR12A.R3.MP.V142.4.P42 MediaTek Bootloader Unlocked no Serial No PT99651CA1AB1900698 Secure Boot yes Kernel Little Kernel Product Wolverine Bootloader T99651AA2-4281638-20210902195636-202111 Hardware Rev ca00 Also when i get to andriod logo for recovery mode it sticks there i have tried various key combos but nothing happens except after a while the phone just restarts. I am trying to reset phone any help will be appreciated |
02-12-2022, 06:56 | #3 (permalink) | |
Member: 121461 Status: Offline Thanks Meter: 49 | Quote:
Android 11 on Nokia 2.4 blocks Brom or Preloader mode once FRP lock is activated. Therefore the only option to remove FRP or Reset the phone is via Testpoint. https://www.gsm1x.xyz/2022/01/testpo...id-11.html?m=1 | |
02-19-2022, 11:50 | #5 (permalink) |
Freak Poster Join Date: Jan 2013 Location: SEGOU MALI
Member: 1862574 Status: Offline Thanks Meter: 69 | I have nokia 1274 and i did factory reset with cm2 2.32 and my phone is broken only install mtk driver so be careful because my fone was in patern condition and now it is not works if your fone is ok please make read the firmware and share it it the forum you will help me veryvery good but dont do format or wipe userdata overwise you will brick your fone nokia 1274 can be connect without any touch or tespoint i formated mine witout holding any touch without tespoint also.thank so make read firmwaare before format |
04-20-2022, 20:27 | #8 (permalink) |
Freak Poster Join Date: Feb 2008 Location: Brasil
Member: 694980 Status: Offline Thanks Meter: 91 | Bkp [QUOTE=tontonbouba;14545912]you need put your fone in fast boot mode then go to recovry with any I made a backup by infinity, which can help those who had the dead model tool[/https://drive.google.com/file/d/166g16s6Dg0js-YXTfUENkkiKMMiJVLFT/view?usp=drivesdk |
07-08-2022, 10:33 | #9 (permalink) | |
No Life Poster Join Date: Mar 2010 Location: djerba
Member: 1269161 Status: Offline Thanks Meter: 119 | [QUOTE=wcelgsm;14546651] Quote:
bad link or deleted ! | |
