Old 04-13-2010, 00:35   #1 (permalink)
Member: 200703
Thanks Meter: 13
Request firmware bb chinese b100
==== C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e [4/13/2010 6:26:18 AM] ====
Loading data, wait...
[Infinity Box] Chinese Miracle v3.11
smart-card: connected
S/N: 4659:0116
Wait...
Device: Autodetect 6205-6227 NOR
Done
Loading file v.01...
Loading failed, probably damaged data file
Loading file v.02...
NEOTEL35_08B_GEMINI_PCB01_GPRS_MT6235B_S01.B300_BP _EN1_TOSHIBA512_V004__firmware_20100413-053418.B4M.bin
loaded
usb bootloader (file) is absent
rom info ver: 07
sw version: NEOTEL35_08B_GEMINI_PCB01_GPRS_MT6235B_S01.B300_BP _EN1_TOSHIBA512_V004.BIN
project-id: B300_BP_EN1_TOSHIBA512_V004, 00000000
code offset: 00000000
ffs offset/size [01]: 03000000/01000000
rom info structure: 2nd [standard] generation
TCL-ID is absent
request firmware bb chinese b100 (red colour) for infi
Old 04-14-2010, 18:24   #2 (permalink)
Member: 200703
Thanks Meter: 13
where is support infi?
Old 04-14-2010, 20:33   #3 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
what problem with phone? have you tried to solve it by format FFS SAfe?
Old 04-14-2010, 21:18   #4 (permalink)
Member: 200703
Thanks Meter: 13
hello bro
the phone was dead, but if i try to power on, have a good respond
i need new file flash for blackberry chinese b100 (red casing)
i was try ffs area, but it has error
==== [4/13/2010 5:19:06 AM] ====
COM6 selected
module v3.11
Device: Autodetect 6228-6239 NAND
Checking data, wait...
Action: read firmware NAND
interface: BROM_DLL_v3.952.00
Connect...
Connecting...
Booting...
Release Power button now !
bootcode current/expected: 3.2/3.2
CPU: 6235:8A04:8A01
status: FF
bbchip bl ver: FE
NOR flash chip: not installed
NAND flash id[0043]: 0098:00F000800095 [TOSHIBA] TC58NWM9S3B
chip size: 64Mb
page/spare size: 0800/0040
pages/block: 0040
bits i/o: 08
address cycles: 04
internal RAM size: 00010000
external RAM: absent
done
Set baudrate (921600)...
done
ram test...
testing...
ram test passed
===> detect existing firmware structure...
detect ffs...
ffs offset/size: 03000000/01000000
firmware size: 48Mb
ffs size: 16Mb
detect sec ro...
detect custom parameters...
detect project-id...
detect NAND info...
number of areas to read: 1
reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)...
nfi area detection...
bootloader version: _BOOTLOADER_B300_BP_EN1_TOSHIBA512_V004.bin
nfi area detection finished: Ok
TCL-ID detection...
TCL-ID detection done
startup code area #1 detection...
startup code area #1 detection done
rom info ver: 07
TCL-ID is absent
===> done
New firmware detected (v.3.11, database date: 18.03.2010):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
area size: 48Mb
error: can not read memory: 0FAA:S_FT_READBACK_FAIL
error: last error: 0FAA:S_FT_READBACK_FAIL
Disconnect...
done
Finished, time used: 1 min 7 sec
Remove/Install battery now !
In most cases you can read "firmware" instead of "full flash",
it may helps to save a lot of time with the same functionality.
Suggestion: read "firmware" now
Do you want to read "firmware" instead of "full flash" ?
==== [4/13/2010 5:20:17 AM] ====
COM6 selected
module v3.11
Connect...
error: can not boot device: 03E8:S_STOP
error: last error: 03E8:S_STOP
Disconnect...
done
Finished, time used: 14 sec
==== [4/13/2010 5:20:50 AM] ====
COM6 selected
module v3.11
Connect...
Disconnect...
done
Finished, time used: 25 sec
Old 04-18-2010, 21:02   #5 (permalink)
Member: 1043909
Thanks Meter: 60,926
Originally Posted by Arraniri View Post
hello bro
COM6 selected
module v3.11
Connect...
Connecting...
Booting...
CPU: 6235:8A04:8A01
status: FF
bbchip bl ver: FE
chip size: 64Mb
pages/block: 0040
bits i/o: 08
address cycles: 04
done
done
ram test...
testing...
ram test passed
detect ffs...
firmware size: 48Mb
ffs size: 16Mb
detect sec ro...
detect NAND info...
TCL-ID detection...
rom info ver: 07
TCL-ID is absent
===> done
area size: 48Mb
Disconnect...
done
COM6 selected
module v3.11
Connect...
Disconnect...
done
COM6 selected
module v3.11
Connect...
Disconnect...
done
Dear Friend,
Please, check the text that was given to you by software:
If you want to flash phone with another flash file, you can download flash files from Infinity-Box support area,
If you can not find in support area file with required firmware version, we will try to find if for you as soon as possible.
Please, do not ask us to find this firmware fast due to all that we can do is: we have to wait until somebody who have GOOD WORKING PHONE will be so kind and read full flash for us and send file to so, so then we will be able to check that file and upload it into support area.
Also last question: do you have the same good working phone ?
Are you able to read full flash from good working phone and send file to us ?
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
Firmware upgrade of 8850 Mad Max Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 07-02-2001 03:12
What Diagram do I need to build Firmware Flasher Cable Ari Nokia Hardware & Hardware Repair 1 06-21-2001 14:26
How to upgrade firmware on Nokia Pepek Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-18-2000 23:29
6150 firmware versions maxim Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 01-25-2000 10:55
Page generated in 0.21305 seconds with 9 queries
