05-25-2018, 05:01 | #1 (permalink) |
Junior Member Join Date: Jul 2005 Age: 44
Member: 158907 Status: Offline Thanks Meter: 3 | Tcl 750 Chinese Miracle II [MTK module] v 1.58 Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 37 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : BROM [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2122 EMICFG_NOT_ACCEPTED_CONFIG Boot Error! Operation Failed Elapsed: 00:00:12 Reconnect Power/Cable! Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 37 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : BROM [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2122 EMICFG_NOT_ACCEPTED_CONFIG Boot Error! Operation Failed Elapsed: 00:00:10 Reconnect Power/Cable! |
05-25-2018, 10:09 | #6 (permalink) |
Member: 158907 Status: Offline Thanks Meter: 3 | Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 37 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : BROM [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2122 EMICFG_NOT_ACCEPTED_CONFIG Boot Error! Operation Failed Elapsed: 00:00:10 Reconnect Power/Cable! |
10-23-2018, 15:25 | #7 (permalink) |
Freak Poster Join Date: Feb 2017 Location: Pakistan
Member: 2680797 Status: Offline Thanks Meter: 44 | Tcl 750 MT6755 Same prob how solve?? I Also try on MT2 Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.00 r4 Operation : Identify [ v2.00 r4 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM325) MODE : BOOTROM PORT : 325 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000007 BROM : SecMode : SBC+SLA+SDA BROM : BOOTROM MODE : 0_base : BASE_v1712 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6755 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00000001 : DA SEND ERROR! ERROR : SECURE BOOT : SLA NOT PASSED IN BROM MODE! INFO : BROM Level : SLA AUTH or AUTH required! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
