09-04-2017, 10:20 | #1 (permalink) |
No Life Poster Join Date: Apr 2003 Location: ROMANIA Age: 45
Member: 26714 Status: Offline Thanks Meter: 14 | nokia 3 ta-1032 unable to reset frp Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 94 ] Sync... Open port error , something went wrong! Boot Error! Operation Failed Elapsed: 00:00:17 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 94 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:09 Reconnect Power/Cable! |
09-05-2017, 10:43 | #3 (permalink) |
Member: 26714 Status: Offline Thanks Meter: 14 | i use cm2mtk also instaled InfinityBox_update_CM2MTK_Supplementary-files-package_v1.58 butt no luck. i select sp auto am frp reset. i need instructios |
10-25-2017, 09:05 | #6 (permalink) |
Junior Member Join Date: Apr 2012 Location: visakapatnam
Member: 1749901 Status: Offline Thanks Meter: 4,294,967,295 | nokia 3 ta-1032 unable to reset frp done by cm tool 1. sellect " sp:6571....6797 2. sellect model in down row "nokia 3" 3. go to service "reset frp" ok |
10-25-2017, 15:53 | #7 (permalink) |
Insane Poster Join Date: Mar 2008 Location: tunis
Member: 716894 Status: Offline Thanks Meter: 18 | nokia 3 ta-1032 unable to reset frp done by cm tool 1. sellect " sp:6571....6797 2. sellect model in down row "nokia 3" 3. go to service "reset frp" ok |
The Following User Says Thank You to lotfigsm2 For This Useful Post: |
