Old 08-01-2020, 19:05   #1 (permalink)
Member: 240756
Thanks Meter: 90
Mobicel R1 Plus Stuck On Mobicel Logo Bootloop
There is problem that i can not understand that what happened to Mobicel R1 Plus Device i got this mobile from client stuck and bootloop so i took backup with infinity CM2 and after Flash with New Rom MT6580 8.1.0 but Mobile Dead after flash but when flashed with BACKUP it Come Alive but same Bootloop condition,so please someone has any Idea what problem it could be.also try with other tools too but same condition.please help me to get ride of this problem.Logs here
Operation : Identify [ v2.13 ]
Mode : FLASH
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek PreLoader USB VCOM (Android) (COM146)
MODE : PRELOADER PORT
PORT : 146
Waiting BOOT ack ...
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
TYPE : LEGACY MTK
BROM : SecLevel : 0x00000000
BROM : SecMode : PLAIN [+PRL]
BROM : BROM|BL : 0xFF|0x01
BROM : PRELOADER PORT
MODE : Mobicel : Mobicel_R1 Plus_Boot | Manual : Disabled
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA_SP.bin
AGENT : Found MT6580
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
NAND : DEVICE NOT FOUND
NAND : 000000000000000000000000
eMMC : OK
eMMC : 44030188363144396F1C384721A60529
DAInf: 4 : 2 : 156
DA : DRAM ready!
DA : BOOT to 2nd DA ...
DA : Receiving HW info
EMMC: 880103443944313647381C6F2905A621
EMMC: VEN : FORESEE | OEM : 301 | DEV : D9D16G
EMMC:
BOOT1 : 0x00400000 [ 4.00 MB ]
BOOT2 : 0x00400000 [ 4.00 MB ]
RPMB : 0x00400000 [ 4.00 MB ]
USER : 0x39D000000 [ 14.45 GB ]
SRAM: 0x00020000 [ 128.00 KB ]
DRAM: 0x40000000 [ 1.00 GB ]
CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : AD1F44A8F39AAB68BF411C177D91AD79
STATUS : BLANK FLASH
BSTYLE : EMMC FLASH BOOT
DA : USB : HIGH-SPEED
Boot done!
Patch Level : O11019
Display ID : O11019 release-keys
Ver. CodeName : REL
Ver. Release : 8.1.0
Sec. Patch : 2019-07-05
Build Time : 1563798633
Product Model : R1 Plus
Product Brand : Mobicel
Product Name : R1_Plus
Product Device : R1_Plus
Board Platform : mt6580
Product Manfct : Mobicel
Product Info : k80hd_bsp_fwv_512m
Product Board : R1_Plus
USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption ***)
IMEI[0] : 35780510xxxxxxx
IMEI[1] : 35780510xxxxxx
IMEI[2] : 3546480xxxxxxx
NVRAM check : Passed!
NVRAM : SEC NORMAL [ No extra security ]
Done!
Elapsed: 00:00:22
Thanx
Old 08-01-2020, 19:26   #2 (permalink)
busywonder's Avatar
Member: 985857
Sonork: 100.1677137
Thanks Meter: 288
https://busywonderandco.co.za/produc...are-rommt6580/
Sent from my STK-L22 using Tapatalk
Old 08-01-2020, 19:47   #3 (permalink)
Member: 240756
Thanks Meter: 90
already Bought from Saroms and 2nd file from other site.but both of 2 firmware did not remove bootloop accept dead after flashed but revive after Backup file.
Old 08-01-2020, 19:53   #4 (permalink)
busywonder's Avatar
Member: 985857
Sonork: 100.1677137
Thanks Meter: 288
Untick the files until you get to system image. Flash system image downwards
Old 08-01-2020, 19:59   #5 (permalink)
busywonder's Avatar
Member: 985857
Sonork: 100.1677137
Thanks Meter: 288
The file on saroms shows to be tested soon which means it's not a tested file.
The Following User Says Thank You to busywonder For This Useful Post:
Old 08-01-2020, 21:05   #6 (permalink)
Member: 240756
Thanks Meter: 90
Still Dead condition after uncheck as above.no luck
Old 08-02-2020, 05:13   #7 (permalink)
busywonder's Avatar
Member: 985857
Sonork: 100.1677137
Thanks Meter: 288
I have flashed more than 8pieces so far, if your backup file is always able to revive the phone then the file you're using is not good.
Old 08-02-2020, 08:34   #8 (permalink)
Member: 240756
Thanks Meter: 90
i have sent you email about to add Fund for buying Silver Account but i have facing problem to transfer.please check [email protected]
The Following User Says Thank You to Aazib jhon For This Useful Post:
Old 08-02-2020, 08:49   #9 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Is simple factory reset/format fs not help?
The Following User Says Thank You to JayDi For This Useful Post:
Old 08-02-2020, 15:59   #10 (permalink)
Member: 240756
Thanks Meter: 90
No.can Enter In Recovery But when Select Recovery to boot in recovery Mobile Restart.you can not perform to factory reset..
Old 08-03-2020, 05:51   #11 (permalink)
busywonder's Avatar
Member: 985857
Sonork: 100.1677137
Thanks Meter: 288
I've received your email and whatsapp. ...
Old 08-03-2020, 12:08   #12 (permalink)
JayDi's Avatar
Member: 462970
From software, not device menu.
Old 08-03-2020, 12:10   #13 (permalink)
JayDi's Avatar
Member: 462970
Advertizing not allowed here, if you want share something - it must be open for community.
Otherwise use PM instead forum.
Old 08-03-2020, 12:21   #14 (permalink)
Moderator
...:::::NP™:::::...'s Avatar
Member: 1162626
Sonork: 100.1591727 QQ:2337938173
Thanks Meter: 11,110
@ busywonder
Just stop your spam around in this forum.
Really I'm wondering, here's how you can promoted your web which side not free only pay scrap web.
__________________
Use Search Button to get Instant Result | Follow Forum Rules
Avoid Spams in the forum to prevent ban your account.
The Following 2 Users Say Thank You to ...:::::NP™:::::... For This Useful Post:
Old 08-03-2020, 20:04   #15 (permalink)
busywonder's Avatar
Member: 985857
Sonork: 100.1677137
Thanks Meter: 288
Noted with thanks, there won't be a repeat.
Page generated in 0.25937 seconds with 9 queries
