08-26-2018, 05:58 | #2 (permalink) | |
Product Supporter Join Date: Jun 2014 Location: India
Member: 2211790 Status: Offline Thanks Meter: 5,118 | Quote:
ofp extraction not supported some of tool supported extract ofp but useless for other tool better try to read working set file with cm2 and flash in your faulty set(w/o LK and Preloader) or can take help from nearest oppo authorized service center Last edited by kamal_singla; 08-26-2018 at 06:06. | |
03-25-2019, 22:27 | #7 (permalink) |
No Life Poster Join Date: Jul 2013 Location: in my company
Member: 1984825 Status: Offline Thanks Meter: 222 | Operation : Reset Settings/Format FS [ v2.05 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM10) MODE : BOOTROM PORT : 10 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BOOTROM MODE : 0_base : BASE_v1712 | Manual : Enabled BROM : SLA BROM : SLA Passed! BROM : SLA CHLNG not used AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6755 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007024 : DA SEND ERROR! ERROR : SECURE BOOT : SELECTED DA NOT SUPPORTED IN CURRENT DEVICE STATE! INFO : BROM Level : CERT/AUTH required! Try boot device in PRELOADER mode with select PL/PL_CRYPTO/SWSEC type! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.05 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM10) MODE : BOOTROM PORT : 10 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BOOTROM MODE : 0_base : BASE_v1712 | Manual : Enabled BROM : SLA BROM : SLA Passed! BROM : SLA CHLNG not used AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6755 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0 EMI : CNT : 0008 EMI : Init EMI from INTERNAL DB DA : SETUP EMI PARAMS FAILED! ERROR : ABORT Error : Fail to init protocol! Internal EMI : Select other EMI number! External Preloader - make sure it correct for connected device! Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v2.05 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM10) MODE : BOOTROM PORT : 10 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BOOTROM MODE : 0_base : BASE_v1712 | Manual : Enabled BROM : SLA BROM : SLA Passed! BROM : SLA CHLNG not used AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6755 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0 EMI : CNT : 0008 EMI : Init EMI from INTERNAL DB DA : SETUP EMI PARAMS FAILED! ERROR : ABORT Error : Fail to init protocol! Internal EMI : Select other EMI number! External Preloader - make sure it correct for connected device! Reconnect Power/Cable! |
