06-26-2008, 05:35 | #1 (permalink) |
Junior Member Join Date: Nov 2007
Member: 626781 Status: Offline Thanks Meter: 2 | My G B889 Ask Help. its file flash have back-up with infinity, in the reality its file read corupt. finally, i taken file back-up from result of same phone good and still nicely its condition. process of flashing and formating with infinity success altogether. but my handphone become death. what wrong? this result of flash with infinity : COM18 [Serial2] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 003114A:38B0 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.AD4CCB76.[MTK26_05C_B889IDN_PCB01_GPRS_MT6226_S01.MAUI_05C_W 06_16.BIN_CD74198D].rpl ==================== New firmware detected: MTK26_05C_B889IDN_PCB01_GPRS_MT6226_S01.MAUI_05C_W 06_16.BIN - make "Read full flash" operation - send "backup_system_log_..." file to support: [email protected] - send flash backup file(s) to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished device-id: AD4CCB76 identification#1 protocol ver: 04 ver. sw1: MTK26_05C_B889IDN_PCB01_GPRS_MT6226_S01.MAUI_05C_W 06_16.BIN ver. sw2: MAUI.05C.W06.16, 72E68B32 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 01227E22202200:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom[MTK26_05C_B889IDN_PCB01_GPRS_MT6226_S01.MAUI_05C_W 06_16.BIN]]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\File Backup\eeprom[MTK26_05C_B889IDN_PCB01_GPRS_MT6226_S01.MAUI_05C_W 06_16.BIN]_20080626-085922.B0E.bin flash: 01227E22202200:29EA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.AD4CCB76.[MTK26_05C_MASTER_PCB01_GPRS_MT6226_S01.MAUI_05C_W0 6_16.BIN_7A44D4EF].rpl warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.AD4CCB76._MTK2 6_05C_MASTER_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_16 .BIN_7A44D4EF_.rpl warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.AD4CCB76.[MTK26_05C_MASTER_PCB01_GPRS_MT6226_S01.MAUI_05C_W0 6_16.BIN_7A44D4EF].rpl warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.AD4CCB76._MTK26_05C_MASTER_PCB01_GPRS_MT6226_S01 .MAUI_05C_W06_16.BIN_7A44D4EF_.rpl ==================== warning: unknown identification#1 structure: MTK26_05C_MASTER_PCB01_GPRS_MT6226_S01.MAUI_05C_W0 6_16.BIN_7A44D4EF error: Unknown firmware, user action required: 1. download latest software from support area and try again ! 2. if no still luck follow the next procedure: - find good working phone with the same firmware: MTK26_05C_MASTER_PCB01_GPRS_MT6226_S01.MAUI_05C_W0 6_16.BIN - make "Read detailed information" operation - send "backup_system_log_..." file to support: [email protected] - make "Read full flash" operation - send flash backup file(s) to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== You can flash phone now but can't finalize it. In most cases phone can NOT power-on normally. Do you want to write flash anyway ? file saved: C:\Program Files\InfinityBox\ChineseMiracle\system_log_AD4CCB 76_MTK26_05C_B889IDN_PCB01_GPRS_MT6226_S01.MAUI_05 C_W06_16.BIN_CD74198D_20080626-090219.B0X.bin Area: Firmware flash: 01227E22202200:29EA0000000000 Write: Firmware detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Write Done Finalization... Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\system_log_AD4CCB 76_MTK26_05C_B889IDN_PCB01_GPRS_MT6226_S01.MAUI_05 C_W06_16.BIN_CD74198D_20080626-092844.B0X.bin Finished, time used: 1990 sec Remove/Install battery now ! |
06-26-2008, 05:36 | #2 (permalink) |
Member: 626781 Status: Offline Thanks Meter: 2 | and this result of format of complete with infinity: COM18 [Serial2] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: reset Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 003114A:38B0 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 damaged, recalculation required identification#1 detection finished device-id: AD4CCB76 identification#1 protocol ver: 04 ver. sw1: MTK26_05C_MASTER_PCB01_GPRS_MT6226_S01.MAUI_05C_W0 6_16.BIN ver. sw2: MAUI.05C.W06.16, 102BBB85 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 01227E22202200:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom[MTK26_05C_MASTER_PCB01_GPRS_MT6226_S01.MAUI_05C_W0 6_16.BIN]]... warning: wrong cs at 0x00EFAC00, retry... read error recovered file saved: C:\Program Files\InfinityBox\ChineseMiracle\File Backup\eeprom[MTK26_05C_MASTER_PCB01_GPRS_MT6226_S01.MAUI_05C_W0 6_16.BIN]_20080626-094149.B0E.bin flash: 01227E22202200:29EA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: 01227E22202200:29EA0000000000 Finalization Done Finished, time used: 264 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
06-26-2008, 09:49 | #3 (permalink) | |
Please, read text marked in red color. | |
my ub always ask to open phone manual why?.. | mrsakoz | Universalbox | 2 | 10-14-2009 09:00 |
every time I switch on my N73 it asks me to re-set the time and date | gmarso2 | Nokia Hardware & Hardware Repair | 2 | 07-28-2008 11:55 |
MY V-55 asking for phone code | icedragon69 | ARM9 BASED M62 / M62+ | 6 | 11-19-2006 22:36 |
I reset my 6600 (*#7370#) now ask my memory card password HELP ME | moottoo | Nokia Multimedia | 13 | 01-17-2006 16:20 |
Asking help using Freia15 on MC60 | john999 | E-Gold Based Phones | 16 | 11-15-2004 13:17 |
