Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2019 Location: isr
Member: 2937153 Status: Offline Thanks Meter: 103 | Nokia 8000 4G TA-1305 Full flashing with CM2QLM Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Loading firmware ... Loading 1 program definition file(s) ... Load Ok! Operation : Flash [ v1.16 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 1DDEB71D ID_BLOCK_E : 00420029 ID_BLOCK_L : F3408EF69D8F9BB0A8D2CE6C67B81A7A ID_BLOCK_L : C4F3CFFF3072119A7A0B9F10E92842D8 Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000000E9000000 [ eMMC 4 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Boot Ok! Flash Chain : 42 Flashing now Flashing : sbl1.mbn Flashing : sbl1.mbn Flashing : emmc_appsboot.mbn Flashing : abootbak Flashing : rpm.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : tz.mbn Flashing : devcfg.mbn Flashing : apdp Flashing : pad Flashing : misc.img Flashing : fsc Flashing : ssd Flashing : splash.img Flashing : keystore Flashing : oem Flashing : config Flashing : NON-HLOS.bin Flashing : DDR Flashing : sec.dat Flashing : boot.img Flashing : system.img Flashing : persist.img Flashing : cache.img Flashing : recovery.img Flashing : devinfo Flashing : cmnlib.mbn Flashing : cmnlib.mbn Flashing : keymaster Flashing : keymasterbak Flashing : userdata.img Flashing : gpt_main0.bin Flashing : gpt_backup0.bin Flash sequence completed! Applying patches for storage # 0 Records : 26 Patch sequence completed! BootConfig set to 0x00 Flashing done! Done! Elapsed: 00:01:55 Reconnect Power/Cable! |
The Following 4 Users Say Thank You to y8765 For This Useful Post: |
![]() | #7 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2014
Member: 2289628 Status: Offline Thanks Meter: 221 | Quote:
Code: Loading firmware ... Loading 1 program definition file(s) ... Load Ok! Operation : Flash [ v1.16 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 1DDEB71D ID_BLOCK_E : 00420029 ID_BLOCK_L : F3408EF69D8F9BB0A8D2CE6C67B81A7A ID_BLOCK_L : C4F3CFFF3072119A7A0B9F10E92842D8 Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000000E9000000 [ eMMC 4 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Boot Ok! Flash Chain : 42 Flashing now Flashing : sbl1.mbn Flashing : sbl1.mbn Flashing : emmc_appsboot.mbn Flashing : abootbak Flashing : rpm.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : tz.mbn Flashing : devcfg.mbn Flashing : apdp Flashing : pad Flashing : misc.img Flashing : fsc Flashing : ssd Flashing : splash.img Flashing : keystore Flashing : oem Flashing : config Flashing : NON-HLOS.bin Flashing : DDR Flashing : sec.dat Flashing : boot.img Flashing : system.img Flashing : persist.img Flashing : cache.img Flashing : recovery.img Flashing : devinfo Flashing : cmnlib.mbn Flashing : cmnlib.mbn Flashing : keymaster Flashing : keymasterbak Flashing : userdata.img Flashing : gpt_main0.bin Flashing : gpt_backup0.bin Flash sequence completed! Applying patches for storage # 0 Records : 26 Patch sequence completed! BootConfig set to 0x00 Flashing done! Done! Elapsed: 00:01:55 Reconnect Power/Cable! How could you do this ? ![]() ![]() Code: Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 1373E794 ID_BLOCK_E : 00420029 ID_BLOCK_L : 48C9374D1434022B235B41F5FE0391F1 ID_BLOCK_L : 5F1E5264DDE9E461D19E70ED1CB3E933 Use CM2 Internal Loader ERROR : Prepare target failed! Unsupported SecureType! INFO : Send log and report.log to support! Include device info also! Reconnect Power/Cable! | |
![]() | #8 (permalink) | |
Member: 2289628 Status: Offline Thanks Meter: 221 | Nokia 8000 4G (TA-1311) Quote:
![]() | #11 (permalink) |
Product Supporter ![]() ![]() ![]() Join Date: May 2005
Member: 148515 Status: Online Thanks Meter: 19,178 | |
![]() | #12 (permalink) | |
Member: 2289628 Status: Offline Thanks Meter: 221 | ![]() Quote:
![]() By the way when will be release CM2QLM2 ???? | |
The Following User Says Thank You to hafiz4saqib For This Useful Post: |
