09-25-2021, 02:02 | #1 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Madeira Island Age: 47
Member: 85718 Status: Offline Thanks Meter: 449 | Nokia E52 Contact the retailer The true is recently i have resolved other same model im same situation, but i thik have done the same procedure to repair but atm no success. Any help is apreciated. Phone found! Series 60 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia E52-1 Software ver : V ICPR82_11w16.3.11 29-03-12 RM-469 (c) Nokia IMEI : 359327032824256 XappVer : 000008F2 Ape Ver : 091.004 APE Var : 091.004091.004.02.01091.004.C00.01 APE ADSP: 256 DSP Ver : 11w52 APE Test: v0.a091 PPM : CNT : Product SN : SEM335321 Product code : 0590249 Base Prd.code: 0565921 Module code : 0204674 Long Prod.SN : 0 Hardware info======= HWID : 6020 Retu : 40 Tahvo : 00 Battery: 4570 mV APE HW: 256 RF ic : |Vapaus_5.1 | Aura_?.? Lock info =========== IMEI : 359327032824256 IMEI spNet : IMEI svNet : Unable to read Lock table... Error collect lock info, try again User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! |
09-25-2021, 23:39 | #2 (permalink) |
Member: 85718 Status: Offline Thanks Meter: 449 | If i try to restore SimLock from firmware backup i have this result. Connect phone on selected interface... Checking, wait ... Get phone info data from flash... IMEI : 359327032824256 NPC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\359327032824256_CR T_2nd.rpl Get secure data... Taking additional data... ID_INFO : ICPR82_11w16.3.2/04-08-11/RM-469 #1st block Ok [SLT] - > Initial check failed, SimLock seems dead Elapsed: 00:00:48 |
