Old 12-12-2021, 22:56   #16 (permalink)
Member: 65061
Thanks Meter: 30
I tried those pinouts and no works, if phone still in the shop I will try to take a backup tomorrow.
The Following User Says Thank You to rikimaer For This Useful Post:
Old 12-13-2021, 08:47   #17 (permalink)
Member: 2433060
Thanks Meter: 4
https://disk.yandex.ru/d/rDYcGLFb8MXXew
4\64gb no userdata
The Following 2 Users Say Thank You to Demosis For This Useful Post:
Old 12-14-2021, 07:13   #18 (permalink)
Member: 716073
Thanks Meter: 17
Originally Posted by rikimaer View Post
Test point found and done with CM2
here
Short to GND
here..............................
The Following User Says Thank You to mawan161080 For This Useful Post:
Old 12-14-2021, 15:50   #19 (permalink)
Member: 240756
Thanks Meter: 90
Nokia TA-1334 Screen Lock And Frp Remove Successfully With CM2.
Here is Logs.
Card found : D0FD8DDE , v0151
Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.30
Load IDBase v1121431 Ok!
Update configuration ...
Operation : Identify [ v2.30 ]
Mode : FLASH
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port (COM18)
MODE : BOOTROM
PORT : 18
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
Error : Fail to init protocol!
>>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation!
Reconnect Power/Cable!
Mode : FLASH
MODE : BOOTROM
PORT : 18
BROM : Init BROM
BROM init passed!
CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
CODE : Cervino
TYPE : MODERN [RAPHAEL]
BROM : MEID : E7A2B86DF18C687C3918DEEFB14EA229
BROM : SecLevel : 0x000000E7
BROM : SecMode : SBC+SLA+SDA+EXT
BROM : BROM|BL : 0x05|0xFE
BROM : BOOTROM
BROM : SOCID : EA06EFB7ADBA9746DD9068D85D045D4359910FF05DF07843A0 D657A7F99CB6A3
BROM : SLA : Local Auth
BROM : SLA : Auth Started!
BROM : FF : Look for EMI
BROM : FF : EMI not found
BROM : SLA : Auth Passed!
BROM : SLA : 0x0000001F
AGENT : 0_base : BASE_v2112 | Manual : Disabled
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6765
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
DA : EXT_RAM NOT initialized!
EMI : DEV : INFINITY
EMI : SRC : PRELOADER_INFINITY_0
EMI : CNT : 0008
EMI : Init EMI from INTERNAL DB
EMI : EXT_RAM CFG Passed!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
SRAM: 0x0003A000 [ 232.00 KB ]
DRAM: 0xC0000000 [ 3.00 GB ]
EMMC: CID : 880103534C4433324759CFBF162FB7AF
EMMC: VEN : FORESEE : OEM : 3 : ID : 534C44333247
EMMC: VEN : FORESEE : SLD32G
EMMC: SNN : 3485406767 ( 0xCFBF162F) , MF : 11/2020
EMMC:
BOOT1 : 0x00400000 [ 4.00 MB ]
BOOT2 : 0x00400000 [ 4.00 MB ]
RPMB : 0x00400000 [ 4.00 MB ]
USER : 0x73A000000 [ 28.91 GB ]
CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : 59F2EC2E4BD74140E6CA2F975E6E0580
DA : USB : HIGH-SPEED
Boot done!
Done!
Elapsed: 00:00:23
Operation : Reset Settings/Format FS [ v2.30 ]
Mode : FULL FACTORY ( WIPE + FRP )
MODE : BOOTROM
PORT : 18
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : CNT : 0008
EMMC:
Boot done!
Format Ok : RESET PROTECTION
Format Ok : USERDATA
Done!
Elapsed: 00:00:27
The Following 3 Users Say Thank You to Aazib jhon For This Useful Post:
Old 12-15-2021, 02:51   #20 (permalink)
Member: 1228709
Thanks Meter: 272
Originally Posted by Brka View Post
If phone is still in your hands ... can you please check this image,
(or measure with multimeter device) if some of these points are also TP connected ?
p.s. sorry for late reply, was away from pc. Can you PLEASE make firmware/security backups and upload somewhere ?
p.s.2 good job, and also thanks @JorgeVla
b.r.
Alex
I have 3x security backup, do you want it ?
Old 12-15-2021, 18:32   #21 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,933
Of course
btw. does scatter-like reading of firmware works on this device ?
b.r.
Alex
__________________
Always press THANKS button if my post was helpful!
Please DO NOT send me PM's for help, You can ask for help on forum
Do not post THANKS posts - use thanks button !
ALWAYS use SEARCH button before posting!
Old 12-19-2021, 16:47   #22 (permalink)
Member: 2195859
Thanks Meter: 19
hi friends, testpoint done , phone got recognised .
identify ok , phone backed up ok
now after doing reset full factory wipe+frp phone startup failed.
'' no valid operating system could be found .device will reboot ''
restoring backup..not helpm getting error writing back backup
i will attached here logs..
Mode : FLASH
PTFN : MediaTek USB Port (COM80)
MODE : BOOTROM
PORT : 80
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : MEID : D971A3029BD73A274CBEA6C785146C2F
BROM : BOOTROM
BROM : SOCID : 3774B0DA52AA99B470FDA8D1B0802B1C252B9DC2485BA5DCD7 ED6BB6A4ACB655
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : CNT : 0008
EMMC: CID : 880103534C4433324759BFDA68241801
EMMC: SNN : 3218761764 ( 0xBFDA6824) , MF : 1/2021
EMMC:
RNID : A3FA9F88A11CB2414391C7A8644F1630
Boot done!
Product Brand : Nokia
Product Model : Nokia G10
Product Name : Rogue_00WW
Product Device : ROGA_sprout
Patch Level : RP1A.200720.011
Display ID : 00WW_1_260
Product Info : ROGA_sprout
Product Model : 00WW
Ver. CodeName : REL
Ver. Release : 11
Sec. Patch : 2021-09-05
Build Time : 26.09.2021
Product Board : MT6762
Board Platform : mt6765
Product Manfct : HMD Global
USERDATA : FILESYSTEM : EXT4 with FBE ( File-Base Encryption )
NVRAM : 0xA108D089
NVRAM : State : Ok!
NVRAM : SecLv : Vendor Signed
INFO : WiFi MAC : C010B1B368D9
INFO : BlTh MAC : C010B1B368DA
INFO : IMEI[1] : 358078143002065
INFO : IMEI[2] : 358078143002073
Backup sensetive data [ 16 ]
Backup path : Backup\MT6765__D971A3029BD73A274CBEA6C785146C2F\
[17] Read : NVRAM
[7] Read : NVDATA
[15] Read : PROINFO
[6] Read : NVCFG
[10] Read : PROTECT1
[11] Read : PROTECT2
[1] Read : PGPT
[13] Read : PERSIST
[0] Read : PRELOADER
Backup done!
STORAGE : Life Status : eMMC : OK!
STORAGE : OTP Status : UNLOCKED!
Done!
Elapsed: 00:02:33
MODE : BOOTROM
PORT : 80
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : CNT : 0008
EMMC:
Boot done!
Done!
Elapsed: 00:03:53
Operation : Restore backup [ v2.30 ]
MODE : BOOTROM
PORT : 80
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : CNT : 0008
EMMC:
Boot done!
Restore : nvcfg
ExtSparse : Compression ratio : 60%
Fail to restore : nvcfg , ERROR
Restore : nvdata
ExtSparse : Compression ratio : 83%
Fail to restore : nvdata , ERROR
Restore : nvram
Fail to restore : nvram , ERROR
Restore : persist
ExtSparse : Compression ratio : 73%
Fail to restore : persist , ERROR
Restore : pgpt
Fail to restore : pgpt , ERROR
Restore : proinfo
Fail to restore : proinfo , ERROR
Restore : protect1
ExtSparse : Compression ratio : 46%
Fail to restore : protect1 , ERROR
Done!
Elapsed: 00:04:14
any advices are welcomed
Old 12-19-2021, 17:32   #23 (permalink)
Member: 1043909
Thanks Meter: 61,327
No idea yet but v2.31 is the latest one but not 2.30, try it
Old 12-21-2021, 09:45   #24 (permalink)
Member: 2195859
Thanks Meter: 19
got one flash file , and tried to write with 2.31
Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.31
Preloader [HW DEV] Info :
EMI : DEV : MT6765
EMI : SRC : preloader_t99652aa1.bin
EMI : CNT : 0005
EMI : [00] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 512.00 MB ]
EMI : [01] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 3.00 GB ]
EMI : [02] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ]
EMI : [03] : DRAM : LP_DDR4 : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 3.00 GB ]
EMI : [04] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ]
Operation : Write Flash [ v2.31 ]
Repartition : Enabled
Flash Verify : Disabled
Reg.Pre-Erase : Enabled
Verify HW/SW : Enabled
SData Backup : Disabled
Safe UserData : Disabled
Flash Format : Disabled
Files :14
[FL] : Set : preloader_T99652AA1.bin
[FL] : Set : logo-verified.bin
[FL] : Set : md1img-verified.img
[FL] : Set : spmfw-verified.img
[FL] : Set : scp-verified.img
[FL] : Set : sspm-verified.img
[FL] : Set : gz-verified.img
[FL] : Set : lk-verified.img
[FL] : Set : dtbo.img
[FL] : Set : tee-verified.img
[FL] : Set : wt_custom.img
[FL] : Set : super.img
[FL] : Set : userdata.img
[FL] : Total size : 0x1036B05A8 [ 4.05 GB ]
MODE : BOOTROM
PORT : 80
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : BOOTROM
BROM : SLA : Starting Auth
BROM : SEC : 0x000000E0
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : DEV : MT6765
EMI : CNT : 0005
EMI : Init EMI from PRELOADER
EMMC:
Boot done!
[FL] : HW verification passed!
SEC_DL : False (RAPHAEL)
SEC_ID : 0x494E46494E495459424F584245535432
[FL] : Pre-Erase
Erase : 0x0000000000000000 : 0x0000000001688000
Erase : 0x0000000003688000 : 0x000000000769A000
Erase : 0x000000000C000000 : 0x0000000000800000
Erase : 0x000000000F800000 : 0x0000000000200000
Erase : 0x000000000FD00000 : 0x0000000000080000
Erase : 0x0000000013D80000 : 0x0000000008280000
Erase : 0x000000001E000000 : 0x0000000004D00000
Erase : 0x0000000024500000 : 0x0000000017800000
Erase : 0x0000000040800000 : 0x0000000240000000
[FL] : RePartition
[FL] : RePartition Ok!
[FL] : Flashing now ...
Write : PRELOADER
Update bootloader backup copy ...
Update bootloader backup copy Ok!
Write : LOGO_A
Write : MD1IMG_A
Write : SPMFW_A
Write : SCP_A
Write : SSPM_A
Write : GZ_A
Write : LK_A
Write : DTBO_A
Write : TEE_A
Write : WT_CUSTOM_A
Write : LOGO_B
Write : SUPER
Write : USERDATA
UltraFlash : OK!
[FL] : RePartition
[FL] : Flashing finished!
Done!
Elapsed: 00:03:48
but phone in same condition, also..if i try restore backup made by infinity , cannot get it back in working state..i still get this on phone lcd :
Old 12-21-2021, 09:47   #25 (permalink)
Member: 2195859
Thanks Meter: 19
https://ibb.co/THCsmgh
Old 01-03-2022, 09:14   #26 (permalink)
Member: 930870
Thanks Meter: 3
can someone add dump for this phone? tried wipe with cm2 and its bricked not backuped :/
Old 01-03-2022, 19:08   #27 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,356
CM2 can't brick this device by simple wipe.
Could you provide logs? Very interest to see them.
CM2 also make backups at any "even 1% chance possible brick" operation to avoid such issues from a long time ago.
Most probably "Restore Backup" button can handle "issue".
Old 01-03-2022, 19:50   #28 (permalink)
Member: 930870
Thanks Meter: 3
need full backup of this phone anybody can help?
Old 01-03-2022, 22:43   #29 (permalink)
Moderator
...:::::NP™:::::...'s Avatar
Member: 1162626
Sonork: 100.1591727 QQ:2337938173
Thanks Meter: 11,132
It's Working Perfectly Without Any Issue.
Operation : Identify [ v2.32 ]
Mode : FLASH
PTFN : MediaTek USB Port (COM3)
MODE : BOOTROM
PORT : 3
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : MEID : FB8AE4C565E9EF60FCD04DBE3EBAFD19
BROM : BOOTROM
BROM : SOCID : BD9AD0AC08649960792B5F605B7BABAEB2C00A52BF790B47E4 B9C10333DE601A
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : CNT : 0008
EMMC: CID : 880103534C4433324759DCAEE52EB7BF
EMMC: SNN : 3702449454 ( 0xDCAEE52E) , MF : 11/2020
EMMC:
RNID : 7F7086B12E7E5E41D3292FB28172DFE7
Boot done!
Display ID : 00WW_1_070
Ver. CodeName : REL
Ver. Release : 11
Sec. Patch : 2021-04-05
Build Time : 09.04.2021
NVRAM : 0xA108D089
NVRAM : State : Ok!
INFO : WiFi MAC : C010B1AC8EAB
INFO : BlTh MAC : C010B1AC8EAC
INFO : IMEI[1] : 358078141897748
INFO : IMEI[2] : 358078141897755
Backup sensetive data [ 17 ]
Backup path : Backup\MT6765__FB8AE4C565E9EF60FCD04DBE3EBAFD19\
Backup done!
STORAGE : RPMB Status : eMMC : RPMB KEY PROGRAMMED [UNUSABLE]
Done!
Elapsed: 00:00:29
Operation : Reset Settings/Format FS [ v2.32 ]
Mode : SMART RESET
MODE : BOOTROM
PORT : 3
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : CNT : 0008
EMMC:
Boot done!
SmartInfo : 0x835757
Done!
Elapsed: 00:00:29
Operation : Read Firmware [ v2.32 ]
ExtSparse : Enabled
ForceRead : Disabled
MODE : BOOTROM
PORT : 3
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : CNT : 0008
EMMC:
Boot done!
Info : Device support slots
Info : Active slot : a
Ver. CodeName : REL
Ver. Release : 11
MT6765__HMD_Global__00WW__11__00WW_1_070__RP1A.200 720.011__ROGA_sprout
Read : preloader.bin
Read : persist.img
ExtSparse : Compression ratio : 81%
Read : proinfo.img
Read : nvram.bin
Read : logo.bin
Read : md1rom.img
Read : spmfw.img
Read : tinysys-scp.bin
Read : sspm.img
Read : gz.img
Read : lk.bin
Read : boot.img
Read : dtbo.img
Read : tz.img
Read : vbmeta.img
Read : vbmeta_system.img
Read : vbmeta_vendor.img
Read : wt_custom.img
ExtSparse : Compression ratio : 92%
Read : oem.img
Read : elabel.img
ExtSparse : Compression ratio : 96%
Read : super.img
ExtSparse : Compression ratio : 34%
Read : userdata.img
FW Size : 4.15 GB
Android Info saved : _Android_info.txt
Scatter : MT6765_Android_scatter.txt
Saved to : C:\Users\NP\Documents\MT6765__HMD_Global__00WW__11 __00WW_1_070__RP1A.200720.011__ROGA_sprout\
Done!
Elapsed: 00:17:24
__________________
Use Search Button to get Instant Result | Follow Forum Rules
Avoid Spams in the forum to prevent ban your account.
The Following 4 Users Say Thank You to ...:::::NP™:::::... For This Useful Post:
Old 01-05-2022, 10:13   #30 (permalink)
Member: 509103
Thanks Meter: 40
pls,I need full backup of this phone anybody can help?
The Following User Says Thank You to godjy For This Useful Post:
Page generated in 0.34419 seconds with 9 queries
