Old 04-22-2022, 22:21   #46 (permalink)
killme12's Avatar
Member: 682054
Sonork: 100.1602688
Thanks Meter: 147
I am getting this error can some tell me where is the problem.........
Card found : 48007079 , v0153
Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.34
Load IDBase v312457 Ok!
Update configuration ...
Operation : Identify [ v2.34 ]
Mode : FLASH
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port (COM57)
MODE : BOOTROM
PORT : 57
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
CODE : Cervino
TYPE : MODERN [RAPHAEL]
BROM : MEID : AB7DC0128D8D875B26263DA7E3160636
BROM : SecLevel : 0x000000E7
BROM : SecMode : SBC+SLA+SDA+EXT
BROM : BROM|BL : 0x05|0xFE
BROM : BOOTROM
BROM : SOCID : 1BFC49D4494E579B7A6D67B72D330ECE67EDA42020E0029668 964A72CD7D3DD1
BROM : SLA : Local Auth
BROM : SLA : Starting Auth
BROM : FF : Look for EMI
BROM : FF : EMI not found
BROM : SLA : Auth Passed!
BROM : SEC : 0x000000E0
AGENT : 0_base : BASE_v2112 | Manual : Disabled
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6765
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
DA : SYNC with DA FAILED!
Error : Fail to init protocol!
>>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation!
Reconnect Power/Cable!
Mode : FLASH
MODE : BOOTROM
PORT : 57
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
EMI : DEV : MT6765
EMI : SRC : preloader_t99652aa1.bin
EMI : CNT : 0004
EMI : [00] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 512.00 MB ]
EMI : [01] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 3.00 GB ]
EMI : [02] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ]
EMI : [03] : DRAM : LP_DDR4 : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 3.00 GB ]
Mode : FLASH
MODE : BOOTROM
PORT : 57
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : BOOTROM
AGENT : 0_base : BASE_v2112 | Manual : Enabled
BROM : DA sent
DA : AGENT started!
Old 04-24-2022, 12:43   #47 (permalink)
xerraco's Avatar
Member: 890926
Thanks Meter: 2,076
Mode : FLASH
MODE : BOOTROM
PORT : 57
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
Mode : FLASH
MODE : BOOTROM
PORT : 57
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
EMI : DEV : MT6765
EMI : CNT : 0004
Mode : FLASH
MODE : BOOTROM
PORT : 57
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
Platform is Infinity Firefly Smartphone, try v2.32, v2.33
Br,
xerraco
The Following User Says Thank You to xerraco For This Useful Post:
Old 04-24-2022, 14:57   #48 (permalink)
killme12's Avatar
Member: 682054
Sonork: 100.1602688
Thanks Meter: 147
Br,
xerraco
tried that also but still same sir............
Old 04-24-2022, 19:48   #49 (permalink)
killme12's Avatar
Member: 682054
Sonork: 100.1602688
Thanks Meter: 147
Br,
xerraco
Sorry bro and thanks a lot V2.33 worked for me ......
Load IDBase v1121431 Ok!
Operation : Identify [ v2.33 ]
Mode : FLASH
MODE : BOOTROM
PORT : 57
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : BOOTROM
BROM : Sending FireFly
FireFly : Starting ...
FireFly : Init Core
FireFly : Core init done!
FireFly : Running : v05.05.05 on MT6765
FireFly : eMMC init passed!
EMMC: CSD : D0FFFF329F5903FFFFFFFFEF9640002D
EMMC: CSD : TEMP_WRITE_PROTECT: False
EMMC: CSD : PERM_WRITE_PROTECT: False
EMMC: CID : 880103534C443634476531FB48B038B1
EMMC: VEN : FORESEE : OEM : 3 : ID : 534C44363447 : PRV : 0x65
EMMC: VEN : FORESEE : SLD64G
EMMC: SNN : 838551728 ( 0x31FB48B0 ) , MF : 3/2021
EMMC: EXTCSD : rev1.8 ( eMMC 5.1 )
EMMC: EXTCSD [CONFIG] : 0x48, 0x02, 0x01
EMMC: EXTCSD [PARTITION_CONFIG] : 0x48
EMMC: EXTCSD [BOOT_BUS_WIDTH] : 0x02
EMMC: EXTCSD [RST_N_FUNCTION] : 0x01
EMMC: EXTCSD [PART_S_COMPLETED] : False
EMMC: EXTCSD [SIZE] : Market : 64 GB
EMMC: EXTCSD [SIZE] : Actual : 0xE67800000 [ 57.62 GB ]
EMMC: EXTCSD [EOL] : EOL status : Normal ( Less than 80% reserved blocks used )
EMMC: EXTCSD [EOL_A] : SLC status : 0% - 10% used
EMMC: EXTCSD [EOL_B] : MLC status : Not defined
EMMC:
BOOT1 : 0x00400000 [ 4.00 MB ]
BOOT2 : 0x00400000 [ 4.00 MB ]
USER : 0xE67800000 [ 57.62 GB ]
DA : USB : HIGH-SPEED
Boot done!
Product Brand : Nokia
Product Model : Nokia G10
Product Name : Rogue_00WW
Product Device : ROGA_sprout
Patch Level : RP1A.200720.011
Display ID : 00WW_1_160
Product Info : ROGA_sprout
Product Model : 00WW
Ver. CodeName : REL
Ver. Release : 11
Sec. Patch : 2021-07-05
Build Time : 06.07.2021
Product Board : MT6762
Board Platform : mt6765
Product Manfct : HMD Global
USERDATA : FILESYSTEM : EXT4 with FBE ( File-Base Encryption )
NVRAM : 0xA108D089
NVRAM : State : Ok!
NVRAM : SecLv : Vendor Signed
INFO : WiFi MAC : C010B1CB1265
INFO : BlTh MAC : C010B1CB1266
INFO : IMEI[1] : 358078144690264
INFO : IMEI[2] : 358078144690272
Backup sensetive data [ 18 ]
Backup path : Backup\MT6765__AB7DC0128D8D875B26263DA7E3160636\
[17] Read : NVRAM
[7] Read : NVDATA
[15] Read : PROINFO
[6] Read : NVCFG
[10] Read : PROTECT1
[1] Read : PGPT
[13] Read : PERSIST
[0] Read : PRELOADER
Backup done!
Done!
Elapsed: 00:04:26
Operation : Reset Settings/Format FS [ v2.33 ]
Mode : SMART RESET
MODE : BOOTROM
PORT : 57
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : BOOTROM
FireFly : Init Core
EMMC:
Boot done!
SmartInfo : 0x835757
Format Ok : RESET PROTECTION
Format Ok : USERDATA
Done!
Elapsed: 00:01:08
Old 07-05-2022, 09:10   #50 (permalink)
Member: 2345191
Thanks Meter: 35
Originally Posted by ...:::::NP™:::::... View Post
flash this firmware mobile dead
Old 08-29-2022, 05:53   #51 (permalink)
Member: 2989274
Thanks Meter: 20
Originally Posted by rikimaer View Post
Test point found and done with CM2
Short to GND
Can we repair imei with Cm2.?
Old 11-08-2022, 02:39   #52 (permalink)
valentine aquil's Avatar
Member: 504913
Sonork: 100.1659651
Thanks Meter: 29
I can't seem to get these working on my own
Operation: Identify Device [ v2.38u ]
Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X
Mode: FLASH
[+] Sensitive Data Backup
[+] AutoBoot
[+] Read Deep Info: PRL, HW, DEBUG
[-] AutoEMI
[-] FireFly UNI-Proto
[+] Smart Service
[-] Local SLA
[-] Force BROM
Wait...
1. Power Off the device
2. Wait 20 seconds
3. Connect USB cable to device
Waiting for device connection...
PTFN: MediaTek USB Port_V1632 (COM3)
MODE: BOOTROM
PORT: 3
Waiting BOOT ack...
BROM: Skip ACK verify
BROM: Init BROM
BROM init passed
CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766
CODE: Cervino
TYPE: MODERN [RAPHAEL]
BROM: MEID: 1CFCB8E099687DCFF8D6AEF00237E3ED
BROM: SecLevel: 0x000000E7
BROM: SecMode : SBC+SLA+SDA+EXT
BROM: BROM|BL : 0x05|0xFE
BROM: BOOTROM
BROM: SOCID: D8E53139813C17D08974774B3B89AA1123407332471C0E11E0 4619C794F0F4C0
BROM: SLA: Local Auth
BROM: SLA: Starting Auth
BROM: SLA: Auth Passed
BROM: SEC: 0x000000E0
AGENT: 0_base : BASE_v2112 | Manual : Disabled
AGENT: Looking for suitable BootChain in DA...
AGENT: [0656ff20] C:\InfinityBox\CM2MT2\boot\0_base\BASE_v2112\MTK_A llInOne_DA.bin
AGENT: Found MT6765
AGENT: MTK_DOWNLOAD_AGENT
BROM: Sending 1st DA...
BROM: DA sent
BROM: Transfer control to DA...
DA: AGENT started
DA: SYNC with DA FAILED
1. Disconnect battery and cable
2. Check USB drivers
3. Change cable
4. Change USB port
5. Do not use USB-hub
Try again
Page generated in 0.20611 seconds with 9 queries
