Old 11-30-2007, 02:41   #1 (permalink)
Member: 215758
Thanks Meter: 33
zte a12+ sp-unlock
they could help me I have tried to open this model's bands but it leaves me
this yano you that to make the client above helps derrepente makes bad or that
lacks to make it
the cel also works well
I place him the clearing sim it works but I want for movistar
COM12 [VCP0] selected
Device: ZTE-A12+
Checking data, wait...
Action: unlock
Boot...
Phone must be POWERED-OFF !
Press and HOLD Power button !
Connecting, wait...
Release Power button !
flash: EC22A000000000:38E59F00000000
flash: Samsung T 4Mb
Boot Done
Set baud...
115200
Set baud Done
Check flash...
Check flash Done
Check space...
file saved: C:\Archivos de programa\InfinityBox\AModule\backup__eeprom-calibration_20071129-202048.98E.bin
warning: wrong data size at 0x01370800, retry...
read error recovered
warning: wrong data size at 0x0137E000, retry...
warning: wrong data size at 0x0137E800, retry...
error: too many retries during read operation
file saved: C:\Archivos de programa\InfinityBox\AModule\backup__eeprom-ffs_20071129-202137.98E.bin
Reading[lock-area-2]...
warning: wrong data size at 0x011F0000, retry...
warning: wrong cs at 0x011F0000, retry...
error: can't read flash area, operation aborted
Check space Fail
error: no any expected answer
Finished, time used: 89 sec
Remove/Install battery now !
Old 11-30-2007, 03:01   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
switch On advanced chip detection method and try again
Old 11-30-2007, 07:03   #3 (permalink)
Member: 215758
Thanks Meter: 33
Exclamation
not never
Device: ZTE-A12+
advanced flash detection active
Action: unlock
Boot...
Connecting, wait...
flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb
Boot Done
Set baud...
115200
Set baud Done
Check flash...
Check flash Done
Check space...
file saved: C:\Archivos de programa\InfinityBox\AModule\backup__eeprom-calibration_20071129-234257.98E.bin
warning: wrong data size at 0x0137C400, retry...
warning: wrong cs at 0x0137C400, retry...
error: unexpected data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
file saved: C:\Archivos de programa\InfinityBox\AModule\backup__eeprom-ffs_20071129-234337.98E.bin
error: wrong answer[97]
Check space Fail
error: wrong answer[3B]
Finished, time used: 57 sec
Old 11-30-2007, 13:24   #4 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Please, double check cable, be sure that phone connector contacts is cleran, that your cable is quite short and that battery enough charged.
As I can see from your logs the problem is a communication error that can be a result of cabler problems.
Each time error at different address, this means that it's not software problem but it's cable problem or phone hardware problem.
Old 12-01-2007, 05:24   #5 (permalink)
Member: 215758
Thanks Meter: 33
already revise step for step the cable he/she has 10 centimeters the connector
ok I proved it now with another celeluar and the same thing I request a
solution to my problem departe of the support of this box
Old 12-01-2007, 17:47   #6 (permalink)
Member: 130995
Hello,
Please, try to use another cable, I don't think it's softare pronblem.
Old 03-02-2020, 13:30   #7 (permalink)
Member: 2905715
Sonork: 100.1682585
Thanks Meter: 11
ZTE-A12+ unlocking any solution.is sigma and nck dongle can support
Old 03-02-2020, 13:34   #8 (permalink)
kamal_singla's Avatar
Member: 2211790
Thanks Meter: 5,118
kindly please do not spam here
Old 03-02-2020, 13:51   #9 (permalink)
Member: 2905715
Sonork: 100.1682585
Thanks Meter: 11
need solution ztea12+
ZTE A12+ succesfully unlock by infinity. sayfulalam Infinity-Box 9 08-29-2009 08:27
23 Jun 2008: ZTE-A12, A12+, A15, A16, A37, A39, A80, 2010, WP626, Coral-300 imei... InfinitySupport Infinity-Box 29 07-08-2008 07:24
22 Jun 2008: "AModule" v1.30:imei repair function added for .ZTE-A12, A12+, A15, A16, alamgir80 Infinity-Box 6 06-23-2008 11:48
23 Jun 2008: ZTE-A12, A12+, A15, A16, A37, A39, A80, 2010, WP626, Coral-300 imei... SHANU Service Products News & Updates 0 06-23-2008 09:59
ZTE A12+ Unlock problem himu_mm Infinity-Box 3 03-17-2008 12:09
Page generated in 0.22297 seconds with 9 queries
