Old 07-23-2020, 18:59   #1 (permalink)
Member: 383211
Thanks Meter: 105
nokia hmd ta-1139 dead after write file in cm2
.i format it befoe writing its own backup .mobile formted but when insert sim after little while mobile hanged.nokia hmd ta-1139 dead after write file in cm2.show this error after writing finished
[ERROR] : DA_UART_RX_BUF_FULL
Flash Error!
Check Cable, Battery , try again
Card found : S/N : 53471D69 , v0144
Operation : Check / Read Info [ v1.58 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 67 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0000
BB_CPU_SN : 7F7F0E99E94C2EF362A5AF4B796B6C67
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x00EC , [GigaDevice] GD25LQ32
[0] : FLASH_DIE : 00C8 0060 0016 0000
[0] : FLASH_LEN : 0x00400000
SDS_INFO : 0x003FE000 , 0x00002000
INT_RAM : 0x0000D000
EXT_RAM : 0x00400000
File_Info : MXWD012_D_HL_M258S_QMOBILE_PCB01_gprs_MT6261_S00.Q MOBILE_N222_V07_09_01_2017.bin
FileVersion : QMobile_N222_V07_09_01_2017
Done!
Elapsed: 00:00:31
Reconnect Power/Cable!
Wait for phone...
Phone found! [ 67 ]
Sync...
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
Setting...
BROM stage done
SOC_VERIFY : 0xC1
Backup done
Executing FFS FORMAT now...
FAT_RANGE : 0x00393000-0x003FDFFF , LEN : 0x0006B000
DA_RET : DA_IN_PROGRESS
DA_RET : FORMAT_DONE
Done!
Elapsed: 00:00:25
Load File
File_Info : KEYTAK60A_M210_PCB01_gprs_MT6260_S00.M210_IJ_7789V N_190803_V01.bin
FileVersion : M210_IJ_7789VN_190803_V01
Load File Ok
Operation : Flash [ v1.58 ]
======= Flash
Files set for flashing :
[ MCU ] : KEYTAK60A_M210_PCB01_gprs_MT6260_S00.M210_IJ_7789V N_190803_V01.bin
Wait for phone...
Phone found! [ 67 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6260_S0000
BB_CPU_SN : 13641B4AD8C4280BE777CAD4F26F9A3A
Setting...
BROM stage done
InitRes : 00000000
DEV[0] : C200 2500 3800 0000
DEV[1] : 0000 0000 0000 0000
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B
SOC_VERIFY : 0xC1
[0] : FLASH_VEN : 0x00EF , [MXIC] MX25U12835FZNI_10G
[0] : FLASH_DIE : 00C2 0025 0038 0000
[0] : FLASH_LEN : 0x01000000
SDS_INFO : 0x00FFE000 , 0x00002000
EXT_RAM : 0x00800000
Flash now
Erase region , wait ...
Write data , wait ...
Write : KEYTAK60A_M210_PCB01_gprs_MT6260_S00.M210_IJ_7789V N_190803_V01.bin
Flash Error!
Operation Failed
Elapsed: 00:02:02
Old 07-24-2020, 14:43   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 17,229
In most cases that mean damage of FlashIC.
The Following 4 Users Say Thank You to JayDi For This Useful Post:
Old 07-30-2020, 10:10   #3 (permalink)
Crazy Poster
Member: 2812460
Thanks Meter: 11
i have same problem also. please share tested file and solution also.. my mobile was 100 % working only problem was that game charges were deducting by telenor every week thats why i flashed it.. i also take backup but when i load that file it says bad file.. plz help
Old 07-30-2020, 11:12   #4 (permalink)
JayDi's Avatar
Member: 462970
Make sure about you read FactoryFW, maybe? It can be flashed via MTK FlashTool ( NOT SP Flash Tool )
The Following User Says Thank You to JayDi For This Useful Post:
Old 07-31-2020, 22:12   #5 (permalink)
ddilshod93's Avatar
Member: 2082192
Thanks Meter: 1,032
Wait for phone...
Phone found! [ 67 ]
Sync...
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
Setting...
BROM stage done
SOC_VERIFY : 0xC1
Done!
Elapsed: 00:00:31
Wait for phone...
Phone found! [ 67 ]
Sync...
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
Setting...
BROM stage done
SOC_VERIFY : 0xC1
Backup done
Done!
Elapsed: 00:00:25
Load File
Load File Ok
======= Flash
Wait for phone...
Phone found! [ 67 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
Setting...
BROM stage done
InitRes : 00000000
SOC_VERIFY : 0xC1
Flash now
Flash Error!
Operation Failed
Elapsed: 00:02:02
Hi!
You flashed not correct fw, correct fw here!
In link fw .bin format flashing using CM2MTK.
Old 08-09-2020, 13:08   #6 (permalink)
Crazy Poster
Member: 2812460
Thanks Meter: 11
Originally Posted by ddilshod93 View Post
Hi!
flashed my mobile flashing done but mobile not switching on.. Plz share any other file.
Old 08-09-2020, 13:53   #7 (permalink)
Crazy Poster
Member: 2812460
Thanks Meter: 11
Load File
Load File Ok
======= Flash
[ MCU ] : MXWD012_D_HL_M258S_QMOBILE_PCB01_gprs_MT6261_S00.Q MOBILE_N222_V07_09_01_2017.bin
Wait for phone...
Device boot not done
Check Drivers
Try again
Boot Error!
Operation Failed
Elapsed: 00:00:40
======= Flash
Wait for phone...
Phone found! [ 53 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_SN : F8A8237842B99B06641767A50B7DDF02
Setting...
BROM stage done
InitRes : 00000000
SOC_VERIFY : 0xC1
Flash now
Write : MXWD012_D_HL_M258S_QMOBILE_PCB01_gprs_MT6261_S00.Q MOBILE_N222_V07_09_01_2017.bin
Done!
Elapsed: 00:01:10
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 53 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
Setting...
BROM stage done
InitRes : 00000000
SOC_VERIFY : 0xC1
Backup done
Done!
Elapsed: 00:00:20
STILL NOT POWERING ON PLZ SHARE FILE
Old 08-09-2020, 15:09   #8 (permalink)
Member: 2546130
Thanks Meter: 4
Wait for phone...
Phone found! [ 5 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_SN : E6EC6363763EF3080A62709DE7533A3A
Setting...
BROM stage done
InitRes : 00000000
SOC_VERIFY : 0xC1
Done!
Elapsed: 00:00:10
Operation : Read UserCode [ v1.58 ]
Wait for phone...
Phone found! [ 5 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
Setting...
BROM stage done
InitRes : 00000000
SOC_VERIFY : 0xC1
Read ExtData
Sorting ExtData
Reading UserCode
Active : No , Code : 12345
PLock|MobTrack : Not active
Done!
Elapsed: 00:00:13
Operation : Read Flash [ v1.58 ]
Wait for phone...
Phone found! [ 5 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
Setting...
BROM stage done
InitRes : 00000000
SOC_VERIFY : 0xC1
Reading Flash Content now ...
Read Flash now
Read Ok , 16777216 bytes read
Check and collect compile info
Saved to : C:\InfinityBox\CM2MTK\Read_out\KEYTAK60A_M210_PCB0 1_gprs_MT6260_S00.M210_IJ_7789VN_190803_V01.bin
Done!
Elapsed: 00:00:57
Flash File Link :- https://mega.nz/file/aJJwlSrZ#34cBYx...rM8HjcRXOGdcq0
Old 08-11-2020, 16:15   #9 (permalink)
Crazy Poster
Member: 2812460
Thanks Meter: 11
Wait for phone...
Phone found! [ 5 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
Setting...
BROM stage done
InitRes : 00000000
SOC_VERIFY : 0xC1
Done!
Elapsed: 00:00:10
Wait for phone...
Phone found! [ 5 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
Setting...
BROM stage done
InitRes : 00000000
SOC_VERIFY : 0xC1
Read ExtData
Sorting ExtData
Reading UserCode
Done!
Elapsed: 00:00:13
Wait for phone...
Phone found! [ 5 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
Setting...
BROM stage done
InitRes : 00000000
SOC_VERIFY : 0xC1
Read Flash now
Done!
Elapsed: 00:00:57
Card found : S/N : 1DEDBB41 , v0137
Load File
Load File Ok
======= Flash
Wait for phone...
Phone found! [ 53 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
Setting...
BROM stage done
InitRes : 00000000
SOC_VERIFY : 0xC1
BOOT_STYLE : DONE
[ERROR] : DA_BLANK_FLASH
Flash now
Flash Error!
Operation Failed
Elapsed: 00:03:17
Not working Plz someone share working file
Page generated in 0.39760 seconds with 7 queries
