Nokia N22 pinout needed? 1 Attachment(s) Hi, I need China Nokia N22 pinout! it's 2x6 pins! Here is picture of the pcb. Anyone got this? thanks |
Dear Friend, There are different "Chinese" phones with the same name but absolutely different hardware exist on market. Example: exist at least 30 "Chinese" phones with name "N95", at least 20 models "N73" etc. but all models has difference in hardware, different bottom connectors, different pinouts and and has different firmware, so it's impossible to give any advice about phone pinout only by phone name. So we recommend you to include the next information in your request regarding pinout: 1. detailed description of model: brand name, model name, complete text from phone back label, any other marks that you can find on phone cover 2. phone CPU chip name 3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB) 4. attach phone photo 5. attach phone bottom connector photo 6. include information about Gnd and Charge pins on phone bottom connector After you have this information prepared, you can find pinout by yourself more easy than before, just check the next detailed description how to get pinout for your model: 1. use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 2. if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\ 3. if not helps, please read: http:///vbb/showpo...36&postcount=7 4. if not helps, please read: http:///vbb/showthread.php?t=433447 Universal solution for pinout detection: http://www.infinity-box.biz/index.ph...infinder&lg=en |
None got this kind of phone before? It's 2x6 pin: / 1 - - - - - - 6 \ / 7 - - - - - - 12 \ keybord up GND:8 VPP: 1 TX: ? RX: ? need help, tanks. |
hello! as long as nobody able to help i can advice fast and easy method to detect needed pins: measure voltage on all pins and detect needed by voltage near 2,7-2,8volts. step by step tutroial is in out FAQ section under "second and tested way..." |
neeeeeeeeeeed this pinout |
Good pinout for N22 RM-56 2x6 pin 8 GND 6 TX 7 RX tested ok in infinity box cable UB-CECT006 CECT S560 |
1 Attachment(s) Use this one ( tested) : |
thanks work 100/100................ |
