nokia n95 8gb fake can not connect with pinfinder what to do? hi guy i have fake nokia n95 8gb i can not connect with pin finder its same as real one its has usb connection i have cable L5A i try to connect with but can not connect what to do? can plz some one help me out? thanks |
try mild rehit the arm ic thats the only ic i always het when hard to find tx rx if not re plant arm ic |
hello! Most N95 with L5A cable keep tx/rx as test points on PCB. you can do search in pinout folder and find pinout for you PCB type |
hello! you have to use test points on PCB. here is example: http://forum.gsmhosting.com/vbb/f296...-cable-386780/ pinout for your phone can be found in Pinout folder C:\Program Files\InfinityBox\pinout make search for "N95" and find in available pictures your type |
use L10C i have tested it but backup first |
