03-30-2008, 18:04 | #1 (permalink) |
Freak Poster Join Date: Oct 2004 Location: Batna Age: 43
Member: 85151 Status: Offline Thanks Meter: 30 | N73 RM-133 BIG problem but after i have white screen i try to make eeprom beckup but no result any solution please |
03-31-2008, 09:17 | #3 (permalink) |
Member: 85151 Status: Offline Thanks Meter: 30 | original flash is CM_Nokia-N73-1-RM-133_JCJ_H252608CT_SK3_CO6R_GI9[1].DB02_JCJ00_966D_ C_V2_2DTEST--070919_16m_En_Ru_Fr_De_Id_Vn_Ar.B0M it's N73 i flash the phone with the same flash but same problem white screen |
03-31-2008, 13:31 | #4 (permalink) |
No Life Poster Join Date: Jan 2002 Location: Jordan Age: 46
Member: 8664 Status: Offline Sonork: 100.1573507 Thanks Meter: 56 | weard, lemme explane something 1st- the phone should not be damaged by FFS format 2nd- if you flashed the phone with same version which was on your phone, it should work 100%. 3rd- if the phone can send and receive calls, then probably you have some hardware problem. do u have another phone [same hardware, and software] if yes, try to read full flash from the working one and flash it to the other phone with the white lcd problem. if nothing is changed, then put the working LCD on the damaged phone to check the hardware. BR Mansi |
03-31-2008, 19:37 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello guys! i think mr. karimgsm must spend some time on checking operation.log file. find operations which he did with this phone and compare or even better- post it here. there are many flash file versions which look exactly same, but have difference just in 1-2 letters. so lets focus one more time on Original phone version |
04-01-2008, 11:37 | #6 (permalink) |
Member: 85151 Status: Offline Thanks Meter: 30 | ok here is the log file ==== log opened: [30/03/2008 16:28:27] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v2.36 S/N: 10AF:010E Wait... Device: Autodetect 6205-6227 NOR Done WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? COM5 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: reset Boot... Press and HOLD Power button now ! error: can't detect device Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 30 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? COM5 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: reset Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:C67E:E360 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 04227E22212200:2BEA0000000000 flash: Fujitsu AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: 04227E22212200:2BEA0000000000 flash: Fujitsu AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 04227E22212200:2BEA0000000000 flash: Fujitsu AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: 04227E22212200:2BEA0000000000 flash: Fujitsu AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.140CB857.[JCJ_H252608CT_SK3_CO6R_GI9.DB02_JCJ00_966D_C_V2_2D TEST--070919.BIN_52CCD78E].rpl identification#1 detection finished device-id: 140CB857 identification#1 protocol ver: 05 ver. sw1: JCJ_H252608CT_SK3_CO6R_GI9.DB02_JCJ00_966D_C_V2_2D TEST--070919.BIN ver. sw2: DB02_JCJ00_966D_C_V2.2DTEST, 712833AD ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 04227E22212200:2BEA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom[JCJ_H252608CT_SK3_CO6R_GI9.DB02_JCJ00_966D_C_V2_2D TEST--070919.BIN]]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom[JCJ_H252608CT_SK3_CO6R_GI9.DB02_JCJ00_966D_C_V2_2D TEST--070919.BIN]_20080330-165033.B0E.bin flash: 04227E22212200:2BEA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: 04227E22212200:2BEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _140CB857_JCJ_H252608CT_SK3_CO6R_GI9.DB02_JCJ00_96 6D_C_V2_2DTEST--070919.BIN_52CCD78E_20080330-165139.B0X.bin Finished, time used: 416 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! COM5 [VCP0] selected Action: imei imei write method: mode-2 new imei: 352759010945603 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:C67E:E360 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: DB02_JCJ00_966D_C_V2.2DUXAR Version: JCJ_H252608CT_SK3_CO6R_GI9 detecting structure #2... 0done 44 byte(s) read imei: 13579024681122 connection Ok detecting structure #2... 0done 44 byte(s) read verification... verification done: 35275901094560 Finished, time used: 20 sec Remove/Install battery now ! ==== log opened: [30/03/2008 17:26:52] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v2.36 S/N: 10AF:010E Wait... Device: Autodetect 6205-6227 NOR Done WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? COM5 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: reset Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:C67E:E360 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 04227E22212200:2BEA0000000000 flash: Fujitsu AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: 04227E22212200:2BEA0000000000 flash: Fujitsu AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 04227E22212200:2BEA0000000000 flash: Fujitsu AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: 04227E22212200:2BEA0000000000 flash: Fujitsu AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.140CB857.[JCJ_H252608CT_SK3_CO6R_GI9.DB02_JCJ00_966D_C_V2_2D TEST--070919.BIN_52CCD78E].rpl identification#1 detection finished device-id: 140CB857 identification#1 protocol ver: 05 ver. sw1: JCJ_H252608CT_SK3_CO6R_GI9.DB02_JCJ00_966D_C_V2_2D TEST--070919.BIN ver. sw2: DB02_JCJ00_966D_C_V2.2DTEST, 712833AD ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 04227E22212200:2BEA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom[JCJ_H252608CT_SK3_CO6R_GI9.DB02_JCJ00_966D_C_V2_2D TEST--070919.BIN]]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom[JCJ_H252608CT_SK3_CO6R_GI9.DB02_JCJ00_966D_C_V2_2D TEST--070919.BIN]_20080330-174013.B0E.bin flash: 04227E22212200:2BEA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: 04227E22212200:2BEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _140CB857_JCJ_H252608CT_SK3_CO6R_GI9.DB02_JCJ00_96 6D_C_V2_2DTEST--070919.BIN_52CCD78E_20080330-174246.B0X.bin Finished, time used: 497 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! Loading file v.02... ==== log opened: [30/03/2008 17:50:52] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v2.36 S/N: 10AF:010E Wait... Device: Autodetect 6205-6227 NOR Done Loading file v.02... backup_eeprom[JCJ_H252608CT_SK3_CO6R_GI9.DB02_JCJ00_966D_C_V2_2D TEST--070919.BIN]_20080330-165033.B0E.bin loaded COM5 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: write NOR flash skip: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:C67E:E360 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 04227E22212200:2BEA0000000000 flash: Fujitsu AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: 04227E22212200:2BEA0000000000 flash: Fujitsu AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 04227E22212200:2BEA0000000000 flash: Fujitsu AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: 04227E22212200:2BEA0000000000 flash: Fujitsu AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.140CB857.[JCJ_H252608CT_SK3_CO6R_GI9.DB02_JCJ00_966D_C_V2_2D TEST--070919.BIN_52CCD78E].rpl identification#1 detection finished device-id: 140CB857 identification#1 protocol ver: 05 ver. sw1: JCJ_H252608CT_SK3_CO6R_GI9.DB02_JCJ00_966D_C_V2_2D TEST--070919.BIN ver. sw2: DB02_JCJ00_966D_C_V2.2DTEST, 712833AD ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 04227E22212200:2BEA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom[JCJ_H252608CT_SK3_CO6R_GI9.DB02_JCJ00_966D_C_V2_2D TEST--070919.BIN]]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom[JCJ_H252608CT_SK3_CO6R_GI9.DB02_JCJ00_966D_C_V2_2D TEST--070919.BIN]_20080330-175803.B0E.bin flash: 04227E22212200:2BEA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _140CB857_JCJ_H252608CT_SK3_CO6R_GI9.DB02_JCJ00_96 6D_C_V2_2DTEST--070919.BIN_52CCD78E_20080330-175819.B0X.bin Area: Eeprom/ffs flash: 04227E22212200:2BEA0000000000 Write: Eeprom/ffs detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Write Done Finalization... Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _140CB857_JCJ_H252608CT_SK3_CO6R_GI9.DB02_JCJ00_96 6D_C_V2_2DTEST--070919.BIN_52CCD78E_20080330-180154.B0X.bin Finished, time used: 590 sec Remove/Install battery now ! Loading file v.02... CM_Nokia-N73-1-RM-133_JCJ_H252608CT_SK3_CO6R_GI9[1].DB02_JCJ00_966D_C_V2_2DTEST--070919_16m_En_Ru_Fr_De_Id_Vn_Ar.B0M.bin loaded identification#1 protocol ver: 05 ver. sw1: JCJ_H252608CT_SK3_CO6R_GI9.DB02_JCJ00_966D_C_V2_2D TEST--070919.BIN ver. sw2: DB02_JCJ00_966D_C_V2.2DTEST, 712833AD You have loaded file with security features enabled. detecting languages... Languages: En Ru Fr De Id Vn Ar COM5 [VCP0] selected error: can't open COM5 COM5 ready COM5 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: write NOR flash write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:C67E:E360 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 04227E22212200:2BEA0000000000 flash: Fujitsu AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: 04227E22212200:2BEA0000000000 flash: Fujitsu AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 04227E22212200:2BEA0000000000 flash: Fujitsu AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: 04227E22212200:2BEA0000000000 flash: Fujitsu AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.140CB857.[JCJ_H252608CT_SK3_CO6R_GI9.DB02_JCJ00_966D_C_V2_2D TEST--070919.BIN_52CCD78E].rpl identification#1 detection finished device-id: 140CB857 identification#1 protocol ver: 05 ver. sw1: JCJ_H252608CT_SK3_CO6R_GI9.DB02_JCJ00_966D_C_V2_2D TEST--070919.BIN ver. sw2: DB02_JCJ00_966D_C_V2.2DTEST, 712833AD ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 04227E22212200:2BEA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom[JCJ_H252608CT_SK3_CO6R_GI9.DB02_JCJ00_966D_C_V2_2D TEST--070919.BIN]]... file saved: C:\Documents and Settings\redha\Bureau\backup_eeprom[JCJ_H252608CT_SK3_CO6R_GI9.DB02_JCJ00_966D_C_V2_2D TEST--070919.BIN]_20080330-181131.B0E.bin flash: 04227E22212200:2BEA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished security area#1 calculation... done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _140CB857_JCJ_H252608CT_SK3_CO6R_GI9.DB02_JCJ00_96 6D_C_V2_2DTEST--070919.BIN_52CCD78E_20080330-182140.B0X.bin Area: Firmware flash: 04227E22212200:2BEA0000000000 Write: Firmware detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Write Done Finalization... Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _140CB857_JCJ_H252608CT_SK3_CO6R_GI9.DB02_JCJ00_96 6D_C_V2_2DTEST--070919.BIN_52CCD78E_20080330-184602.B0X.bin Finished, time used: 2415 sec Remove/Install battery now |
04-01-2008, 12:07 | #7 (permalink) | |
No Life Poster Join Date: Sep 2003 Age: 43
Member: 39948 Status: Offline Thanks Meter: 68 | Quote:
note to you, always do a full backup before do any operation, because this is important, if something happen just write back the full backup. | |
04-01-2008, 14:48 | #8 (permalink) |
Member: 85151 Status: Offline Thanks Meter: 30 | phone is no network before i make format and infinity make automatique beckup and i mke beckup eeprom and full flash but the same prb i read one full flash from one N73 with the same firmware but no result the phone have a good screen befor iu make format |
04-02-2008, 09:36 | #10 (permalink) |
Member: 85151 Status: Offline Thanks Meter: 30 | PLEASE INFINITY as i tel u i allready restore beckups no result and read full flash from one phone with the same firmwair but my prb is not solved ;;;;; i m not new with china phones customer want his phone what can i do his phone is damaged |
04-02-2008, 11:43 | #11 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! well, as long as you are sure that this is your original version: JCJ_H252608CT_SK3_CO6R_GI9.DB02_JCJ00_96 6D_C_V2_2DTEST--070919 and flsah file from support not help: flashfiles/ChineseMiracle/_MT6226/CM_Nokia-N73-1-RM-133_JCJ_H252608CT_SK3_CO6R_GI9.DB02_JCJ00_966D_C_V 2_2DTEST--070919_16m_En_Ru_Fr_De_Id_Vn_Ar.B0M.bin then, if this is software problem, for sure must help full backup downloaded from other phone. can you upload this flash file (which you said you used also) to www.rapidshare.com i will check this file |
04-03-2008, 10:05 | #12 (permalink) |
Member: 85151 Status: Offline Thanks Meter: 30 | ok master this is the link with flash readed from one worked phonehttp://rapidshare.com/files/10449491...61324.B0M.html |
04-03-2008, 22:18 | #13 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! i just checked file- it looks normal. by my oppinion- if phone with original backup written and also with another working dump still show empty LCD- it is time to check phone's hardware |
04-04-2008, 07:39 | #14 (permalink) | |
No Life Poster Join Date: Nov 2005 Location: .:GSM WORLD:.
Member: 203158 Status: Offline Sonork: 100.1592032 Thanks Meter: 358 | Quote:
bro Never do N73 Rm-133 Complete format FFS... u will have this white screen.... i have tried many of them ... always do safe format FFS.. as infinty peoples told u so .. do safe format FFS first ... and do write ur old eeprom . it will get ur phone to original position ..and then u can make safe format ... | |
Nokia N73-1 RM-133 mmc problem | irfaN_vu | Chinese Models & Cloned Phones | 1 | 08-27-2008 17:40 |
CM N73-RM-133 problem | dexter_mn | Infinity-Box | 1 | 11-29-2007 19:41 |
Need help: N73 RM-133 APAC 2.0628.0.0.1 v1.0 | azure.tu | Nokia Base Band 5 ( BB-5 ) | 0 | 09-12-2006 07:19 |
