03-28-2009, 16:03 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Location: Land of Lakes and Volcanoes Age: 51
Member: 111014 Status: Offline Thanks Meter: 132 | Nokia N98+ Supported ? Thanks in advance. |
03-28-2009, 16:06 | #2 (permalink) |
Freak Poster Join Date: Mar 2006 Location: morocco Age: 39
Member: 243158 Status: Offline Thanks Meter: 25 | hello! lets start from checking what CPU it is based. you either can do this by disassembling phone or by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software |
03-28-2009, 19:26 | #3 (permalink) | |
Member: 111014 Status: Offline Thanks Meter: 132 | Quote:
Thanks in advance | |
03-29-2009, 21:10 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! i would advice to use pinfinder, but if you dont have i can teach how to find pinout using multimeter |
03-30-2009, 15:38 | #6 (permalink) | |
thanks | |
03-30-2009, 20:36 | #7 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! 1. set multimeter to voltage measuring. 2. check bettery voltage, it should be more than 3,7volts 3. set one multimeter probe to some grounded phone part (if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal) 4. with second probe touch one by one all phone pins (phone battery attached, will work on powered phone as well as not powered_On) (to get better result i would advice to set needle on the end of second probe) memorise pins with voltage between 2,7-2,9volts. those are tx/rx |
nokia n98 tv mobile | yacine ben | Infinity-Box | 1 | 04-14-2008 17:51 |
