01-29-2020, 02:48 | #1 (permalink) |
Freak Poster Join Date: Feb 2009 Location: AmEriCa
Member: 977012 Status: Offline Thanks Meter: 28 | Nokia TA-1127 successful repair dm-verity error Setting : UserData preserve : False Setting : Flash Pre-Erase : True Setting : Bootloader update : True 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek USB Port (COM57) MODE : BOOTROM PORT : 57 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 TYPE : MODERN RAPHAEL BROM : DSLevel : DEV_KEY+DEV_ARB BROM : BOOTROM BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 0000 0000 V0: 0000 0000 [0001] BROM : SOCID : 088F4E67DBAB7E42AE27D1D34C0BA063F9C28C474633BCC9B4 D517C408F76A2A AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6739 AGENT : BEST_Nokia_DA_v19_1711_06 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] EMMC: 700100464D414545382026509FE756DB EMMC: VEN : KINGSTON | OEM : 01 | DEV : FMAEE8 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A8000000 [ 14.63 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : C0933648B1C754EA4E637E2FFBE5B632 DA : USB : HIGH-SPEED Boot done! DL_INFO : PMT present SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : HW verification passed! Erase : 0x0000000000000000 : 0x0000000002000000 Erase : 0x0000000002800000 : 0x0000000004000000 Erase : 0x0000000007800000 : 0x0000000000800000 Erase : 0x000000000B300000 : 0x0000000000800000 Erase : 0x000000000C440000 : 0x00000000003C0000 Erase : 0x000000000CA80000 : 0x0000000005200000 Erase : 0x0000000012180000 : 0x0000000000200000 Erase : 0x00000000123A0000 : 0x00000000B5C60000 PMT Update : OK Flashing now ... PROCESS : PRELOADER Unpack : ANT-0-0750-00WW-1-1-preloader_ANT.bin Flash : ANT-0-0750-00WW-1-1-preloader_ANT.bin Update bootloader backup copy ... Update bootloader backup copy Ok! PROCESS : RECOVERY Unpack : ANT-0-0750-00WW-1-1-recovery.img Flash : ANT-0-0750-00WW-1-1-recovery.img PROCESS : MD1IMG Unpack : ANT-0-0750-00WW-1-1-md1img.img Flash : ANT-0-0750-00WW-1-1-md1img.img PROCESS : MD1DSP Unpack : ANT-0-0750-00WW-1-1-md1dsp.img Flash : ANT-0-0750-00WW-1-1-md1dsp.img PROCESS : SPMFW Unpack : ANT-0-0750-00WW-1-1-spmfw.img Flash : ANT-0-0750-00WW-1-1-spmfw.img PROCESS : MCUPMFW Unpack : ANT-0-0750-00WW-1-1-mcupmfw.img Flash : ANT-0-0750-00WW-1-1-mcupmfw.img PROCESS : LK Unpack : ANT-0-0750-00WW-1-1-lk.img Flash : ANT-0-0750-00WW-1-1-lk.img PROCESS : LK2 Unpack : ANT-0-0750-00WW-1-1-lk.img Flash : ANT-0-0750-00WW-1-1-lk.img PROCESS : LOADER_EXT1 Unpack : ANT-0-0750-00WW-1-1-loader_ext.img Flash : ANT-0-0750-00WW-1-1-loader_ext.img PROCESS : LOADER_EXT2 Unpack : ANT-0-0750-00WW-1-1-loader_ext.img Flash : ANT-0-0750-00WW-1-1-loader_ext.img PROCESS : BOOT Unpack : ANT-0-0750-00WW-1-1-boot.img Flash : ANT-0-0750-00WW-1-1-boot.img PROCESS : LOGO Unpack : ANT-0-0750-00WW-1-1-logo.bin Flash : ANT-0-0750-00WW-1-1-logo.bin PROCESS : DTBO Unpack : ANT-0-0750-00WW-1-1-dtbo.img Flash : ANT-0-0750-00WW-1-1-dtbo.img PROCESS : TEE1 Unpack : ANT-0-0750-00WW-1-1-tee.img Flash : ANT-0-0750-00WW-1-1-tee.img PROCESS : TEE2 Unpack : ANT-0-0750-00WW-1-1-tee.img Flash : ANT-0-0750-00WW-1-1-tee.img PROCESS : VENDOR Unpack : ANT-0-0750-00WW-1-1-vendor.img Flash : ANT-0-0750-00WW-1-1-vendor.img PROCESS : SYSTEM Unpack : ANT-0-0750-00WW-1-1-system.img Flash : ANT-0-0750-00WW-1-1-system.img PROCESS : CACHE Unpack : ANT-0-0750-00WW-1-1-cache.img Flash : ANT-0-0750-00WW-1-1-cache.img PROCESS : USERDATA Unpack : ANT-0-0750-00WW-1-1-userdata.img Flash : ANT-0-0750-00WW-1-1-userdata.img PMT Update : OK SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 Flashing finished! Done! Elapsed: 00:03:40 Reconnect Power/Cable! You must download firmware from support !!!! Good work infinity team |
The Following 3 Users Say Thank You to unlockmoto For This Useful Post: |
05-25-2020, 23:41 | #2 (permalink) |
No Life Poster Join Date: Jun 2014 Location: Bolivia
Member: 2202707 Status: Offline Sonork: whatsapp +59170073722 Thanks Meter: 212 | great work infinity team.... I could not find the software in the support, I looked in the nokia folder and with the search engine ta-1127 but I did not find results. in google I was able to find the software I used and I could fix my problem dm-verity error Operation : Write FW [ v1.20 ] Setting : UserData preserve : False Setting : Flash Pre-Erase : True Setting : Bootloader update : True 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM46) MODE : PRELOADER PORT PORT : 46 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 TYPE : MODERN RAPHAEL BROM : DSLevel : DEV_KEY BROM : PRELOADER PORT BROM : SOCID : FE5C3EB64EEB042F6046BDF3C58DDA2007A5BA34675887C32A 3452A80254A384 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6739 AGENT : BEST_Nokia_DA_v19_1711_06 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00020000 [ 128,00 KB ] DRAM: 0x40000000 [ 1,00 GB ] EMMC: 700100464D41454538201E28CCA06613 EMMC: VEN : KINGSTON | OEM : 01 | DEV : FMAEE8 EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0x3A8000000 [ 14,63 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 3441812313C71FD5F7ECE6D4A36627D2 DA : USB : HIGH-SPEED Boot done! DL_INFO : PMT present SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : HW verification passed! Erase : 0x0000000000000000 : 0x0000000002000000 Erase : 0x0000000002800000 : 0x0000000004000000 Erase : 0x0000000007800000 : 0x0000000000800000 Erase : 0x000000000B300000 : 0x0000000000800000 Erase : 0x000000000C440000 : 0x00000000003C0000 Erase : 0x000000000CA80000 : 0x0000000005200000 Erase : 0x0000000012180000 : 0x0000000000200000 Erase : 0x00000000123A0000 : 0x00000000B5C60000 PMT Update : OK Flashing now ... PROCESS : PRELOADER Unpack : ANT-0-0980-00WW-preloader_ANT.bin Flash : ANT-0-0980-00WW-preloader_ANT.bin Update bootloader backup copy ... Update bootloader backup copy Ok! PROCESS : RECOVERY Unpack : ANT-0-0980-00WW-recovery.img Flash : ANT-0-0980-00WW-recovery.img PROCESS : MD1IMG Unpack : ANT-0-0980-00WW-md1img.img Flash : ANT-0-0980-00WW-md1img.img PROCESS : MD1DSP Unpack : ANT-0-0980-00WW-md1dsp.img Flash : ANT-0-0980-00WW-md1dsp.img PROCESS : SPMFW Unpack : ANT-0-0980-00WW-spmfw.img Flash : ANT-0-0980-00WW-spmfw.img PROCESS : MCUPMFW Unpack : ANT-0-0980-00WW-mcupmfw.img Flash : ANT-0-0980-00WW-mcupmfw.img PROCESS : LK Unpack : ANT-0-0980-00WW-lk.img Flash : ANT-0-0980-00WW-lk.img PROCESS : LK2 Unpack : ANT-0-0980-00WW-lk.img Flash : ANT-0-0980-00WW-lk.img PROCESS : LOADER_EXT1 Unpack : ANT-0-0980-00WW-loader_ext.img Flash : ANT-0-0980-00WW-loader_ext.img PROCESS : LOADER_EXT2 Unpack : ANT-0-0980-00WW-loader_ext.img Flash : ANT-0-0980-00WW-loader_ext.img PROCESS : BOOT Unpack : ANT-0-0980-00WW-boot.img Flash : ANT-0-0980-00WW-boot.img PROCESS : LOGO Unpack : ANT-0-0980-00WW-logo.bin Flash : ANT-0-0980-00WW-logo.bin PROCESS : DTBO Unpack : ANT-0-0980-00WW-dtbo.img Flash : ANT-0-0980-00WW-dtbo.img PROCESS : TEE1 Unpack : ANT-0-0980-00WW-tee.img Flash : ANT-0-0980-00WW-tee.img PROCESS : TEE2 Unpack : ANT-0-0980-00WW-tee.img Flash : ANT-0-0980-00WW-tee.img PROCESS : VENDOR Unpack : ANT-0-0980-00WW-vendor.img Flash : ANT-0-0980-00WW-vendor.img PROCESS : SYSTEM Unpack : ANT-0-0980-00WW-system.img Flash : ANT-0-0980-00WW-system.img PROCESS : CACHE Unpack : ANT-0-0980-00WW-cache.img Flash : ANT-0-0980-00WW-cache.img PROCESS : USERDATA Unpack : ANT-0-0980-00WW-userdata.img Flash : ANT-0-0980-00WW-userdata.img PMT Update : OK SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 Flashing finished! Done! Elapsed: 00:01:18 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to tomelich For This Useful Post: |
05-29-2020, 11:13 | #3 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Dear Sirs, If you have good flash files and if you want to share it with other users please use IOS File Uploader Tool Please do not upload password protected or damaged files, all of them will be deleted after upload. Thank you ! |
