Old 03-21-2010, 13:37   #1 (permalink)
Member: 752540
Thanks Meter: 18
not calibrated
i hav a fome chinese model f8 it shows not calibrated on power on. i have complete format it bt sama condition. plz give solution sir
Old 03-21-2010, 14:29   #2 (permalink)
Member: 1043909
Thanks Meter: 60,926
Hi,
Did you tried to calibrate touchscreen manually after you power-on phone w/o sim card ?
Old 03-21-2010, 15:38   #3 (permalink)
Member: 752540
Thanks Meter: 18
not calibrated
sir this not a touch scren phone.
Old 03-21-2010, 16:02   #4 (permalink)
Member: 1043909
ok, but what is not calibrated text ?
need more informatuion
Old 03-21-2010, 17:24   #5 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
After safe format the phone (Sigmatel S88) displays text -"Not Calibrated" on the screen and it doesn't ask for calibration manually like usually every phone asks to do with pen. The problem is even after trying all calibration methods with Infinity the problem remains same.
Wr.
Old 03-22-2010, 04:39   #6 (permalink)
Member: 752540
Thanks Meter: 18
D386_pcb01_gprs_mt6223_s00.sw_v00_03_yidalong.bin
Old 03-22-2010, 20:46   #7 (permalink)
Member: 1043909
http://forum.gsmhosting.com/vbb/f425...brated-957697/
Old 04-26-2010, 23:03   #8 (permalink)
Member: 764516
Thanks Meter: 55
Originally Posted by YellowBoss View Post
Between could you Help !
I want Chinese blackberry 9000 working Pinouts
Thanks
Old 04-27-2010, 14:03   #9 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
lets start from checking what CPU it is based.
you either can do this by disassembling phone or by typing *#0044# and pressing green (send) button.
if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software
If it does supported, and you dont have infinity Pinfinder- i can teach how to find pinout in minutes.
Just by measuring voltage on phone system connector pins.
Old 04-28-2010, 12:08   #10 (permalink)
Member: 764516
Thanks Meter: 55
@InfinityHelp
Yes ,i want to know how to find pinout for this bb 9000
by voltage measuring on phone system connector pins .
Thanks
Old 04-28-2010, 12:09   #11 (permalink)
Member: 764516
Thanks Meter: 55
@InfinityHelp
Big Thanks
in advance
Old 04-28-2010, 12:23   #12 (permalink)
Member: 752540
Thanks Meter: 18
module v3.11
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: reset settings ("format ffs")
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
high speed boot On
chip: 0011:4390:000C
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 2088C4FFFFFFFF:2088C400000000
flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb
otp offset: 00FE0000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [standard] generation
TCL-ID is absent
rom info detection finished
New firmware detected (v.3.11, database date: 18.03.2010):
D386_PCB01_GPRS_MT6223_S00.SW_V00_03_YIDALONG.BIN
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
rom info ver: 07
sw version: D386_PCB01_GPRS_MT6223_S00.SW_V00_03_YIDALONG.BIN
project-id: D386.SW.V00.03.YIDALONG, 00000000
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: D386_PCB01_GPRS_MT6223_S00.SW_V00_03_YIDALONG__ffs ...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\D386_PCB01_GPRS_M T6223_S00.SW_V00_03_YIDALONG__ffs_20100428-164559.B0E.bin
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
Finished, time used: 4 min 52 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 04-29-2010, 22:59   #13 (permalink)
Member: 148515
hello!
1. set multimeter to voltage measuring.
2. power Onphone
3. set one multimeter probe to some grounded phone part
(if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal)
4. with second probe touch one by one all phone pins (phone must be powered On)
(to get better result i would advice to set needle on the end of second probe)
memorise pins with voltage between 2,7-2,9volts.
those are tx/rx
Old 04-30-2010, 11:32   #14 (permalink)
akashub's Avatar
Member: 750001
Sonork: 100.1641021
Thanks Meter: 1,269
her is the solution bro link
The Following User Says Thank You to akashub For This Useful Post:
Old 05-08-2010, 03:10   #15 (permalink)
cellexpert's Avatar
Member: 857876
Sonork: cellexpert-33
Thanks Meter: 63
this is tested 100% working eeprom, (use by infinity) i have done many sets by this file. don't forget press thanks button.
The Following User Says Thank You to cellexpert For This Useful Post:
pls help: Error : box is not calibrated freddy black DreamBox 1 03-28-2008 13:30
Error: Box is not Calibrated livewirecebu DreamBox 1 03-24-2008 12:31
I can not calibrate box at all............ The Repair Shop UST Pro II 15 11-02-2007 01:56
Error : You use not calibrated device ocelular DreamBox 10 04-24-2007 15:04
Help Still Can Not Calibrate Ust Pro 2 AbdulKadir UST Pro II 1 03-20-2006 14:53
Page generated in 0.25165 seconds with 9 queries
