12-07-2008, 15:41 | #1 (permalink) |
No Life Poster Join Date: Nov 2008 Location: gsm hosting
Member: 907098 Status: Offline Sonork: 100.1601140 Thanks Meter: 705 | this is not good infinity module v1.57 Device: ZTE-225, Vodafone-225 Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 00BF:7353 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... backup critical area Done Check memory ... Check memory Done Write ... reset... done Erasing: Firmware error: erase failed: 00400000 Write Failed Finished, time used: 24 sec Remove/Install battery now !]]]]]]]]]]]] |
12-07-2008, 15:50 | #2 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Kamalia, Pakistan. Age: 38
Member: 151871 Status: Offline Thanks Meter: 71,421 | 1st of all for one Qua. do not create new threads , and what is not good ? Infinity Box is the one of BEST boxes witch have 0.01 % bugs so whats BAD ? and about your problem , check bettery must be full when you start flashing , and also possible DAMAGE flash chip need to reball or just Reheat ..... check it post results BR Faisal_Computer |
12-07-2008, 15:55 | #3 (permalink) |
Freak Poster Join Date: May 2005 Age: 45
Member: 144091 Status: Offline Thanks Meter: 73 | before you conclude that something is wrong kindly try to other boxes so you'll know it's truly SW problem. Now do it in infinity. now please check battery, check cable, etc... |
12-07-2008, 15:55 | #4 (permalink) | |
No Life Poster Join Date: Jun 2005 Location: Ghana Age: 39
Member: 153893 Status: Offline Thanks Meter: 266 | Quote:
12-08-2008, 05:16 | #8 (permalink) |
Member: 907098 Status: Offline Sonork: 100.1601140 Thanks Meter: 705 | no my battrey is ok and fully charg you say that flash chip bad no no because [with out sim work fine when insert sim then phone is restart posiotion ] then i try flashing throught infinity my phone is dead then i post u ------what is my mistek {my phone have sst cpu} |
12-08-2008, 06:51 | #10 (permalink) |
Member: 151871 Status: Offline Thanks Meter: 71,421 | hi Man , i am using infinity since its released and i have no any problem like you ever , and Erasing: Firmware error: erase failed: 00400000 Write Failed its mean problem in hardware , Please do what i said in my 1st post of this thread. try and post results . just reball it or rehot BR Faisal_Computer |
12-08-2008, 16:01 | #12 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Hello, If you have problem with flashing you can try to flash phone like other models from this module. it may be that this flash type can be flashed like other model. |
12-09-2008, 05:22 | #13 (permalink) |
No Life Poster Join Date: Sep 2006 Location: 102 quy nhơn BĐ Age: 14
Member: 347720 Status: Offline Sonork: xxx Thanks Meter: 204 | if phone hang on or auto restart u try flash sw got error, phone will die bicu hw dmg u need fix hw and flash again,phone live again my story china mp4,phone die boot by spider dun see ic flash and it can fotmat by infinity but got error fail address, only need rehot ic flash, phone power on,sw for check problem hw |
Mr. Raskal and Cinek, how come Zulea always cracked your update, this is not good | mymiela0419 | JAF No Tp Unlocker by Cinek | 6 | 04-03-2009 07:01 |
this is not good for SagMaster | mzbrd | SagMaster Team OLD Products | 4 | 03-24-2006 09:50 |
**** mann this is not good only nokia:( | senkron24 | Phoenix Black Box | 1 | 08-08-2005 17:29 |
