05-23-2018, 11:11 | #1 (permalink) |
No Life Poster Join Date: Nov 2007 Location: United State Of Islam Age: 34
Member: 624551 Status: Offline Sonork: 100.1584837 Thanks Meter: 737 | not supported ID_BLOCK_I : SnapDragon 410 [MSM8916] ID_BLOCK_I : SnapDragon 410 [MSM8916] unsupported |
07-13-2018, 12:34 | #3 (permalink) |
Freak Poster Join Date: Aug 2005 Age: 44
Member: 174065 Status: Offline Thanks Meter: 5 | oppo not suported in cm2 v1.16 Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 410 [MSM8916] ID_BLOCK_S : 23DBD08E ID_BLOCK_L : 1BED877FDE44717C2B00F0DD1A61F1D9 ID_BLOCK_L : B6CD73DADF46E87D905F30E9FB0A2427 Use CM2 Internal Loader FH_LOAD_CODE : 15 ERROR : Loader send failed! HINT : Check cable, connection and drivers! |
07-13-2018, 16:57 | #6 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Hello, Oppo A37f and a37Fw both r supported in cm2,, wht is ur mobile condition here is the logs Code: Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 410 [MSM8916] ID_BLOCK_S : 2595D4DF ID_BLOCK_L : E41C76802FBBA0A39CF1030CCB961E2E ID_BLOCK_L : 4C07892015BC2EA75A95FE373DF0EEED Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Brand : OPPO ProdName : A37f ProdModel : A37f Device : A37f AndroidVer: 5.1.1 SWVersion : A37fEX_11.A.18_INT_018_201703281213 Manufact. : OPPO SysPatch : LMY47V DevComTime: 28-03-2017 AM 6:19:41 QLMxCPU : MSM8916 USERData : NORMAL GCSec : EMPTY Done! Elapsed: 00:00:20 |
