02-05-2019, 07:45 | #1 (permalink) |
Junior Member Join Date: Jan 2019 Location: Nawabshah
Member: 2888365 Status: Offline Thanks Meter: 47 | OALE X2 MT6580 After Flash Display Problem Any One Helpe. OALE X2 MT6580 After Flash Display Problem Any One Helpe. Inital Boot Ok! Iftikhar-Ahmed BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 1501003030434E5630011504081481CB Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , 0VNC0 [eMMC] : FLASH_CID : 1501003030434E5630011504081481CB [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x1D70FD227D7209B170678339C29C719A INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6580 , Project : gxq6580_weg_l , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : Only one records found, and determined as universal BL : eMMC supported by BootLoader! BL : BatteryLevel : 3246 mV BL : [WARNING] : BatteryLevel LOW!!! BL : Flash Pre-Erase Total blocks to Erase : 1 Erase : 0x0000000001C80000-0x00000000D8B80000 Flash Pre-Erase Done, time used : 00:00:00 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_gxq6580_weg_l.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0014 Update PMT by user request [SpecOp] : Extend UserArea Repartition Done! Use FLN Mode Processing : Flash Write Flash now : LK Image Flash Ok Flash now : BOOT Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : SECRO Image Flash Ok Flash now : SYSTEM Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USERDATA Image Flash Ok Flash Write Done, time used : 00:03:35 Processing : Verify Verify Passed : LK Verify Passed : BOOT Verify Passed : RECOVERY Verify Passed : LOGO Verify Passed : SECRO Verify Passed : SYSTEM Verify Passed : CACHE Verify Passed : USERDATA Data Verify Done, time used : 00:00:04 Update Mirror PMT [SpecOp] : Extend UserArea Update Done! Update RomInfo done Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 1501003030434E5630011504081481CB Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , 0VNC0 [eMMC] : FLASH_CID : 1501003030434E5630011504081481CB [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x1D70FD227D7209B170678339C29C719A INT RAM : 0x00020000 Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 1501003030434E5630011504081481CB Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , 0VNC0 [eMMC] : FLASH_CID : 1501003030434E5630011504081481CB [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x1D70FD227D7209B170678339C29C719A INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Processing Miscellaneous test MSC : BatteryLevel : 3244 mV [Processing] FlashMemory Read-Write test [eMMC] : [SAMSUNG] , 0VNC0 , 0x1D2000000 , 7456 MiB [eMMC] : CID : 1501003030434E5630011504081481CB [eMMC] : MODE : SQ-WR [PASSED] : eMMC RW Check #1 Ok! [eMMC] : MODE : RA-WR [PASSED] : eMMC RW Check #2 Ok! [eMMC RO CHECK] : eMMC Ok! READ-WRITE Passed! [Processing] RAM Read-Write test [DRAM] : 0x20000000 , 512 MiB [DRAM] : ADDRESS BUS test [PASSED] : Bus Count : 0x1C [DRAM] : DATA BUS test [PASSED] : Bus Count : 0x1F [DRAM] : PATTERN test [PASSED] : PATTERN Ok [DRAM] : INCDEC test [PASSED] : INCDEC Ok All Done! Done! Elapsed: 00:01:37 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to Iftikhar-Ahmed For This Useful Post: |
02-05-2019, 08:01 | #2 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Quote: |
The Following User Says Thank You to Kirumira For This Useful Post: |
05-21-2019, 12:56 | #3 (permalink) |
Freak Poster Join Date: Sep 2008 Location: Multan Pakistan Age: 49
Member: 872681 Status: Offline Sonork: 1680923 Thanks Meter: 52 | bhai kya aap ko is ki ok file mili? ager nahi mili to reply me i have for this ok file |
The Following User Says Thank You to skynumber For This Useful Post: |
05-21-2019, 13:00 | #5 (permalink) |
Member: 872681 Status: Offline Sonork: 1680923 Thanks Meter: 52 | Quote: aap ko is problem ko theek kerne wali file mili ya nahi? ager nahi mili to mujh se rabata krain i have ok file for this |
05-22-2019, 00:03 | #6 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,784 | Quote:
Read forum rules before posting. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
06-03-2019, 18:12 | #9 (permalink) | |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Quote: Bro Not Work X2 File I Need This File Code: Build ID: LMY47I Display ID: Z6U190HFB_V017En Version: 5.1 Build Date: Mon Feb 5 10:46:39 CST 2018 Model: gxq6580_weg_l Brand: alps Device: gxq6580_weg_l Manufacturer: alps Region: US | |
06-03-2019, 19:48 | #10 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: Pakistan
Member: 116955 Status: Offline Sonork: 100.1604268 Thanks Meter: 992 | Quote:
https://drive.google.com/file/d/1D_3...ew?usp=sharing | |
The Following 3 Users Say Thank You to sahassan82 For This Useful Post: |
