GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   Infinity-Box (https://forum.gsmhosting.com/vbb/f296/)
-   -   Ofp file to scatter file problem (https://forum.gsmhosting.com/vbb/f296/ofp-file-scatter-file-problem-2457635/)
Preadtrum 08-26-2018 02:42
I am cm2 user
I want convert oppo file realme1 ofp file to scatter
Urgent
kamal_singla 08-26-2018 05:58
Originally Posted by Preadtrum (Post 13284637)
I am cm2 user
Urgent
hi
ofp extraction not supported
some of tool supported extract ofp but useless for other tool
better try to read working set file with cm2 and flash in your faulty set(w/o LK and Preloader) or can take help from nearest oppo authorized service center
PASSIONATE_BOYS 08-26-2018 16:02
I am cm2 user
Urgent
Hello,
RealMe1 CPH1859EX firmware already on support, read with CM2MT2. Download and flash it.
About .ofp extraction feature we have it in to-do list already.
Br.
Infinity Box Team.
Preadtrum 08-26-2018 17:28
after flash CPH1859EX my set dead
VIJAY2U2 08-26-2018 17:31
U just ignore this warning by kamal_singla
@ndoy 09-05-2018 04:27
Originally Posted by PASSIONATE_BOYS (Post 13285500)
Hello,
Br.
Infinity Box Team.
I also need this OFP Extraction features for flash in CM2MT2!
tikourine 03-25-2019 22:27
Operation : Reset Settings/Format FS [ v2.05 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MTK USB Port (COM10)
MODE : BOOTROM
PORT : 10
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001
TYPE : MODERN RAPHAEL
BROM : SecLevel : 0x00000005
BROM : SecMode : SBC+SDA
BROM : BOOTROM
MODE : 0_base : BASE_v1712 | Manual : Enabled
BROM : SLA
BROM : SLA Passed!
BROM : SLA CHLNG not used
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6755
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : 0x00007024 : DA SEND ERROR!
ERROR : SECURE BOOT : SELECTED DA NOT SUPPORTED IN CURRENT DEVICE STATE!
INFO : BROM Level : CERT/AUTH required! Try boot device in PRELOADER mode with select PL/PL_CRYPTO/SWSEC type!
Error : Fail to init protocol!
Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation!
Reconnect Power/Cable!
Operation : Identify [ v2.05 ]
MODE : BOOTROM
PORT : 10
BROM : Init BROM
BROM init passed!
BROM : BOOTROM
BROM : SLA
BROM : SLA Passed!
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
DA : EXT_RAM NOT initialized!
EMI : DEV : INFINITY
EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0
EMI : CNT : 0008
EMI : Init EMI from INTERNAL DB
DA : SETUP EMI PARAMS FAILED!
ERROR : ABORT
Internal EMI : Select other EMI number! External Preloader - make sure it correct for connected device!
MODE : BOOTROM
PORT : 10
BROM : Init BROM
BROM init passed!
BROM : BOOTROM
BROM : SLA
BROM : SLA Passed!
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : CNT : 0008
ERROR : ABORT
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.10132 seconds with 6 queries
