Old 10-07-2011, 08:16   #1 (permalink)
Member: 1315046
Thanks Meter: 36
Error while unlocking Cordless FGD 8900
Please help me, i'm using P - 05A Cable of pinfinder.
COM18 [Serial2] selected
module v4.01
Device: _Autodetect MT6205-6239 NOR
Checking data, wait...
Action: "sp-unlock"
unlock method: standard fast
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6205:8B00]...
CPU: MT6205
high speed boot On
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 01227E220A2201:18E59F00000000
flash: Amd AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb
otp offset: 00000000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
detecting chip #04 in region #00...
detecting chip #05 in region #00...
detecting chip #06 in region #00...
detecting chip #07 in region #00...
detecting chip #08 in region #00...
detecting chip #09 in region #00...
detecting chip #0A in region #00...
detecting chip #0B in region #00...
detecting chip #0C in region #00...
detecting chip #0D in region #00...
detecting chip #0E in region #00...
detecting chip #0F in region #00...
number of flash chip/regions detected: 10/01
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
interesting cpu type found
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 00400000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
warning: rom info information not found, possible reasons:
- old firmware type w/o rom info information
- empty (completely or partially erased) flash chip
- damaged firmware
- damaged hardware (bad soldered or damaged flash chip)
> if phone works fine just ignore this warning <
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset assigned: 00380000
standard ffs/eeprom offset confirmed: 00380000
detecting ffs/eeprom size...
ffs/eeprom size: 00080000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00380000-003FFFFF
firmware area: 00000000-0037FFFF
detecting startup code area #2...
startup code area #2 is absent
detecting ffs/eeprom structure pass 1...
ffs/eeprom: detect std location pass #1...
ffs/eeprom: detect standard offset pass #1...
ffs/eeprom record offset detected
ffs/eeprom: detect standard data...
ffs/eeprom record size detected
ffs/eeprom layout detection complete
error: ffs/eeprom detection failed: element #1
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
Backup required data Done
====> Patch required data ...
Patch required data Fail
Finished, time used: 55 sec
Remove/Install battery now !
Old 10-07-2011, 10:27   #2 (permalink)
Member: 1315046
Thanks Meter: 36
COM6 [VCP0] selected
module v4.01
Device: Airtel-Cordless-FGD8900
Action: "sp-unlock"
Warning ! After unlock process finished make this:
1. be sure that there is NO any SIM card in phone
2. press phone "Power" button and power-On phone
3. press phone "Power" button and power-Off phone
4. NOTE ! SIM card can be blocked during first power-On so use SIM card
that you ready to move to trash w/o problems !
5. now you can power-On phone with SIM card
Do you understand instruction and want to continue ?
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6205
high speed boot On
Boot Done
Initialize Done
====> Set baud ...
115200
Set baud Done
- damaged firmware
ffs/eeprom address can not be detected, value from database assigned: 00380000/00080000
lock area found
lock area found
Patch required data Done
====> Special operation ...
detecting parameters to apply patch area 1...
required data found
Write: area 1 (pass 1)
required data found
Write: area 1 (pass 2)
area 1 patch applied Ok
Special operation Done
====> Write ...
Write: lock-area-1
Write: lock-area-2
Write Done
====> Finalization ...
Finalization Done
Finished, time used: 1 min 14 sec
Thanx to infinity team my problem solved.
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
$50 Reward for unlocking my 6150!!! TheDon Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 03-23-2015 14:21
Page generated in 0.19636 seconds with 9 queries
