oppo a12 not boot. how to boot? tick ssla select brom only same ans. Load IDBase v729152 Ok! Operation : Identify [ v2.17 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM45) MODE : BOOTROM PORT : 45 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : C5C014810A9686F23F1046A2C5C16EF1 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2028 | Manual : Disabled BROM : SOCID : 17DD862D2B11FFEB83CDE4FD638EC626BAA322F635779CCDAB E792F858370437 BROM : SLA : Local Auth BROM : Selected Auth/Cert not accepted by device! >>> Check previous message for more info! Reconnect Power/Cable! |
click on hw report post result here also update data base add infinty ios acount data base wil update automatcly |
Username and password how to get for databe iOS ubdate |
downlod dongel manager read ios username pasword |
Check this tutorial for A12. https://forum.gsmhosting.com/vbb/f29...m2mt2-2941945/ |
Card found : 15162424 , v0147 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.17 Failed to prepare enivorment! Load IDBase v729152 Ok! Operation : HW Report [ v2.17 ] HWreport : Mode : eMMC 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM45) MODE : BOOTROM PORT : 45 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : C5C014810A9686F23F1046A2C5C16EF1 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v1944 | Manual : Disabled BROM : SOCID : 17DD862D2B11FFEB83CDE4FD638EC626BAA322F635779CCDAB E792F858370437 BROM : SLA : Local Auth BROM : Selected Auth/Cert not accepted by device! >>> Check previous message for more info! Reconnect Power/Cable! Info : LEGACY : HW reporting feature unavailable for current device! Done! Elapsed: 00:00:08 |
SELECT AUTOUPDATE IN CORE SETTING update data base add infinty ios acount data base wil update automatcly |
same problem boss ,win 7 32 bit not work.64bit maybe work |
Please, wait a bit for v2.18 release and you can do work under your system without any issue. We understanding about change win/set another copy or whatever else is always difficult and take lot of time and trying do all for best user expirience. |
