01-25-2021, 07:37 | #1 (permalink) |
Freak Poster Join Date: Aug 2018 Location: bagbari bogra dhaka bangladesh
Member: 2856614 Status: Offline Sonork: 100.650600 Thanks Meter: 252 | oppo a12 not boot. how to boot? tick ssla select brom only same ans. Operation : Identify [ v2.17 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM45) MODE : BOOTROM PORT : 45 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : C5C014810A9686F23F1046A2C5C16EF1 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2028 | Manual : Disabled BROM : SOCID : 17DD862D2B11FFEB83CDE4FD638EC626BAA322F635779CCDAB E792F858370437 BROM : SLA : Local Auth BROM : Selected Auth/Cert not accepted by device! >>> Check previous message for more info! Reconnect Power/Cable! |
01-25-2021, 10:09 | #5 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Pakistan
Member: 570093 Status: Offline Thanks Meter: 1,067 | Check this tutorial for A12. https://forum.gsmhosting.com/vbb/f29...m2mt2-2941945/ |
01-25-2021, 11:33 | #6 (permalink) | |
Member: 2856614 Status: Offline Sonork: 100.650600 Thanks Meter: 252 | Quote:
Card found : 15162424 , v0147 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.17 Failed to prepare enivorment! Load IDBase v729152 Ok! Operation : HW Report [ v2.17 ] HWreport : Mode : eMMC 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM45) MODE : BOOTROM PORT : 45 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : C5C014810A9686F23F1046A2C5C16EF1 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v1944 | Manual : Disabled BROM : SOCID : 17DD862D2B11FFEB83CDE4FD638EC626BAA322F635779CCDAB E792F858370437 BROM : SLA : Local Auth BROM : Selected Auth/Cert not accepted by device! >>> Check previous message for more info! Reconnect Power/Cable! Info : LEGACY : HW reporting feature unavailable for current device! Done! Elapsed: 00:00:08 | |
01-25-2021, 12:15 | #7 (permalink) | |
No Life Poster Join Date: Dec 2009 Location: pakistan
Member: 1189561 Status: Offline Thanks Meter: 743 | Quote:
SELECT AUTOUPDATE IN CORE SETTING update data base add infinty ios acount data base wil update automatcly | |
The Following User Says Thank You to M.AKHTER For This Useful Post: |
01-25-2021, 16:33 | #10 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Where you live
Member: 462970 Status: Offline Thanks Meter: 20,352 | Please, wait a bit for v2.18 release and you can do work under your system without any issue. We understanding about change win/set another copy or whatever else is always difficult and take lot of time and trying do all for best user expirience. |
The Following 2 Users Say Thank You to JayDi For This Useful Post: |
