03-16-2023, 14:00 | #1 (permalink) |
No Life Poster Join Date: Dec 2013 Location: England Manchester
Member: 2081860 Status: Offline Sonork: 100.1608350 Thanks Meter: 128 | Oppo A15 Can't boot why? Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X Mode: FLASH PORT: BROM ONLY [+] Read Deep info: PRL, HW, DEBUG [+] AutoEMI [+] FireFly UNI-Proto [+] Vendor-Specific Analyzer [+] Local SLA [-] Force BROM Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [Vol+ | Vol-] Waiting for device connection... User break Device not found 1. Check battery voltage 2. Change cable 3. Check USB drivers Reconnect Power/Cable now Operation: Identify Device [ v2.39a5 ] Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X Mode: FLASH PORT: BROM ONLY [+] Read Deep info: PRL, HW, DEBUG [+] AutoEMI [+] FireFly UNI-Proto [+] Vendor-Specific Analyzer [+] Local SLA [-] Force BROM Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port_V1632 (COM6) MODE: BOOTROM; PORT: 6 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM: Init passed CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: 5CF483ADF5CE1E3521CAA05FB2B2CEAC BROM: Sec Level: 0x00000000 Mode: PLAIN BROM: BROM|BL : 0x05|0xFE [BOOTROM] BROM: SOCID: 3BB0E3C2467D87723D6C228FDAC342009C0697353026F7C874 0524EAD9123BCC AGENT: 0_base: BASE_v2112 | Manual: Off [0656ff20] C:\InfinityBox\CM2MT2\boot\0_base\BASE_v2112\MTK_A llInOne_DA.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA: AGENT started DA: SYNC DA: MODE: BROM DA: EXT_RAM NOT initialized EMMC: CID: 150100445036384D4202F6D5C4B0A681 VEN: Samsung OEM: 0 ID: 445036384D42 [DP68MB] PRV: 0x02 SNN: 4141204656 [0xF6D5C4B0] MF: 10/2019 EMI: INFINITY PRELOADER_INFINITY_0 with 1 memory type(s) supported EMI: Init EMI from INTERNAL DB EMI: EXT_RAM CFG Passed DA: BOOT to 2nd DA... DA: 2ND stage confirmed DA: SYNC with DA passed DA: Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: CID: 150100445036384D4202F6D5C4B0A681 VEN: Samsung OEM: 0 ID: 445036384D42 [DP68MB] PRV: 0x02 SNN: 4141204656 [0xF6D5C4B0] MF: 10/2019 BOOT1: 0x00400000 [ 4.00 MB ] BOOT2: 0x00400000 [ 4.00 MB ] RPMB: 0x01000000 [ 16.00 MB ] USER: 0xE8F800000 [ 58.24 GB ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: A3F49499FB55B55F60DAF66714A59038 MEID: 5CF483ADF5CE1E3521CAA05FB2B2CEAC DA: USB: HIGH-SPEED Boot done [1] Reading... Ok Error: Failed to read initial info: Device Erased or Damaged It seems as something is wrong with device! 1. Check battery voltage and charge it! 2. Check is device hardware Ok Try again Reconnect Power/Cable now |
03-17-2023, 13:50 | #3 (permalink) | |
Member: 2081860 Status: Offline Sonork: 100.1608350 Thanks Meter: 128 | oppo A15 boot problem Quote:
Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X Mode: FLASH Port: BROM Only [+] Read Deep info: PRL, HW, DEBUG [+] Auto-EMI [-] FireFly UNI-Proto [+] Vendor-Specific Analyzer [+] Local SLA [-] Force BROM Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port_V1632 (COM6) MODE[0]: BOOTROM; PORT: 6 Waiting BOOT ACK... BROM: Skip ACK verify BROM: Init... Init passed MODE[0] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: 5CF483ADF5CE1E3521CAA05FB2B2CEAC BROM: Sec Level: 0x00000000 Mode: PLAIN VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 3BB0E3C2467D87723D6C228FDAC342009C0697353026F7C874 0524EAD9123BCC AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_A llInOne_DA.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Transfer control to DA... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 150100445036384D4202F6D5C4B0A681 VEN: Samsung OEM: 0 ID: 445036384D42 [DP68MB] PRV: 0x02 SNN: 4141204656 [0xF6D5C4B0] MM/YY: 10/2019 EMI: Init EMI by INTERNAL Database EMI: INFINITY PRELOADER_INFINITY_0 with 1 memory type(s) supported EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... SRAM: 0x0003A000 [ 232.00 Kb ] DRAM: 0xC0000000 [ 3.00 Gb ] EMMC CID: 150100445036384D4202F6D5C4B0A681 VEN: Samsung OEM: 0 ID: 445036384D42 [DP68MB] PRV: 0x02 SNN: 4141204656 [0xF6D5C4B0] MM/YY: 10/2019 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: A3F49499FB55B55F60DAF66714A59038 MEID: 5CF483ADF5CE1E3521CAA05FB2B2CEAC USB: HIGH-SPEED Boot done [1] Reading... Ok Fail to read partitions layout: Device Erased or Damaged It seems as something is wrong with device! 1. Check battery voltage and charge it! 2. Check is device hardware Ok Try again Reconnect Power/Cable now | |
03-22-2023, 10:28 | #5 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,531 | Quote:
