Old 01-25-2021, 12:37   #1 (permalink)
babarmughal's Avatar
Member: 2609063
Thanks Meter: 94
Oppo A1K success identify and format FS
Operation : Identify [ v2.17 ]
Mode : FLASH
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port (COM15)
MODE : BOOTROM
PORT : 15
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
CODE : Cervino
TYPE : MODERN RAPHAEL
BROM : MEID : 0ACABB93A6ADA5831DF244684B629E82
BROM : SecLevel : 0x000000E5
BROM : SecMode : SBC+SDA+EXT
BROM : BROM|BL : 0x05|0xFE
BROM : BOOTROM
MODE : 0_base : BASE_v2028 | Manual : Disabled
BROM : SOCID : 3062D7A1D61AA99AF89EC7E15D80F616E0BC82EF31123D49B6 87B57B0D530142
BROM : SLA : Local Auth
BROM : SLA : Auth Passed!
BROM : SLA : 0x0000001F
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6765
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
DA : EXT_RAM NOT initialized!
EMI : DEV : INFINITY
EMI : SRC : PRELOADER_INFINITY_0
EMI : CNT : 0003
EMI : Init EMI from INTERNAL DB
EMI : EXT_RAM CFG Passed!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
SRAM: 0x0003A000 [ 232.00 KB ]
DRAM: 0x80000000 [ 2.00 GB ]
EMMC: 150100514436334D4203C1989B7EB6B9
EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QD63MB
EMMC:
BOOT1 : 0x00400000 [ 4.00 MB ]
BOOT2 : 0x00400000 [ 4.00 MB ]
RPMB : 0x01000000 [ 16.00 MB ]
USER : 0x747C00000 [ 29.12 GB ]
CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : D4319ADBC4AF836F0D2641C30663B3B
DA : USB : HIGH-SPEED
Boot done!
Patch Level : PPR1.180610.011
Ver. CodeName : REL
Ver. Release : 9
Sec. Patch : 2020-10-05
Product Manfct : OPPO
Build Time : 09.10.2020
Product Brand : OPPO
Product Model : CPH1923
Product Info : CPH1923
Product Name : CPH1923
Product Device : OP486C
SW OTA Version : CPH1923EX_11.A.36_0360_202010092308
Display ID : CPH1923EX_11_A.36
Kernel Info : 4.9.117
USERDATA : FILESYSTEM : EXT4 with FBE ( File-Base Encryption )
STORAGE : LifeStatus : eMMC : OK!
Done!
Elapsed: 00:00:18
Operation : Reset Settings/Format FS [ v2.17 ]
Mode : SMART RESET
MODE : BOOTROM
PORT : 15
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : CNT : 0003
EMMC:
Boot done!
SmartInfo : 0x815757
Format Ok : USERDATA
Format Ok : CACHE
Format Ok : RESET PROTECTION
Done!
Elapsed: 00:00:27
Reconnect Power/Cable!
The Following 7 Users Say Thank You to babarmughal For This Useful Post:
Old 01-25-2021, 12:46   #2 (permalink)
Member: 730191
Sonork: AFRIDI
Thanks Meter: 8
oppo a1k not boot
oppo a1k not boot window 32 bit
Old 01-25-2021, 12:55   #3 (permalink)
Member: 2609063
Thanks Meter: 94
always post log man.... without logs no help.
Old 01-25-2021, 13:00   #4 (permalink)
Member: 730191
Sonork: AFRIDI
Thanks Meter: 8
Operation : HW Report [ v2.17 ]
HWreport : Mode : eMMC
PTFN : MediaTek USB Port (COM10)
MODE : BOOTROM
PORT : 10
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : MEID : 83A0DAE2B9A7085DEA13EE97FE04C945
BROM : BOOTROM
MODE : Oppo : A5s Shanto | Manual : Disabled
BROM : SOCID : 332787DD620FB7341756F308E40B44447FC9D5FEF00C757274 BD844BB06044EA
BROM : Selected Auth/Cert not accepted by device!
>>> Check previous message for more info!
Old 01-25-2021, 13:04   #5 (permalink)
Member: 2782345
Sonork: Not Use
Thanks Meter: 26
MODE : BOOTROM
PORT : 10
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : BOOTROM
Try To Tick SLA
Press And Hold Volium UP And DEown Button
Old 01-25-2021, 13:13   #6 (permalink)
Member: 730191
Sonork: AFRIDI
Thanks Meter: 8
oppo a1k not booting
already tick ssla which model seleted
Old 01-25-2021, 13:14   #7 (permalink)
Member: 2609063
Thanks Meter: 94
MODE : BOOTROM
PORT : 10
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : BOOTROM
brotehr... 1st complete on your mobile... then shutdown with poer key.. after shutdown, wiat 15 sec then press both vol and insert usb cable...
also see software hints
Old 01-25-2021, 13:48   #8 (permalink)
Member: 730191
Sonork: AFRIDI
Thanks Meter: 8
32bit not working
MODE : BOOTROM
PORT : 10
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : BOOTROM
Old 01-25-2021, 13:49   #9 (permalink)
Member: 730191
Sonork: AFRIDI
Thanks Meter: 8
MODE : BOOTROM
PORT : 10
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : BOOTROM
32BIT ISSUE BRO
Old 01-25-2021, 13:52   #10 (permalink)
asad_nomy7's Avatar
Member: 570093
Thanks Meter: 1,057
MODE : BOOTROM
PORT : 10
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : BOOTROM
Why you select Boot. Try with default boot.
Old 01-25-2021, 13:53   #11 (permalink)
asad_nomy7's Avatar
Member: 570093
Thanks Meter: 1,057
MODE : BOOTROM
PORT : 10
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : BOOTROM
Why you select Boot A5s Shanto . Try with default boot.
Old 01-25-2021, 13:57   #12 (permalink)
Member: 730191
Sonork: AFRIDI
Thanks Meter: 8
MODE : BOOTROM
PORT : 10
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : BOOTROM
ALREADY TEST SAME ISSUE YOUR WINDOW 32BIT OR 64 BIT
Old 01-25-2021, 16:38   #13 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 18,878
32 bit OS will be supported by Infinity CM2MT2 v2.18 in a short time
The Following User Says Thank You to JayDi For This Useful Post:
Old 01-25-2021, 16:48   #14 (permalink)
khalidsuper's Avatar
Member: 2620145
Thanks Meter: 274
Update ur dongle 2.18
will work
https://drive.google.com/file/d/1Vwv...ew?usp=sharing
Old 01-25-2021, 19:07   #15 (permalink)
Member: 148515
Thanks Meter: 17,782
You must install CM2MT2 v2.18 or higher !
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.35100 seconds with 7 queries
