07-02-2019, 12:32 | #1 (permalink) |
No Life Poster Join Date: Oct 2015 Location: Pakistan
Member: 2478233 Status: Offline Thanks Meter: 596 | Oppo a37fex after flash with a33f file now phone dead Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Read Flash [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... BREAK : Device not found! HINT : Check cable, connection and drivers! Reconnect Power/Cable! Operation : Read Flash [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 410 [MSM8916] ID_BLOCK_S : 0BAAB840 ID_BLOCK_L : 45BFD5218C1A0702FD52A2A36C37BF8F ID_BLOCK_L : 611CA20D0E91394A4FAEE3D82AC5D3F8 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB800000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Brand : OPPO ProdName : A37f ProdModel : A37f Device : A37f AndroidVer: 5.1.1 SWVersion : A37fEX_11.A.22_INT_022_201705221641 Manufact. : OPPO QLMxCPU : MSM8916 DevInfo : MSM8916__OPPO__OPPO__ANDR_v5.1.1__A37f__A37f__A37f __A37fEX_11.A.22_INT_022_201705221641 Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : NON-HLOS.bin [Read Ok] : sec.dat [Read Ok] : sbl1.mbn [Read Ok] : emmc_appsboot.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : hyp.mbn [Read Ok] : pnvbak.img [Read Ok] : lsplash.img [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : persist.img [Read Ok] : misc.img [Read Ok] : driver.iso [Read Ok] : reserve4.bin [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin [Read Ok] : gpt_main2.bin [Read Ok] : cdt.mbn [Read Ok] : gpt_backup2.bin Android Info saved! Read finished! Configuration : MSM8916 / eMMC Firmware Size : 3093 MiB Done! Elapsed: 00:04:42 Reconnect Power/Cable! Loading firmware ... Firmware load error! Firmware damaged or in unknown format! Send report to support! Loading firmware ... Firmware load error! Firmware damaged or in unknown format! Send report to support! Loading firmware ... Created by Infinity-Box (c) Chinese Miracle II (c) 2017 Device Brand : OPPO Device Manufact.: OPPO Device Model : A33f Device CPU : MSM8916 Device IntName : A33f Device Version : 5.1.1 SWVersion : A33fEX_11.A.29_INT_029_201705311650 CU_SWVer : OPPO Device Compile : 5/31/2017 11:14:23 AM Device ExtInfo : A33f Load Ok! Operation : Flash [ v1.16 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 410 [MSM8916] ID_BLOCK_S : 0BAAB840 ID_BLOCK_L : 45BFD5218C1A0702FD52A2A36C37BF8F ID_BLOCK_L : 611CA20D0E91394A4FAEE3D82AC5D3F8 Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB800000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Flash Chain : 42 Flashing now Flashing : gpt_main0.bin Flashing : NON-HLOS.bin Flashing : sec.dat Flashing : sbl1.mbn Flashing : sbl1.mbn Flashing : emmc_appsboot.mbn Flashing : emmc_appsboot.mbn Flashing : rpm.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : tz.mbn Flashing : hyp.mbn Flashing : hyp.mbn Flashing : lsplash.img Flashing : boot.img Flashing : recovery.img Flashing : system.img Flashing : cache.img Flashing : persist.img Flashing : misc.img Flashing : driver.iso Flashing : userdata.img Flashing : gpt_backup0.bin Flashing : gpt_main2.bin Flashing : cdt.mbn Flashing : gpt_backup2.bin Wipe data ... BootConfig set to 0x00 Flashing done! Done! Elapsed: 00:04:53 Reconnect Power/Cable! Loading firmware ... Created by Infinity-Box (c) Chinese Miracle II (c) 2017 Device Brand : OPPO Device Manufact.: OPPO Device Model : A37f Device CPU : MSM8916 Device IntName : A37f Device Version : 5.1.1 SWVersion : A37fEX_11.A.22_INT_022_201705221641 CU_SWVer : OPPO Device Compile : 5/22/2017 10:56:07 AM Device ExtInfo : A37f Load Ok! Operation : Flash [ v1.16 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... BREAK : Device not found! HINT : Check cable, connection and drivers! Reconnect Power/Cable! Operation : Flash [ v1.16 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... BREAK : Device not found! HINT : Check cable, connection and drivers! Reconnect Power/Cable! Operation : Read Flash [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... BREAK : Device not found! HINT : Check cable, connection and drivers! Reconnect Power/Cable! Operation : Flash [ v1.16 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 410 [MSM8916] ID_BLOCK_S : 0BAAB840 ID_BLOCK_L : 45BFD5218C1A0702FD52A2A36C37BF8F ID_BLOCK_L : 611CA20D0E91394A4FAEE3D82AC5D3F8 Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB800000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Flash Chain : 43 Flashing now Flashing : gpt_main0.bin Flashing : NON-HLOS.bin Flashing : sec.dat Flashing : sbl1.mbn Flashing : sbl1.mbn Flashing : emmc_appsboot.mbn Flashing : emmc_appsboot.mbn Flashing : rpm.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : tz.mbn Flashing : hyp.mbn Flashing : hyp.mbn Flashing : lsplash.img Flashing : boot.img Flashing : recovery.img Flashing : system.img Flashing : cache.img Flashing : persist.img Flashing : misc.img Flashing : driver.iso Flashing : userdata.img Flashing : gpt_backup0.bin Flashing : gpt_main2.bin Flashing : cdt.mbn Flashing : gpt_backup2.bin Wipe data ... BootConfig set to 0x00 Flashing done! Done! Elapsed: 00:05:37 Reconnect Power/Cable! Loading firmware ... Created by Infinity-Box (c) Chinese Miracle II (c) 2017 Device Brand : OPPO Device Manufact.: OPPO Device Model : A37f Device CPU : MSM8916 Device IntName : A37f Device Version : 5.1.1 SWVersion : A37fEX_11.A.22_INT_022_201705221641 CU_SWVer : OPPO Device Compile : 5/22/2017 10:56:07 AM Device ExtInfo : A37f Load Ok! Operation : Flash [ v1.16 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... BREAK : Device not found! HINT : Check cable, connection and drivers! Reconnect Power/Cable! Operation : Flash [ v1.16 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... BREAK : Device not found! HINT : Check cable, connection and drivers! Reconnect Power/Cable! Operation : Flash [ v1.16 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 410 [MSM8916] ID_BLOCK_S : 0BAAB840 ID_BLOCK_L : 45BFD5218C1A0702FD52A2A36C37BF8F ID_BLOCK_L : 611CA20D0E91394A4FAEE3D82AC5D3F8 Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB800000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Flash Chain : 43 Flashing now Flashing : gpt_main0.bin Flashing : NON-HLOS.bin Flashing : sec.dat Flashing : sbl1.mbn Flashing : sbl1.mbn Flashing : emmc_appsboot.mbn Flashing : emmc_appsboot.mbn Flashing : rpm.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : tz.mbn Flashing : hyp.mbn Flashing : hyp.mbn Flashing : lsplash.img Flashing : boot.img Flashing : recovery.img Flashing : system.img Flashing : cache.img Flashing : persist.img Flashing : misc.img Flashing : driver.iso Flashing : userdata.img Flashing : gpt_backup0.bin Flashing : gpt_main2.bin Flashing : cdt.mbn Flashing : gpt_backup2.bin Wipe data ... BootConfig set to 0x00 Flashing done! Done! Elapsed: 00:05:34 Reconnect Power/Cable! phone is totally dead even not vibrating but after disconnecting battery from phone phone its connecting to pc |
07-03-2019, 08:57 | #4 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Make sure qcn is read from working phone. After writing qcn make factory reset once from settings. If required restore original imxx written on phone back sticker. Br. Infinity-Box Team. |
07-03-2019, 13:58 | #5 (permalink) | |
Member: 2478233 Status: Offline Thanks Meter: 596 | Quote:
Operation : Write QCN (NVM) [ v1.16 ] 1. Enable DiagInterface on device [ by Code, Root or other way ] 2. Make sure DiagDrivers installed and work correct Wait for phone... Device Found! Initialize ... DiagMode initialized! MSMHW : 00007050 MODHW : 00000FFE BUILD : MPSS.DPM.2.0.2.c1.10-00065-M8936FAAAANUZM-1.98235.2.100042.1_VENDOR RTIME : May 22 201718:10:54 BTIME : May 21 201713:00:00 DEVST : EAAAANUZ xQCN details : IMEI [1] : 86xxxxxxxxxxxxx IMEI [2] : 86xxxxxxxxxxxxx BTID : A6E248145C6C WiFi : A6E248145C6C Writing NVRAM data from XQCN image ... Writing NV Items... Writing SIM1 NV Items... Writing SIM2 NV Items... Writing RFNV... Writing Provisioning Item Files... Write done! Reboot device, if it not restart! Hint : Factory Reset is required to finish process completely! Done! Elapsed: 00:00:25 | |
